This is probably obvious to others. But, as a complete newbie to MQTT, and Flying Diver's MQTT plugins, I have been doing a bit of learning. So, I thought I'd share something I figured out today in the hope it will help someone else, or that at least someone will tell me what I got wrong.
The situation is the path MQTT messages take between the broker (I am using MQTT Broker, but it doesn't matter) and the "shim devices" created with the MQTT Shims plugin. I am exchanging messages with a LinkTap sprinkler controller. The MQTT topic has a root of a/b/c . Then, the specific sprinkler valve controller is appended as a 4th element (topic field 3 in the MQTT Connector) subscription entry. I initially had a separate subscribed topic for each controller. However, I found I can use MQTT wildcards to slim that down to just one subscription. The form is a/b/c/# and will match any 4 element topic starting with a/b/c/ . However, I still had separate Message Types for each controller. But, I was able to get by with just one message type ###foo### (set in the MQTT trigger). I made this work by using the shim configuration Unique ID Location test. I choose Topic Component, and set the Topic Field to 3: the 4th field of the Topic. I then set the Unique ID Value to the ID of the respective sprinkler. So, one Connector and one trigger can catch and properly route all of my controller valves. Of course, I did have to have a separate shim for each valve.
The only downside I can see here is that every shim sees every message. But, I doubt that will be an issue.
Anyway, I hope someone finds this useful, and if not, at least I now have a record of what I did that I will on some future date find with a google search.
Clarification of my MQTT plugins understanding
Jump to
- Indigo Help
- ↳ Announcements
- ↳ Basic Usage Questions
- ↳ Devices
- ↳ Schedules
- ↳ Conditions
- ↳ Action Groups and Actions
- ↳ Variables
- ↳ Control Pages
- ↳ Feature Requests
- ↳ Z-Wave
- ↳ INSTEON
- ↳ Indigo Virtual Devices
- ↳ X10 - Legacy
- ↳ Supported Hardware
- ↳ Interfaces
- ↳ IR and A/V Devices
- ↳ Switches
- ↳ Thermostats
- ↳ Miscellaneous Devices
- ↳ Built-in Plugins
- ↳ Airfoil Pro
- ↳ Old Airfoil Discussions
- ↳ Alexa
- ↳ EasyDAQ Relay Card
- ↳ Email+
- ↳ Global Property Manager
- ↳ iTunes (Discontinued)
- ↳ NOAA Weather
- ↳ SQL Logger
- ↳ Timers and Pesters
- ↳ WeatherSnoop
- ↳ Growl (Discontinued)
- ↳ Indigo Server Software
- ↳ Indigo Mac Client App
- ↳ Indigo Touch for iOS
- ↳ Indigo Touch for the Web
- ↳ Extending Indigo
- ↳ AI Coding Agents
- ↳ Python Scripting
- ↳ Client APIs
- ↳ Hacking
- ↳ AppleScript Scripting
- ↳ Archived Posts
- ↳ Plugin Lists
- ↳ AaronLionsheep’s Plugins
- ↳ ShellyMQTT
- ↳ ShellyNGMQTT
- ↳ AB's Plugins
