Cannot Run HomeKitLink Siri 0.6.75 / Indigo 2024.2
SearchCz
Post by SearchCz »
Just did a routine update of my plugins, but I can't get the HomeKitLInk Siri plugin to take. Got an error message about permissions:
2025-06-13 12:07:18.786 Error Requirements file for "HomeKitLink Siri 0.6.75" failed to process correctly, contact the developer with the following information:
2025-06-13 12:07:18.786 Error WARNING: The directory '/Users/daniel/Library/Caches/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
error: subprocess-exited-with-error
× Building wheel for zeroconf (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [345 lines of output]
So ... I am /usr/daniel, and my Indigo instance is running under /usr/daniel.
Also, in an attempt to remedy this situation, I granted read & write permission on .usr/daniel/Library/Caches to everyone. No love. I restored version 0.6.61 and all is well. Any idea how I can ge 0.6.65 working?
GlennNZ
Re: Cannot Run HomeKitLink Siri 0.6.75 / Indigo 2024.2
Post by GlennNZ »
Hi
The permissions for the folder pip install into is very much in Indigo’s hands. If that is the issue (and seems to be from snippet) you will have to sort out user permissions….
Re-running the Indigo installer I believe is the best way to resolve permissions errors.
Return to “HomeKitLink Siri”
