I just moved my indigo setup from an Intel Silicon MacMini to the new M4 Mac Mini with Apple silicon. I was able to get Indigo up and running, but I am getting massive errors when I load HomeKitLink. See below. I migrated the old device to the new, so maybe the new device is missing some libraries. I am not sure what to do to fix it.
Many thanks, Mark
________________
Jan 12, 2025 at 4:01:19 PM
Reloading plugin "HomeKitLink Siri 0.6.61" using API v3.4
Starting plugin "HomeKitLink Siri 0.6.61" (pid 3615)
Processing requirements for plugin "HomeKitLink Siri 0.6.61"
Requirements installing, this may take a few seconds...
Error Requirements file for "HomeKitLink Siri 0.6.61" failed to process correctly, contact the developer with the following information:
Error error: subprocess-exited-with-error
× Building wheel for zeroconf (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [345 lines of output]
A setup.py file already exists. Using it.
warning: src/zeroconf/_cache.py:47:23: Unknown type declaration '_DNSRecordCacheType' in annotation, ignoring
warning: src/zeroconf/_cache.py:47:49: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_cache.py:47:63: Unknown type declaration '_DNSRecord' in annotation, ignoring
warning: src/zeroconf/_cache.py:67:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
warning: src/zeroconf/_cache.py:117:32: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_cache.py:126:38: Unknown type declaration '_UniqueRecordsType' in annotation, ignoring
warning: src/zeroconf/_cache.py:138:41: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_cache.py:138:54: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:138:68: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:184:47: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:184:61: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:205:51: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:205:65: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:237:93: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:76:33: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_dns.py:119:31: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:191:43: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_dns.py:197:37: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:202:30: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:206:28: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:210:29: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:219:39: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:255:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:300:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:346:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:380:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:429:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:480:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:552:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
warning: src/zeroconf/_dns.py:224:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_handlers/answers.py:82:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/answers.py:90:13: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/answers.py:90:96: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_handlers/answers.py:102:56: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:29: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:46: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:89:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:118:48: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:129:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:134:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:206:44: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:220:55: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:238:20: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:240:15: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:267:23: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:403:14: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:404:14: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:405:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
warning: src/zeroconf/_handlers/record_manager.py:51:33: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_history.py:41:63: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_history.py:45:53: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_history.py:67:32: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_listener.py:87:20: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/zeroconf/_listener.py:109:18: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_listener.py:110:13: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_listener.py:111:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/zeroconf/_listener.py:189:14: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_listener.py:190:14: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_listener.py:191:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
warning: src/zeroconf/_listener.py:214:48: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_listener.py:222:14: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_listener.py:223:14: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_listener.py:224:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:262:35: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:22: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:35: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:49: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:60: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:74: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:362:32: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:394:44: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:152:67: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:200:33: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:205:32: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:209:44: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:213:36: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:213:49: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:217:33: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:232:34: Unknown type declaration 'bytes_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:239:28: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:257:31: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:300:41: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:306:40: Unknown type declaration 'DNSQuestion_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:323:33: Unknown type declaration 'DNSRecord_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:323:50: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:327:36: Unknown type declaration 'DNSRecord_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:327:53: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:349:63: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:349:81: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:368:61: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:376:56: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:384:79: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:32: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:53: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:77: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:102: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/__init__.py:69:64: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/__init__.py:73:66: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:189:39: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:212:16: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:212:35: Unknown type declaration 'bool_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:212:71: Unknown type declaration '_QuestionWithKnownAnswers' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:250:16: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:378:55: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:378:84: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:417:53: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:417:84: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:513:47: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:628:22: Unknown type declaration 'ServiceStateChange' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:629:15: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:630:14: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:645:56: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:147:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:153:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:165:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:171:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/info.py:304:44: Unknown type declaration 'IPVersion' in annotation, ignoring
warning: src/zeroconf/_services/info.py:323:23: Unknown type declaration 'IPVersion' in annotation, ignoring
warning: src/zeroconf/_services/info.py:336:29: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:442:35: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:442:49: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:455:66: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:464:66: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:473:56: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:485:81: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:573:17: Unknown type declaration 'IPVersion' in annotation, ignoring
warning: src/zeroconf/_services/info.py:704:77: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:731:52: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:861:13: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:862:14: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:863:15: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:864:16: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:885:35: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:885:58: Unknown type declaration 'DNSQuestionType' in annotation, ignoring
warning: src/zeroconf/_services/info.py:107:42: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/registry.py:82:65: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_updates.py:52:56: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_utils/ipaddress.py:112:43: Unknown type declaration 'bytes_' in annotation, ignoring
warning: src/zeroconf/_utils/ipaddress.py:112:58: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_utils/time.py:40:30: Unknown type declaration '_float' in annotation, ignoring
Compiling src/zeroconf/_dns.py because it changed.
