insert a var in a message being sent: A how do I question...
berkinet
Post by berkinet »
Interaction with a sprinkler valve controller. the Shim device (an On/Off Switch) can now turn a valve on and off. However, at the moment, the on payload contains a fixed value for the duration. How can I set that up to use a variable, or maybe even a dimmer (slider) control where 0-100 in in minutes.
Any idea welcomed.
Re: insert a var in a message being sent: A how do I questio
File an enhancement request to support variable substitution in the action payload fields. I probably should have done that from the beginning.
Return to “MQTT”
