Error
Bildhauer
Error
Post by Bildhauer »
After working fine for approx. 48 hours all over sudden I'm getting the following messages:
 Stopped plugin "HomeKitLink Siri 0.6.5"
   Starting plugin "HomeKitLink Siri 0.6.5" (pid 1069)
   Hue Lights                      Updated:  LED Fernseher links                         to 11
   HomeKitLink Siri
   HomeKitLink Siri                ================================================ Initializing New Plugin Session =================================================
   HomeKitLink Siri                Plugin name:                   HomeKitLink Siri
   HomeKitLink Siri                Plugin version:                0.6.5
   HomeKitLink Siri                Plugin ID:                     com.GlennNZ.indigoplugin.HomeKitLink-Siri
   HomeKitLink Siri                Indigo version:                2023.1.0
   HomeKitLink Siri                Python version:                3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
   HomeKitLink Siri                Python Directory:              /Library/Frameworks/Python.framework/Versions/3.10
   HomeKitLink Siri
   HomeKitLink Siri                ================================================== End Initializing New Plugin  ==================================================
   Started plugin "HomeKitLink Siri 0.6.5"
   HomeKitLink Siri                Finding devices to publish to HomeKit Given Startup...
   Hue Lights                      Updated:  LED Fernseher links                         to 10
   HomeKitLink Siri                Starting accessory HomeKitLink Bridge 425081 on address 192.168.11.30, port 51826.
   HomeKitLink Siri Error          (characteristic.py: Function: to_valid_value  line: 234):    Exception :  Message : ContactSensorState: value=37.20 W is not a numeric value.
   HomeKitLink Siri Error          Traceback:
   HomeKitLink Siri Error          Error in plugin execution:
NoneType: None
Exc_info: (None, None, None)
Exc_Text: NoneType: None
Stack_info: None
   HomeKitLink Siri                A total of 54 devices are currently selected to be published to HomeKit
   HomeKitLink Siri                0 Home Kit Accessories are now Started.
   HomeKitLink Siri                Given this difference, please review devices by Select Menu Item, Show Device Publications for more information.
HomeKit ist not working at all.
Please help! ;-)
Bildhauer
Re: Error
Post by Bildhauer »
"Show Device Publications" ends in:
HomeKitLink Siri                ============================================================ Currently Published Devices / Action Groups ============================================================
   HomeKitLink Siri                BridgeID             DeviceID             Device Name                                        HomeKit Name                             Device Type          Sensor Type/Linked Doorbell
   HomeKitLink Siri                ---------------------------------------------------------------------------------------------------------------------------------------------------------------------
   HomeKitLink Siri                Bridge ID:425081     1005174769           Badezimmer 1 Stunde auf 23º Button                 1 Stunde auf 23º                         Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1013440435           Verbrauch Waschkeller stündlich                    Verbrauch                                ContactSensor        curEnergyLevel.ui
   HomeKitLink Siri                Bridge ID:425081     1023597193           Zwischenstecker Trockner Keller                    Wäschetrockner                           Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     108032090            Devolo Raumthermostat Buero Heizung                Raumthermostat                           Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1083382813           Gästezimmer 1 Stunde auf 23º Button                1 Stunde auf 23º                         Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     114346584            Qubino Lammeleneinstellung Esszimmer Erker mitte/ rechts Erker mittterechts                       Blind                - None Selected -
   HomeKitLink Siri                Bridge ID:425081     122288300            LEDs Aussenbereich Garten hinten                   LEDs Garten hinten                       LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1264641968           Beet vorne rechts 2 - Relay Switch 6               Beet vorne re.                           Irrigation           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1270529572           Schalter Zeitschaltuhr Beet rechts AN/ AUS         Timer Beet rechts                        Valve                - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1307894838           Spirit Heizungsthermostat Buero                    Heizungsthermostat                       Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1313077303           Büro gemütlich                                     Büro gemütlich                           Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1331336435           Zwischenstecker Küche Kühlschrank                  Kuehlschrank                             Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1346536011           Devolo Heizungsthermosthat Gästezimmer             Gästezimmer                              Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1386135786           Rasenbewässerung (Programm) HomeKIt Button         Rasenbewässerung -Program-               Irrigation           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1419121000           Devolo Heizungsthermostat Wohnzimmer               Wohnzimmer                               Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1446029434           Qubino Lammelleneinstellung Wohnzimmer Schiebetür  Schiebetür                               Blind                - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1446722917           Spirit Heizungsthermosthat Schlafzimmer rechts     Heizung rechts                           Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1458447894           Devolo Heizungsthermosthat Begehbarer Kleiderschrank Begehbarer Kleiderschrank                Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1501893467           Büro Licht AN/ AUS                                 Büro                                     LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1508319562           Licht AN/AUS Wohnbereich                           Wohnzimmer                               LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1547662784           Zwischenstecker Büro Thunderbolt-Monitor 1 (links) Monitor li.                              Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1620588674           Spirit Heizungsthermosthat Badezimmer              Heizungsthermostat                       Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1649229526           Zwischenstecker Küche Spülmaschine                 Spülmaschine                             Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1656794290           Schalter Zeitschaltuhr Beet links AN/ AUS          Timner Beet links                        Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1687651780           Zwischenstecker Esszimmer Kaffeemaschine           Kaffeemaschine                           Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1702280427           Rechteckregner Terasse vorne - Relay Switch 3      Rechteckregner vorne                     Irrigation           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1741426531           Zwischenstecker Kühlschrank Flur                   Kühlschrank Flur                         Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1743418890           Devolo Raumthemostat Wohnzimmer Heizung            Raumthermostat                           Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1847240237           LEDs Carport                                       LEDs Carport                             LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     1957744991           Spirit Heizungsthermosthat Viktoria                Heizungsthermostat                       Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     200592824            Zwischenstecker Büro Thunderbolt-Monitor 2 (rechts) Monitor re.                              Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     238881578            Zwischenstecker Keller Waschmaschine               Wäschetrockner                           Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     24717048             Schlafzimmer 1 Stunde auf 23º Button               1 Stunde auf 23º                         Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     277398496            Zwischenstecker Wohnzimmer Stehlampe Terassenseite Stehlampe Terassenseite                  LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     294109719            LEDs Beet links                                    LEDs Beet                                LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     304613501            Spirit Heizungsthermosthat Gäste-WC                Heizungsthermostat                       Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     316158684            Bewegungsmelder Carport                            Carport                                  MotionSensor         onOffState
   HomeKitLink Siri                Bridge ID:425081     329024126            Qubino Lammeleneinstellung Esszimmer Erker links   Erker links                              Blind                - None Selected -
   HomeKitLink Siri                Bridge ID:425081     348868401            Dusche 1 Stunde auf 23º Button                     1 Stunde auf 23º                         Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     372964597            Beleuchtung  Aussenbereich                         Aussenbereich                            LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     396062130            Zwischenstecker TV Wohnzimmer                      Fernseher                                Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     415946568            Zwischenstecker Esszimmer große Salzlampe          große Salzlampe                          Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     45248862             Zwischenstecker Wohnzimmer Stehlampe Auffahrtseite Stehlampe Auffahrtseite                  LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     542976004            Beet hinten links - Relay Switch 9                 Beet hinten li.                          Irrigation           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     558912560            Kleine Rasensprenger Ecken hinten rechts -  Relay Switch 5 RS hinten rechts                         Irrigation           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     5787685              Zwischenstecker Esszimmer kleine Salzlampe         kleine Salzlampe                         LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     643379203            Kleiner Rasensprenger links vorne -  Relay Switch 7 RS links vorne                           Irrigation           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     648729139            Schalter Zeitschaltuhr Bewaesserung AN/ AUS        Timer Rasenbewässerung                   Valve                - None Selected -
   HomeKitLink Siri                Bridge ID:425081     650661604            Zwischenstecker Keller Tiefkühlschrank             Tiefkühlschrank                          Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     698375986            Spirit Heizungsthermosthat Maximilian              Heizungsthermostat                       Thermostat           - None Selected -
   HomeKitLink Siri                Bridge ID:425081     850095033            Licht AN/AUS Weihnachtsbeleuchtung                 Weihnachtsbeleuchtung                    LightBulb            - None Selected -
   HomeKitLink Siri                Bridge ID:425081     869380927            Zwischenstecker Küche Thermomix                    Thermomix                                Switch               - None Selected -
   HomeKitLink Siri                Bridge ID:425081     909408573            Qubino Lammeleneinstellung Wohnzimmer Auffahrt     Auffahrtseite                            Blind                - None Selected -
   HomeKitLink Siri                Bridge ID:425081     922177807            Qubino Lammelleneinstellung Wohnzimmer Terrasse Tür links Terassentür links                        Blind                - None Selected -
   HomeKitLink Siri                ====================================================================== 54 HomeKit Device Found=======================================================================
   HomeKitLink Siri                ======================================================== Thats the end of Published Devices / Action Groups =========================================================
   Hue Lights                      Updated:  LED Fernseher links                         to 36
Bildhauer
Re: Error
Post by Bildhauer »
Sorry for disturbing you. I found the reason: There was a device measuring the power consumption integrated into the bridge. Deleting it was the solution!
GlennNZ
Re: Error
Post by GlennNZ »
Hi
No problem, glad you fixed.
This bit - the first error is actually, surprisingly helpful, typically HomeKit just dies
Likely device here:
Particularly the Sensor bit for a ContactSensor being Energy Level - should be True/False.
But glad you fixed!
Would suggesting updating to 0.6.27
https://github.com/Ghawken/HomeKitLink-Siri/releases
Brings a number of fixes (particularly for OS17) and speed of notification.
Plan to release soon just nice to have slightly more feedback before I do so....
Glenn
Return to “HomeKitLink Siri”
