New Hue Error after upgrading to most recent plug In.
joeaug
Post by joeaug »
Hi. I'm running the most recent version of Indigo on macOS Monterey with no issues on a late 2009 MacBook. Karl recently updated the plugin to address an issue with not being able to add bridges and the fix is great! But since then I occasionally get the following error stream - like maybe 3 or 4 times a day although operation seems unaffected:
Hue Lights Error
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 438, in _error_catcher
yield
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 519, in read
data = self._fp.read(amt) if not fp_closed else b""
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 465, in read
s = self.fp.read(amt)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socket.py", line 705, in readinto
return self._sock.recv_into(b)
ConnectionResetError: [Errno 54] Connection reset by peer
During handling of the above exception, another exception occurred:
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 760, in generate
for chunk in self.raw.stream(chunk_size, decode_content=True):
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 576, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 512, in read
with self._error_catcher():
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 455, in _error_catcher
raise ProtocolError("Connection broken: %r" % e, e)
urllib3.exceptions.ProtocolError: ("Connection broken: ConnectionResetError(54, 'Connection reset by peer')", ConnectionResetError(54, 'Connection reset by peer'))
File "plugin.py", line 857, in commandToHub_HTTP
r = requests.get(command, timeout=kTimeout, headers={'Connection':'close'})
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/sessions.py", line 529, in request
resp = self.send(prep, **send_kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/sessions.py", line 687, in send
r.content
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 838, in content
self._content = b''.join(self.iter_content(CONTENT_CHUNK_SIZE)) or b''
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 763, in generate
raise ChunkedEncodingError(e)
requests.exceptions.ChunkedEncodingError: ("Connection broken: ConnectionResetError(54, 'Connection reset by peer')", ConnectionResetError(54, 'Connection reset by peer'))
Wondering if there might be any connection between the update and this error? Tried all the usual fixes of rebooting devices, etc. but no change. Anyone else seeing this? Ideas?
Re: New Hue Error after upgrading to most recent plug In.
If it just happens once or twice a day it is likely a network issue or an issue on the bridge.
Could you open a terminal and run ping to the bridge
Let it run and check if you have ping timeouts at the same time when these error messages occur
Return to “Hue Lights”
