Permissions prevent install of HomeKit Siri plugin
elf55
Post by elf55 »
This is the error:
Installing and enabling plugin HomeKitLink Siri v0.6.61
Error ReloadPlugin() caught exception: FileIOError -- rename/move of file or folder failed -- check file/folder permissions
I've tried reinstalling Indigo 2023.2 and the plugin, but I get this same error each time. This is on an M2 mini that I migrated from an older intel mini, but did a full reinstall of Indigo as noted. No other plugin problems.
-Mike
GlennNZ
Re: Permissions prevent install of HomeKit Siri plugin
Post by GlennNZ »
Something has gone wrong with your install.
Would be suggesting
1. File Permissions issues
But rerunning the indigo installer (seems like you have done this) should fix those
2. Some other system wide security aspect unique to you
3. Perhaps the Plugin bundle folder already exists from previous copy/install. Check the Plugins and Plugins (Disabled) folders for HomekitLink plugin bundle. If so delete it and reinstall
Glenn
durosity
Post by durosity »
You’re not trying to install the plugin from an iCloud Drive location are you? I get a very similar warning when I try to install a plugin from iCloud Drive downloads folder. The solution for me is to move the plugin to my user folder and it works fine from there!
elf55
Post by elf55 »
You sir, are a steely-eyed missile man. That was exactly what I was doing and have been doing for years. I move the install file to a local folder and it installed fine. I would never have thought of that. Thanks.
-Mike
durosity
Post by durosity »
Glad I could help!
@matt or @jay this seems to be coming up a bit.. might be nice if you could add a bit of info into the error message if it comes up, if it can’t be fixed that is!
jay (support)
Post by jay (support) »
durosity wrote:@matt or @jay this seems to be coming up a bit.. might be nice if you could add a bit of info into the error message if it comes up, if it can’t be fixed that is!
I don't recall ever hearing about this before, but it's likely because we use the OS move API (vs copy) when we install a plugin (we don't want to leave plugins laying around all over your disk!). A move implies that it's getting removed from the original location and this is likely a problem when on an iCloud drive, unless the Indigo Server has full disk access (and perhaps even then). Bottom line though is that we won't know where the source is actually located so changing the error message would require significant rework of system calls and probably even require more security access permissions. Much more effort than necessary given that it hasn't come up before (or, at the least very often).
durosity
Post by durosity »
Fair! And just for the record I’ve tested it with full disk access for indigo client and server and still the same issue!
Return to “HomeKitLink Siri”