- ↳ AD2USB Alarm Interface
- ↳ Anyone's Plugins
- ↳ Autolog's Plugins
- ↳ AWTRIX
- ↳ Dynamic View Controller
- ↳ Foscam HD Controller
- ↳ Hubitat
- ↳ LIFX Controller
- ↳ nanoleaf Controller
- ↳ Roon Controller
- ↳ SMAPPEE Controller
- ↳ Squeezebox Controller
- ↳ Starling Bridge
- ↳ Touch Portal
- ↳ TRV Controller
- ↳ Z-Wave Interpreter
- ↳ Zigbee2mqtt
- ↳ Berkinet's Plugins
- ↳ Bill's Plugins
- ↳ Bouncing Ball LTD
- ↳ Dave's Plugins
- ↳ Announcements Plugin
- ↳ Bike Share Plugin
- ↳ Dave's Scripts
- ↳ GhostXML Plugin
- ↳ Indigo Log Viewer
- ↳ Matplotlib Plugin
- ↳ Multitool Plugin
- ↳ OWServer Plugin
- ↳ Z-Wave Node Matrix Plugin
- ↳ Deprecated Plugins
- ↳ Thingspeak Plugin
- ↳ WUnderstation Plugin
- ↳ WUnderground Plugin
- ↳ Fantastic Weather Plugin
- ↳ Duncan’s Plugins
- ↳ FlyingDiver's Plugins
- ↳ Ecobee
- ↳ Harmony Hub
- ↳ Home Assistant Agent
- ↳ LIFX Bridge
- ↳ Lutron
- ↳ miniUniFi
- ↳ MQTT
- ↳ Spy Connect
- ↳ Trane Nexia
- ↳ Twilio
- ↳ Other Plugins
- ↳ Discontinued Plugins
- ↳ RFPlayer
- ↳ MyQ
- ↳ Better Email
- ↳ GlennNZ's Plugins
- ↳ Actron QUE AC Plugin
- ↳ AppleTV Plugin
- ↳ BlueIris
- ↳ DeepState AI Plugin
- ↳ Deluxe Graphing
- ↳ Device Timer
- ↳ Dreame Vacuum Plugin
- ↳ Emby Plugin
- ↳ Enphase Envoy Solar
- ↳ ESPHome4Indigo
- ↳ FindFriendsMini Plugin
- ↳ Gecko Spa Plugin
- ↳ Holiday Plugin
- ↳ HomeKitLink Siri
- ↳ iMessage
- ↳ iRoomba iRobot Plugin
- ↳ Kiosk Home iOS App
- ↳ LedSimple Effects Plugin
- ↳ Mammotion Robot
- ↳ Paradox Alarm Plugin
- ↳ Sipura SPA VOIP Plugin
- ↳ Solar Smart
- ↳ Sunrise Plugin
- ↳ Tesla Battery
- ↳ Windows PC Remote Plugin
- ↳ Greg Glockner's Plugins
- ↳ Greg's Plugins
- ↳ Honeywell TC2 Security
- ↳ howartp's Plugins
- ↳ Clock Display
- ↳ EnergyLink
- ↳ Font Awesome
- ↳ Honeywell Evohome
- ↳ MyEnergi Hub
- ↳ Neo Smart Blinds
- ↳ Pulse Counter
- ↳ Sense Home Energy
- ↳ Sensibo
- ↳ Somfy Manager
- ↳ Tesla EV Control
- ↳ Variable Devices
- ↳ Verisure Alarm
- ↳ Volvo On Call
- ↳ Wakeup Scheduler
- ↳ ZWave Lock Manager
- ↳ ZWave Sensor Logger
- ↳ ZWave Scene Controller
- ↳ ZWave Watcher
- ↳ Zwave Window Controller
- ↳ Jason's Plugins
- ↳ GitHub Plugin Updater
- ↳ Network Devices
- ↳ Power Source
- ↳ Prometheus Client
- ↳ Prowl Notify
- ↳ RToggle
- ↳ Webcam
- ↳ XMPP Client
- ↳ Bouncie OBD Plugin
- ↳ On-Screen Keyboard Plugin
- ↳ AppleTV Plugin
- ↳ ARDUINO Plugin
- ↳ Devices and Variables
- ↳ FINGSCAN
- ↳ Homematic Plugin
- ↳ homeAway - presence
- ↳ Hue Lights
- ↳ Archives
- ↳ Indigo Utilities
- ↳ INDIGOplotD
- ↳ Mother Plugin
- ↳ Network Scanner
- ↳ piBeacon
- ↳ Shelly Plugin
- ↳ startupAction Plugin
- ↳ uniFi-WiFi-AP
- ↳ VoiceReceiver
- ↳ kmarkley's plugins
- ↳ Korey’s Plugins
- ↳ Anthem-Rs232
- ↳ Apple Music Control
- ↳ Music Manager
- ↳ Spotify Control
- ↳ Viewsonic Projector Rs232
