HomeKitLink Siri will not run after migrating to a new Mac
epounds
Post by epounds »
Hello...I migrated Indigo 2023.2 from an Intel Mac to a M2 Mac and everything works except the HomeKitLink Siri plugin will not load. I disabled, removed, and reinstalled, but that did not work.
I get this error when trying to install. Any recommendation on how to resolve? Thank you!
 Loading external plugins
   Loading plugin "HomeKitLink Siri 0.6.61" using API v3.4
   Starting plugin "HomeKitLink Siri 0.6.61" (pid 941)
   Processing requirements for plugin "HomeKitLink Siri 0.6.61"
   Requirements installing, this may take a few seconds...
   Error                           Requirements file for "HomeKitLink Siri 0.6.61" failed to process correctly, contact the developer with the following information:
   Error                             error: subprocess-exited-with-error
  × Building wheel for zeroconf (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [344 lines of output]
      A setup.py file already exists. Using it.
      warning: src/zeroconf/_cache.py:47:23: Unknown type declaration '_DNSRecordCacheType' in annotation, ignoring
      warning: src/zeroconf/_cache.py:47:49: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_cache.py:47:63: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_cache.py:67:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_cache.py:100:36: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_cache.py:117:32: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_cache.py:126:38: Unknown type declaration '_UniqueRecordsType' in annotation, ignoring
      warning: src/zeroconf/_cache.py:138:41: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_cache.py:138:54: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:138:68: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:184:47: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:184:61: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:205:51: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:205:65: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:237:93: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:76:33: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_dns.py:119:31: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:191:43: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_dns.py:197:37: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:202:30: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:206:28: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:210:29: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:219:39: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:255:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:300:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:346:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:380:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:429:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:480:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:552:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_dns.py:224:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_handlers/answers.py:82:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/answers.py:90:13: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/answers.py:90:96: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_handlers/answers.py:102:56: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:29: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:46: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:89:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:118:48: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:129:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:134:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:206:44: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:220:55: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:238:20: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:240:15: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:267:23: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:403:14: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:404:14: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:405:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
      warning: src/zeroconf/_handlers/record_manager.py:51:33: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_history.py:41:63: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_history.py:45:53: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_history.py:67:32: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_listener.py:87:20: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/zeroconf/_listener.py:109:18: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_listener.py:110:13: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_listener.py:111:14: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/zeroconf/_listener.py:189:14: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_listener.py:190:14: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_listener.py:191:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
      warning: src/zeroconf/_listener.py:214:48: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_listener.py:222:14: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_listener.py:223:14: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_listener.py:224:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:262:35: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:22: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:35: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:49: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:60: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:74: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:362:32: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:394:44: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:152:67: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:200:33: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:205:32: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:209:44: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:213:36: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:213:49: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:217:33: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:232:34: Unknown type declaration 'bytes_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:239:28: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:257:31: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:300:41: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:306:40: Unknown type declaration 'DNSQuestion_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:323:33: Unknown type declaration 'DNSRecord_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:323:50: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:327:36: Unknown type declaration 'DNSRecord_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:327:53: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:349:63: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:349:81: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:368:61: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:376:56: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:384:79: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:32: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:53: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:77: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:102: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/__init__.py:69:64: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/__init__.py:73:66: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:189:39: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:212:16: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:212:35: Unknown type declaration 'bool_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:212:71: Unknown type declaration '_QuestionWithKnownAnswers' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:250:16: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:378:55: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:378:84: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:417:53: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:417:84: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:513:47: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:628:22: Unknown type declaration 'ServiceStateChange' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:629:15: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:630:14: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:645:56: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:147:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:153:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:165:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:171:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/info.py:304:44: Unknown type declaration 'IPVersion' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:323:23: Unknown type declaration 'IPVersion' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:336:29: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:442:35: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:442:49: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:455:66: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:464:66: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:473:56: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:485:81: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:573:17: Unknown type declaration 'IPVersion' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:704:77: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:731:52: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:861:13: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:862:14: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:863:15: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:864:16: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:885:35: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:885:58: Unknown type declaration 'DNSQuestionType' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:107:42: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/registry.py:82:65: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_updates.py:52:56: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_utils/ipaddress.py:112:43: Unknown type declaration 'bytes_' in annotation, ignoring
      warning: src/zeroconf/_utils/ipaddress.py:112:58: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_utils/time.py:40:30: Unknown type declaration '_float' in annotation, ignoring
      Compiling src/zeroconf/_dns.py because it changed.
      Compiling src/zeroconf/_cache.py because it changed.
      Compiling src/zeroconf/_history.py because it changed.
      Compiling src/zeroconf/_record_update.py because it changed.
      Compiling src/zeroconf/_listener.py because it changed.
      Compiling src/zeroconf/_protocol/incoming.py because it changed.
      Compiling src/zeroconf/_protocol/outgoing.py because it changed.
      Compiling src/zeroconf/_handlers/answers.py because it changed.
      Compiling src/zeroconf/_handlers/record_manager.py because it changed.
      Compiling src/zeroconf/_handlers/multicast_outgoing_queue.py because it changed.
      Compiling src/zeroconf/_handlers/query_handler.py because it changed.
      Compiling src/zeroconf/_services/__init__.py because it changed.
      Compiling src/zeroconf/_services/browser.py because it changed.
      Compiling src/zeroconf/_services/info.py because it changed.
      Compiling src/zeroconf/_services/registry.py because it changed.
      Compiling src/zeroconf/_updates.py because it changed.
      Compiling src/zeroconf/_utils/ipaddress.py because it changed.
      Compiling src/zeroconf/_utils/time.py because it changed.