Compiling src/zeroconf/_cache.py because it changed.
Compiling src/zeroconf/_history.py because it changed.
Compiling src/zeroconf/_record_update.py because it changed.
Compiling src/zeroconf/_listener.py because it changed.
Compiling src/zeroconf/_protocol/incoming.py because it changed.
Compiling src/zeroconf/_protocol/outgoing.py because it changed.
Compiling src/zeroconf/_handlers/answers.py because it changed.
Compiling src/zeroconf/_handlers/record_manager.py because it changed.
Compiling src/zeroconf/_handlers/multicast_outgoing_queue.py because it changed.
Compiling src/zeroconf/_handlers/query_handler.py because it changed.
Compiling src/zeroconf/_services/__init__.py because it changed.
Compiling src/zeroconf/_services/browser.py because it changed.
Compiling src/zeroconf/_services/info.py because it changed.
Compiling src/zeroconf/_services/registry.py because it changed.
Compiling src/zeroconf/_updates.py because it changed.
Compiling src/zeroconf/_utils/ipaddress.py because it changed.
Compiling src/zeroconf/_utils/time.py because it changed.
[ 1/18] Cythonizing src/zeroconf/_cache.py
[ 2/18] Cythonizing src/zeroconf/_dns.py
[ 3/18] Cythonizing src/zeroconf/_handlers/answers.py
[ 4/18] Cythonizing src/zeroconf/_handlers/multicast_outgoing_queue.py
[ 5/18] Cythonizing src/zeroconf/_handlers/query_handler.py
[ 6/18] Cythonizing src/zeroconf/_handlers/record_manager.py
[ 7/18] Cythonizing src/zeroconf/_history.py
[ 8/18] Cythonizing src/zeroconf/_listener.py
[ 9/18] Cythonizing src/zeroconf/_protocol/incoming.py
[10/18] Cythonizing src/zeroconf/_protocol/outgoing.py
[11/18] Cythonizing src/zeroconf/_record_update.py
[12/18] Cythonizing src/zeroconf/_services/__init__.py
[13/18] Cythonizing src/zeroconf/_services/browser.py
[14/18] Cythonizing src/zeroconf/_services/info.py
[15/18] Cythonizing src/zeroconf/_services/registry.py
[16/18] Cythonizing src/zeroconf/_updates.py
[17/18] Cythonizing src/zeroconf/_utils/ipaddress.py
[18/18] Cythonizing src/zeroconf/_utils/time.py
running build
running build_py
creating /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_record_update.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_cache.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/asyncio.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_updates.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/__init__.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_engine.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_transport.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_core.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_logger.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_listener.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_exceptions.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_history.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/const.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_dns.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
creating /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/multicast_outgoing_queue.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/record_manager.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/__init__.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/query_handler.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/answers.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
creating /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/outgoing.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/__init__.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/incoming.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
creating /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/registry.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/__init__.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/types.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/browser.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/info.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
creating /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/time.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/ipaddress.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/asyncio.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/net.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/__init__.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/name.py -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/py.typed -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_dns.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_updates.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_record_update.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_cache.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_history.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_listener.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_handlers/answers.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/record_manager.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/multicast_outgoing_queue.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/query_handler.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_protocol/outgoing.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/incoming.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_services/browser.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/__init__.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/registry.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/info.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_utils/ipaddress.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/time.pxd -> /private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
running build_ext
File "/private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/setup.py", line 43, in <module>
setup(**setup_kwargs)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 117, in setup
return distutils.core.setup(**attrs)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 186, in setup
return run_commands(dist)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
