I updated Indigo 2022.2.2 and the logs mentioned some plugins had updates. I updated the MyQ plugin to 2022.0.3 and I'm getting the following in the Indigo log:
Reloading plugin "MyQ 2022.0.3" using API v3.0
Starting plugin "MyQ 2022.0.3" (pid 72521)
MyQ Error Error in plugin execution InitializeMain:
File "plugin.py", line 18, in <module>
type: 'Required Python libraries missing. Run 'pip3 install pymyq==3.1.5' in Terminal window, then reload plugin.
Stopping plugin "MyQ 2022.0.3" (pid 72521)
I updated the pymyq version using the command in the log.
Here's the successful completion message from the terminal:
Installing collected packages: soupsieve, pkce, multidict, idna, frozenlist, charset-normalizer, attrs, async-timeout, yarl, beautifulsoup4, aiosignal, aiohttp, pymyq
Successfully installed aiohttp-3.8.4 aiosignal-1.3.1 async-timeout-4.0.2 attrs-23.1.0 beautifulsoup4-4.12.2 charset-normalizer-3.2.0 frozenlist-1.4.0 idna-3.4 multidict-6.0.4 pkce-1.0.3 pymyq-3.1.5 soupsieve-2.4.1 yarl-1.9.2
Reloading the plugin still gives me the same message.
Here's the python version on my system:
usr/bin/python3 --version
Python 3.9.6
What am I doing wrong? I'll apologize in advance if I didn't give enough info.
Upgraded to 2022.0.3 - Required Python Libraries Missing
- FlyingDiver
Re: Upgraded to 2022.0.3 - Required Python Libraries Missing
That's not the correct version of Python for Indigo. You have a rogue Python3 install, and the pip command is not installing the package in the correct place.
Thanks for the quick response. Ok...my googling tells me to check the usr/local/bin location which tells me this:
/usr/local/bin/python3 --version
Python 3.11.4
Better? Or too new? Or still the wrong location?
When I try to install the pymyq, here's what it's trying to install:
Requirement already satisfied: pymyq==3.1.5 in /opt/homebrew/lib/python3.10/site-packages (3.1.5)
Requirement already satisfied: aiohttp in /opt/homebrew/lib/python3.10/site-packages (from pymyq==3.1.5) (3.8.4)
Requirement already satisfied: beautifulsoup4 in /opt/homebrew/lib/python3.10/site-packages (from pymyq==3.1.5) (4.12.2)
Requirement already satisfied: pkce in /opt/homebrew/lib/python3.10/site-packages (from pymyq==3.1.5) (1.0.3)
Requirement already satisfied: attrs>=17.3.0 in /opt/homebrew/lib/python3.10/site-packages (from aiohttp->pymyq==3.1.5) (23.1.0)
Requirement already satisfied: charset-normalizer<4.0,>=2.0 in /opt/homebrew/lib/python3.10/site-packages (from aiohttp->pymyq==3.1.5) (3.2.0)
Requirement already satisfied: multidict<7.0,>=4.5 in /opt/homebrew/lib/python3.10/site-packages (from aiohttp->pymyq==3.1.5) (6.0.4)
Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in /opt/homebrew/lib/python3.10/site-packages (from aiohttp->pymyq==3.1.5) (4.0.2)
Requirement already satisfied: yarl<2.0,>=1.0 in /opt/homebrew/lib/python3.10/site-packages (from aiohttp->pymyq==3.1.5) (1.9.2)
Requirement already satisfied: frozenlist>=1.1.1 in /opt/homebrew/lib/python3.10/site-packages (from aiohttp->pymyq==3.1.5) (1.4.0)
Requirement already satisfied: aiosignal>=1.1.2 in /opt/homebrew/lib/python3.10/site-packages (from aiohttp->pymyq==3.1.5) (1.3.1)
Requirement already satisfied: soupsieve>1.2 in /opt/homebrew/lib/python3.10/site-packages (from beautifulsoup4->pymyq==3.1.5) (2.4.1)
Requirement already satisfied: idna>=2.0 in /opt/homebrew/lib/python3.10/site-packages (from yarl<2.0,>=1.0->aiohttp->pymyq==3.1.5) (3.4)
I'm assuming this is wrong, too, since I'm still getting the same error.
Python 3.11.4
- FlyingDiver
jkeenan@Kraken Plugins % python3 --version
Python 3.10.2
jkeenan@Kraken Plugins % which python3
/Library/Frameworks/Python.framework/Versions/3.10/bin/python3
- FlyingDiver
Homebrew is definitely wrong. You should not install homebrew Python on your Indigo server. I'm not sure where your 3.9 version is from.
Thanks, I vaguely remember installing Homebrew a long time ago, removed it and all is well. Thanks!