- ↳ VLC Control
- ↳ Kwijibo007’s Plugins
- ↳ Doorbird
- ↳ Monoprice 6 Zone Amp
- ↳ SSH Switch
- ↳ Samsung TV
- ↳ Mpoulson’s Plugins
- ↳ Ring Doorbell
- ↳ Mr.Slim Heat Pump
- ↳ NuHeat Heated Floors
- ↳ PurpleAir
- ↳ Nathan Williams' Plugins
- ↳ Nick's Plugins
- ↳ Autelis Jandy
- ↳ Autelis Somfy
- ↳ Hikvision Camera Alerts
- ↳ Honeywell Thermostat
- ↳ TED 5000
- ↳ Neil's Plugins
- ↳ Daikin Wifi Controller
- ↳ Solcast Solar Forecast
- ↳ Velux Active
- ↳ WLED LED Controller
- ↳ papamac’s plugins
- ↳ Virtual Garage Door
- ↳ Pi GPIO
- ↳ Perry the Cynic
- ↳ racarter's plugins
- ↳ Blink
- ↳ Heatmiser Neo
- ↳ Hive
- ↳ Netatmo Multi
- ↳ Sunsynk
- ↳ Tapo
- ↳ Texecom
- ↳ Tuya
- ↳ Watchdog
- ↳ raneil's corner
- ↳ rbdubz3's Plugins
- ↳ Smart Setpoints
- ↳ Sylvania Lightify
- ↳ Light Scenes
- ↳ RFXCOM
- ↳ TiVo Network Remote
- ↳ Roku Network Remote
- ↳ Niles Audio Zone Receiver
- ↳ Sharp TV Network Remote
- ↳ DomoPad Android Client
- ↳ Onkyo Receiver
- ↳ Plex Media Server Manager
- ↳ Google Assistant
- ↳ Ryan Buckner's Plugins
- ↳ Tomorrow.io Plugin
- ↳ SearchCz's Plugins
- ↳ Roomify
- ↳ Securify
- ↳ Simon’s Plug-ins
- ↳ Claude Skill
- ↳ Domio
- ↳ Home Intelligence
- ↳ MCP Lite
- ↳ Netro Irrigation
- ↳ Sofabaton
- ↳ UK Trains
- ↳ Broadlink Devices
- ↳ APC Metered Rack PDU
- ↳ Captain’s Recapitulation
- ↳ VTMikeL's plugins
- ↳ Auto Fan
- ↳ Auto Lights
- ↳ Security Spy Helper
- ↳ August Home
- ↳ Google Vision
- ↳ Just Add Power
- ↳ MCP Server
- ↳ WeatherSnoop
- ↳ WebDeck Software
- ↳ BAFControl
- ↳ WonderSlug's Plugins
- ↳ Bert's Plugins
- ↳ Indify
- ↳ Chameleon Plugins
- ↳ NEST Home
- ↳ iTravel
- ↳ LED Device Manager
- ↳ iFindStuff
- ↳ Bip's Plugins
- ↳ Homebridge Buddy
- ↳ Device Extensions Plugin
- ↳ HomeKit Bridge
- ↳ LCD Creator
- ↳ Room-O-Matic
- ↳ Scene Toggle
- ↳ Firstnibble
- ↳ indilinq
- ↳ Jacob Lindehoff's Plugins
- ↳ Kristian's Plugins
- ↳ Mission Machines' Plugins
- ↳ Nathan Sheldon Software
- ↳ Proxidyne
- ↳ Sean's Plugins
- ↳ Spencer's Plugins
- ↳ thechad.io
- ↳ Travis' Plugins
- ↳ Smartphone Radar
- ↳ DSC Alarm Plugin
- ↳ Yergey's Forum
- ↳ ZachBenz's Plugins
- ↳ RingForIndigo
- User Contributions
- ↳ User Plugins
- ↳ Open Source Plugins
- ↳ Adapters
- ↳ Alexa-Hue Bridge
- ↳ DIRECTV DVR Control
- ↳ Dynamic Control
- ↳ HassBridge
- ↳ Photo Frame
- ↳ Pushover
- ↳ Archives
- ↳ Rachio
- ↳ Security Camera
- ↳ Sonos
- ↳ Vera Bridge
- ↳ Yamaha RX
- ↳ 8 Channel Network Relay
- ↳ Python Scripts
- ↳ Apple Shortcuts
- ↳ Other Scripts
- ↳ Miscellaneous
- ↳ AppleScripts
- ↳ Archived Posts
- ↳ Switching to Indigo
- ↳ Vendor Announcements
- ↳ Help Wanted & Bounties
- ↳ How Do I...
- ↳ User Modifications
- ↳ Classifieds
- ↳ General Home Automation
- ↳ General Chat
- ↳ Finding Installers
- ↳ Installer Discussions
