Hi.. its been a while since I have used pibeacon but now looking to use a ToF sensor to measure the water in my espresso machine, and was thinking of doing something with an arduino nano, but never used one before, when I realised that as these are i2c they would probably be one that works here, and there is!
I was planning to use a little lcd display on the arduino, but could just use indigo to notify me when I should be topping it up (before it hits empty and I have to fill it up when not caffeinated!). However a screen would be good as well. I see some comments about displays but hard to see a list of what is supported.
Ideally I would be able to convert the distance, ie between 3cm (full) and 25cm (empty ) into a % full indication on the display, but distance would be ok too. Is this possible?
Cheers
Simon.
Time of Flight sensor and display
Re: Time of Flight sensor and display
Simon ,
there a re properties you can set in device edit of all distance sensors: offset and multiply
value shown: ( value measured + offset ) * multiply
so try
offset = -25
multiply = - 100/22 = -4.54545
that gives 0 at 25 and 100 at 3
but if it goes over or under it will give you >100 and < 0 numbers
I could add min/ max to the options if needed
so try
offset = -25
Cheers. Let me get one and play.
One problem I have with use of a display is not having a case for it so looks “unfinished “
please also check out v ..167.71 it has properties cut max and cut min. that will limit the distance values between these values.
Cheers. Sensor arrives Friday so I’ll have a test then.
