Publish separate states as individual devices
berkinet
Post by berkinet »
[Apologies if this has been asked before. I looked, but couldn't find anything]
Is it possible to publish different states of the same Indigo device as separate HomeKit devices? For example, I have an Indigo sensor device that has separate states for humidity and temperature and I would like to publish both to HomeKit. However, it seems the plugin won't support that. Am I missing something? And, if this is not presently possible, is it something that could be added as a feature?
Thanks in advance...
GlennNZ
Re: Publish separate states as individual devices
Post by GlennNZ »
Yeah. Not likely possible I’m afraid, but there is a work around.
Indigo is a device centric system, so to change this plugin to a state based system would need a complete rewrite, probably would be pretty slow and probably need some Indigo based changes to boot. Might be able to piece together some pieces for sensors only devices (which are one way essentially) but would be a lot of overhead and additional steps prior to updating for all devices - essentially would not be a good result.
Use something like Masquerade plugin and create a copy of current device, and publish that to Home App via HKLS as whatever 2nd state you are super interested in. Slight gludge but deals with these rare cases.
Glenn
berkinet
Post by berkinet »
GlennNZ wrote:Yeah. Not likely possible I’m afraid, but there is a work around.... ...Use something like Masquerade plugin and create a copy of current device, and publish that to Home App via HKLS as whatever 2nd state you are super interested in.
Great idea. Thanks for the quick response.
Return to “HomeKitLink Siri”