      [ 1/18] Cythonizing src/zeroconf/_cache.py
      [ 2/18] Cythonizing src/zeroconf/_dns.py
      [ 3/18] Cythonizing src/zeroconf/_handlers/answers.py
      [ 4/18] Cythonizing src/zeroconf/_handlers/multicast_outgoing_queue.py
      [ 5/18] Cythonizing src/zeroconf/_handlers/query_handler.py
      [ 6/18] Cythonizing src/zeroconf/_handlers/record_manager.py
      [ 7/18] Cythonizing src/zeroconf/_history.py
      [ 8/18] Cythonizing src/zeroconf/_listener.py
      [ 9/18] Cythonizing src/zeroconf/_protocol/incoming.py
      [10/18] Cythonizing src/zeroconf/_protocol/outgoing.py
      [11/18] Cythonizing src/zeroconf/_record_update.py
      [12/18] Cythonizing src/zeroconf/_services/__init__.py
      [13/18] Cythonizing src/zeroconf/_services/browser.py
      [14/18] Cythonizing src/zeroconf/_services/info.py
      [15/18] Cythonizing src/zeroconf/_services/registry.py
      [16/18] Cythonizing src/zeroconf/_updates.py
      [17/18] Cythonizing src/zeroconf/_utils/ipaddress.py
      [18/18] Cythonizing src/zeroconf/_utils/time.py
      running build
      running build_py
      creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build
      creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311
      creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_record_update.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_cache.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/asyncio.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_updates.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_engine.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_transport.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_core.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_logger.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_listener.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_exceptions.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_history.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/const.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_dns.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/multicast_outgoing_queue.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/record_manager.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/query_handler.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/answers.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/outgoing.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/incoming.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/registry.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/types.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/browser.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/info.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/time.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/ipaddress.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/asyncio.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/net.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/name.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/py.typed -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_dns.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_updates.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_record_update.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_cache.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_history.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_listener.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_handlers/answers.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/record_manager.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/multicast_outgoing_queue.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/query_handler.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_protocol/outgoing.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/incoming.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_services/browser.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/__init__.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/registry.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/info.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_utils/ipaddress.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/time.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      running build_ext
        File "/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/setup.py", line 43, in <module>
          setup(**setup_kwargs)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 103, in setup
          return distutils.core.setup(**attrs)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 185, in setup
          return run_commands(dist)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
          dist.run_commands()
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
          self.run_command(cmd)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 963, in run_command
          super().run_command(command)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
          cmd_obj.run()
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 131, in run
          self.run_command(cmd_name)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
          self.distribution.run_command(command)
          cmd_obj.run()
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 315, in run
          customize_compiler(self.compiler)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 291, in customize_compiler
          _osx_support.customize_compiler(_config_vars)
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 488, in customize_compiler
          _find_appropriate_compiler(_config_vars)
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 244, in _find_appropriate_compiler
          raise SystemError(
      SystemError: Cannot locate working compiler
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
          return _build_backend().build_wheel(wheel_directory, config_settings,
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
          return WheelBuilder.make_in(
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 88, in make_in
          wb.build(target_dir=directory)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 121, in build
          self._build(zip_file)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 182, in _build
          self._run_build_command(setup)
        File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 248, in _run_build_command
          subprocess.check_call([
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/subprocess.py", line 413, in check_call
          raise CalledProcessError(retcode, cmd)
      subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/setup.py', 'build', '-b', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build', '--build-purelib', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib', '--build-platlib', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for zeroconf
  × Building wheel for chacha20poly1305-reuseable (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [87 lines of output]
      warning: src/chacha20poly1305_reuseable/__init__.py:50:57: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:105:14: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:139:14: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:164:72: Unknown type declaration '_int' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:178:17: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:178:67: Unknown type declaration '_int' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:178:84: Unknown type declaration '_int' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:219:47: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:225:37: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:237:10: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:238:21: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:244:37: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:244:62: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:261:10: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:262:21: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:275:37: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:275:62: Unknown type declaration '_bytes' in annotation, ignoring
      Compiling src/chacha20poly1305_reuseable/__init__.py because it changed.
      [1/1] Cythonizing src/chacha20poly1305_reuseable/__init__.py
      running build
      running build_py
      creating /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build
      creating /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311
      creating /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      copying src/chacha20poly1305_reuseable/__init__.py -> /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      copying src/chacha20poly1305_reuseable/py.typed -> /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      copying src/chacha20poly1305_reuseable/__init__.pxd -> /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      running build_ext
        File "/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/setup.py", line 35, in <module>
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 103, in setup
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 185, in setup
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
          dist.run_commands()
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 963, in run_command
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
          cmd_obj.run()
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 131, in run
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
          cmd_obj.run()
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 315, in run
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 291, in customize_compiler
          raise SystemError(
          main()
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 88, in make_in
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 121, in build
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 182, in _build
        File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 248, in _run_build_command
      subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/setup.py', 'build', '-b', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build', '--build-purelib', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib', '--build-platlib', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
      [end of output]
  ERROR: Failed building wheel for chacha20poly1305-reuseable
ERROR: Could not build wheels for zeroconf, chacha20poly1305-reuseable, which is required to install pyproject.toml-based projects
   HomeKitLink Siri Error          Error in plugin execution InitializeMain:
  File "plugin.py", line 21, in <module>
type: No module named 'ifaddr'
   Stopping plugin "HomeKitLink Siri 0.6.61" (pid 941)
   Waiting for external plugins to initialize
   Stopped plugin "HomeKitLink Siri 0.6.61"
epounds
Re: HomeKitLink Siri will not run after migrating to a new M
Post by epounds »
I figured it out. Just needed to install/reinstall Xcode. This helped. Thank you!
viewtopic.php?f=366&t=27750
Return to “HomeKitLink Siri”
