I have upgraded the plugin to different versions but the problem remains. The Hue lights continue to work and I cant se any problem right efter the upgrade of the plug, the problems starts after a while.
Need some help if possible.
Hue Lights Error Unable to obtain list from the bridge# 0
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 438, in _error_catcher
yield
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 519, in read
data = self._fp.read(amt) if not fp_closed else b""
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 465, in read
s = self.fp.read(amt)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socket.py", line 705, in readinto
return self._sock.recv_into(b)
ConnectionResetError: [Errno 54] Connection reset by peer
During handling of the above exception, another exception occurred:
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 760, in generate
for chunk in self.raw.stream(chunk_size, decode_content=True):
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 576, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 512, in read
with self._error_catcher():
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/response.py", line 455, in _error_catcher
raise ProtocolError("Connection broken: %r" % e, e)
urllib3.exceptions.ProtocolError: ("Connection broken: ConnectionResetError(54, 'Connection reset by peer')", ConnectionResetError(54, 'Connection reset by peer'))
File "plugin.py", line 6163, in updateTheTypeList
retCode, responseData, errorsDict = self.commandToHub_HTTP( hubNumber, theType)
File "plugin.py", line 796, in commandToHub_HTTP
r = requests.get(command, timeout=kTimeout, headers={'Connection':'close'})
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/sessions.py", line 529, in request
resp = self.send(prep, **send_kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/sessions.py", line 687, in send
r.content
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 838, in content
self._content = b''.join(self.iter_content(CONTENT_CHUNK_SIZE)) or b''
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 763, in generate
raise ChunkedEncodingError(e)
requests.exceptions.ChunkedEncodingError: ("Connection broken: ConnectionResetError(54, 'Connection reset by peer')", ConnectionResetError(54, 'Connection reset by peer'))
