Troubleshooting Options for HomeKitLink Siri
GlennNZ
Post by GlennNZ »
Troubleshooting HomeKit
Image=
Homekit is a fairly complicated system, which has many particularly sources of issues. There are a number of third party libraries that try to access HomeKit like the HKLS (Homekit link Siri Plugin) does.
Sometimes googling Homebridge (one system), or pyHAP (other library), or Node Homebridge (other) and your issue may give you some options to try.
Also check the forums here & GitHub for ‘issues’ even open or closed that may have instructions on how to fix the rare problem.
Terminology
Homekit, Homekitlink Siri plugin are confusingly similar names.
Home app == App on ipad device or Max
HomeKit == the apple system itself,
HKLS (HomeKitLinkSiri)- this Plugin
First most, from a HKLS stand point.
Follow the setup instructions, ideally for one bridge, and one simple device.
(Note you can continue to add up to 95 devices per bridge)
If this works and functions correctly, then you add a new device and things fall over - this will be related to how you have setup this new device. Unpublish it and start again.
Troubleshooting
1. Pair Verify Error
HomeKitLink Siri Error (hap_handler.py: Function: _pair_verify_two line: 547): Error : Message : ('192.168.1.45', 50634): Client 065ba670-6da8-48c6-bb08-7eb6925dc343 attempted pair verify without being paired to HomeKitLink Bridge 316862 first.
or
Home app Client with IP address ('XXXXXX', 59470) appears incompatible with this version of homekit. It attempted to connect to Bridge HomeKitLink Bridge 766590 and this connection failed to verify. Typically this means this client hasn't been updated to latest OS version, or is incompatible with it. This needs to be addressed with the Client Home App. See forum for more details as needed.
or
Normally, this will relate to updating the Homekit architecture to 16.4 which has recently become available on 27th March.
If you have devices, hubs, appleTV, mac’s that access HomeKit and haven’t been updated, or are unable to update then this message will be repeatedly received until you update. It comes from the client for every bridge you have - its the client that is the problem and needs to be tracked down. In the case of your error message client is 192.168.1.45
What normally happens with the Homekit architecture update is you receive this message once for the client in particularly (for every bridge you have - so can be multiple red lines if have multiple brigdes) - and then they verify and it goes.
With devices that are not compatible with the new Homekit, this message continues until you remove Home app from them and/or logout.
Alternatively - something has gone wrong with earlier architecture update for this homekit client - which has been seen multiple times before and one of the reasons the 16.2 update was pulled by apple, until it recent return. In this case - Log out, log in again sometimes work. Occasionally it can relate to home icloud caching, and that appears eventually go away. Since you have deleted bridges - that won’t be the issue.
Seeing you have deleted bridges and restarted - it will be because the client in question has not upgraded to HomeKit new architecture. (? not compatible). You should have received a warning message from the Home app when you upgraded.
The pair_verify error typically means that a Home app client has not been updated to the new Home architecture. Until it does it will not be able to connect to any of the HomekitLink Bridges. This error refers to this unverified client (as on old incompatible version of Home) trying to connect. It fails. You need to track down the client (in this case 192.168.0.48 - from DHCP router lists, or check IP’s of clients. Either upgrade the client if possible, or remove it from the Home.
2. Accessory Already Added Error
This occurs if you have paired a HKLS bridge with Home app, either completely or partially and then cancelled. You then try to re-pair (scanning QR code) and you receive this message.
Ideally I would suggest deleting the bridge completely in both Indigo and Home app and creating a new Bridge device and starting again.
However in version 0.6.0 there is an option to Reset Accessory for this issue. Delete bridge from Home app, then run reset accessory. This will remove any security information between Homekit and this HKLS bridge. It will leave all indigo devices attached to it, so after reset when you add these devices should show up for setup in the Home app
GlennNZ
Re: Troubleshooting Options for HomeKitLink Siri
Post by GlennNZ »
3. Accessory Not Found error
Occasionally this can occur after scanning QR code and after a spinning wheel for a period of time.
This is a fairly broad network issue, communication issue between the Indigo Mac running plugin and Homekit system overall.
At times it appears it can relate to cache within HomeKit itself.
First try:
Wifi trick
On your iOS device, use the Forget Network feature in your WiFi settings.
Rejoin your WiFi network.
Attempt to add the homekitlink platforms/accessories as you normally would.
or a broader issue/Basically HomeKit can’t connect to your Indigo Mac.
Firewall?
Network issues?
Blocked particularly Ports?
mDNS issue?
Bonjour connection issue?
iOS device issue (old IOS devices have issues)
This is pretty generic: But worthwhile reviewing.
https://www.macworld.com/article/673739 ... 0is%20down.
and Broader connection issues...
These can have any number of causes, from firewall limiting access to Indigo computer, to network setup, and networks themselves eg. ivp4 versus ivp6 etc..
Googling Homebridge and the error you are seeing may help.
Additionally:
This LFX app - checks for similiar network issues (Bonjour broadcasts etc)
https://support.lifx.com/en_us/free-net ... -ByvgG_iIu
The DNS Discovery app
https://apps.apple.com/us/app/discovery ... 4916?mt=12
Can be run on either Mac or ipad and checks for devices 'advertising' on your network.
We should be able to find a
_hap._tcp.
In the apps displayed list - click on this and should list all Homekit Bridges it finds on your network.
If the Homekitlink bridge is not there -- then something is up with this discovery process.
If this seems the issue, Homekitlink Siri version 0.6.0 adds a number of potentially breaking advanced options for this discovery process:
I would suggest you trial these one at a time, restarting the plugin manually to action them (as per the description)
mDNS Options: IP Version.
If having issues would suggest this should be IPVersion.V4Only
mDNS Options Interfaces
a comma seperated list, or single IP address that HKLS should listen on. e.g. the IP address of the Indigo mac Network interface that you believe should be used.
If have multiple interfaces enabled this may be causing an issue. Limit it to one network. eg. 192.168.1.19
mDNS use Apple AWDL: This shouldn't help and would leave disabled.
Finally:
The below - which is not a mDNS/Bonjour setting, rather the IP address that the plugin uses for the Bridge instance.
Homekit Server Options Interface: Single IP address which is what will be forced used for HKLS.
This differs from mDNS as above. It must be the device you are running the plugin on, and the preferred network.
Different Computers
Post by Different Computers »
Just thought to mention for others' benefit that after installing iOS 18.7 I had to restart this plugin to get Home to see Indigo devices.
Return to “HomeKitLink Siri”
