Example - Passing a dictionary to a shortcut from macOS
Share your macOS, iOS, and iPadOS shortcuts here. Post your shortcut in a new topic and be sure to describe thoroughly (screenshots, full text of any scripts, apps used, etc).
anyone
Post by anyone »
I knew you could pass arguments but never found a use, until recently.
shortcuts run "pass to indigo" <<< '{"message":"indigo.device.toggle", "objectId":"1252158401", "Key Location":"Indigo API Key 2"}'
MODERATOR'S NOTE: amended post title to include "Example"
DaveL17
Re: Passing a dictionary to a shortcut from macOS
Post by DaveL17 »
That's an excellent tip. Thanks for sharing it! I'm going to add your example to the docs. I'm also going to amend the title of your post to include "Example" to make it easier to find.
One note for folks who may try to run this command from within Indigo: you can't use pipes from the Indigo "Run Shell Script" action item. There's a bit of a hack listed in the docs to get around this. It involves using a shell script as an intermediate step.
My Plugins and Scripts
Return to “Apple Shortcuts”