dist.run_commands()
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 983, in run_commands
self.run_command(cmd)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 999, in run_command
super().run_command(command)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 1002, in run_command
cmd_obj.run()
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 136, in run
self.run_command(cmd_name)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 339, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 329, in run
customize_compiler(self.compiler)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 300, in customize_compiler
_customize_macos()
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 286, in _customize_macos
sys.platform == "darwin" and __import__('_osx_support').customize_compiler(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 488, in customize_compiler
_find_appropriate_compiler(_config_vars)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 244, in _find_appropriate_compiler
raise SystemError(
SystemError: Cannot locate working compiler
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
return WheelBuilder.make_in(
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 91, in make_in
wb.build(target_dir=directory)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 128, in build
self._build(zip_file)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 189, in _build
self._run_build_command(setup)
File "/private/tmp/pip-build-env-xu5fcflj/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 284, in _run_build_command
subprocess.check_call(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/subprocess.py", line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/setup.py', 'build', '-b', '/private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build', '--build-purelib', '/private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib', '--build-platlib', '/private/tmp/pip-install-ss2fijgn/zeroconf_bda23a658bd6401a9da3c1857642bc86/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for zeroconf
× Building wheel for chacha20poly1305-reuseable (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [89 lines of output]
The "poetry.dev-dependencies" section is deprecated and will be removed in a future version. Use "poetry.group.dev.dependencies" instead.
warning: src/chacha20poly1305_reuseable/__init__.py:50:57: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:105:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:139:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:164:72: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:17: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:67: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:84: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:219:47: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:225:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:237:10: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:238:21: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:244:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:244:62: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:261:10: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:262:21: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:275:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:275:62: Unknown type declaration '_bytes' in annotation, ignoring
Compiling src/chacha20poly1305_reuseable/__init__.py because it changed.
[1/1] Cythonizing src/chacha20poly1305_reuseable/__init__.py
running build
running build_py
creating /private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/__init__.py -> /private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/py.typed -> /private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/__init__.pxd -> /private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
running build_ext
File "/private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/setup.py", line 35, in <module>
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 117, in setup
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 186, in setup
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
dist.run_commands()
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 983, in run_commands
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 999, in run_command
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 1002, in run_command
cmd_obj.run()
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 136, in run
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 339, in run_command
cmd_obj.run()
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 329, in run
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 300, in customize_compiler
_customize_macos()
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 286, in _customize_macos
raise SystemError(
main()
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 91, in make_in
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 128, in build
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 189, in _build
File "/private/tmp/pip-build-env-6sd2kish/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 284, in _run_build_command
subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/setup.py', 'build', '-b', '/private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/build', '--build-purelib', '/private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/build/lib', '--build-platlib', '/private/tmp/pip-install-ss2fijgn/chacha20poly1305-reuseable_b91e5019cb8d421882330178e1cf1ac3/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
[end of output]
ERROR: Failed building wheel for chacha20poly1305-reuseable
ERROR: ERROR: Failed to build installable wheels for some pyproject.toml based projects (zeroconf, chacha20poly1305-reuseable)
HomeKitLink Siri Error Error in plugin execution InitializeMain:
File "plugin.py", line 21, in <module>
type: No module named 'ifaddr'
Stopping plugin "HomeKitLink Siri 0.6.61" (pid 3615)
Stopped plugin "HomeKitLink Siri 0.6.61"
