iTunes Play single track in playlist problem
Wizard Sleeve
Post by Wizard Sleeve »
Hi I'm trying to trigger a single random track in playlist when I walk in to my bathroom. It creates the "Indigo Single Track" playlist and drops a random track in to it. It plays for less than a second and then stops the player and removes the track again.
Am I doing something wrong?
Lee
Wizard Sleeve
Re: iTunes Play single track in playlist problem
Ok done a bit of messing around in iTunes and I have seen what's causing it but not a way to fix it.
If I crate a playlist that this will pull from and drop a locally downloaded track in it will play fine but what I want to do is play a track from Apple Music + with an online updating playlist. it seems your plugin could do it but it doesn't like something about the online playlists.
This is on MacOS:10.12.6 and iTunes 12.8.2.3.
Ill keep playing
Lee
