Alllllmost there...
Alllllmost there...
Thru a bunch of fits and starts, I'm inching closer to getting this to work. Scanning for Devices returns all of the AppleTV devices, both hardware and software. Once scanned, the data is being correctly updated in the Device. So far, so good. However I am unable to actually control the device at all. The ATV hardware is just not responding.
Pretty sure I've installed all the right pieces... Xcode, Python 3, and the special ATV stuff, but just doesn't seem to be working. I haven't edited any of the devices info.. including the overwrite PIN number which is set to the default 1234.
Any ideas or Suggestions?
Re: Alllllmost there...
Can you switch on debug?jltnol wrote:Thru a bunch of fits and starts, I'm inching closer to getting this to work. Scanning for Devices returns all of the AppleTV devices, both hardware and software. Once scanned, the data is being correctly updated in the Device. So far, so good. However I am unable to actually control the device at all. The ATV hardware is just not responding.
So not sure if this is all the info you need. I see nothing in the regular Indigo Log, so found the log in the Libray/ indigo... folder. In plugin config, I checked Threats for listing... Action commandos... Basic... Special debug for development. Let me know if you need others checked.
The plugin did find 3 other devices... one if which is an older ATV, and 2 that are computes, which may explain some of the error messages.
I deleted today's log, then re-started the plug in, then issued a simple toggle command Action Group for the ATV that shows up as Playing. The plugin is populating the indigo device with the right info...
Here's what in the log:
As always, thanks for taking the time to look into this.
21 16:43:46 logger enabled for THREADDEBUG ==> TEST ONLY
21 16:43:46 logger enabled for DEBUG ==> TEST ONLY
21 16:43:46 logger enabled for INFO ==> TEST ONLY
21 16:43:46 logger enabled for WARNING ==> TEST ONLY
2021-04-21 16:43:46.974 ERROR Plugin.__init__ logger enabled for ERROR ==> TEST ONLY
2021-04-21 16:43:46.974 CRITICAL Plugin.__init__ logger enabled for CRITICAL ==> TEST ONLY
21 16:43:46 path To python3 /usr/local/bin/python3
21 16:43:46 check for new devices every 10 minutes
21 16:43:47 start runConcurrentThread, initialized loop settings
21 16:43:47 in loop #1
21 16:43:53 === listenToDevices ip:192.168.5.102, (re)starting listener w cmd:[u'/usr/local/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', '-s', u'192.168.5.102', 'push_updates']
21 16:43:53 === listenToDevices ip:192.168.5.102, (re)started listener
21 16:43:53 === listenToDevices ip:192.168.5.102, newlines:{"result": "failure", "datetime": "2021-04-21T16:43:53.783118-05:00", "exception": "no service to connect to", "stacktrace": "Traceback (most recent call last):\n File \"/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py\", line 310, in appstart\n print(args.output(await _handle_command(args, abort_sem, loop)), flush=True)\n File \"/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py\", line 195, in _handle_command\n atv = await connect(config, loop, protocol=Protocol.MRP)\n File \"/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/__init__.py\", line 63, in connect\n service = config.main_service(protocol=protocol)\n File \"/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/conf.py\", line 112, in main_service\n raise exceptions.NoServiceError(\"no service to connect to\")\npyatv.exceptions.NoServiceError: no service to connect to\n"}
21 16:43:53 === listenToDevices ip:192.168.5.121, (re)starting listener w cmd:[u'/usr/local/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', '-s', u'192.168.5.121', 'push_updates']
21 16:43:53 === listenToDevices ip:192.168.5.121, (re)started listener
21 16:43:54 === listenToDevices ip:192.168.5.121, newlines:{"result": "failure", "datetime": "2021-04-21T16:43:54.305902-05:00", "exception": "no service to connect to", "stacktrace": "Traceback (most recent call last):\n File \"/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py\", line 310, in appstart\n print(args.output(await _handle_command(args, abort_sem, loop)), flush=True)\n File \"/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py\", line 195, in _handle_command\n atv = await connect(config, loop, protocol=Protocol.MRP)\n File \"/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/__init__.py\", line 63, in connect\n service = config.main_service(protocol=protocol)\n File \"/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/conf.py\", line 112, in main_service\n raise exceptions.NoServiceError(\"no service to connect to\")\npyatv.exceptions.NoServiceError: no service to connect to\n"}
21 16:43:54 === listenToDevices ip:192.168.5.13, (re)starting listener w cmd:[u'/usr/local/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', '-s', u'192.168.5.13', 'push_updates']
21 16:43:54 === listenToDevices ip:192.168.5.13, (re)started listener
21 16:43:54 === listenToDevices ip:192.168.5.134, (re)starting listener w cmd:[u'/usr/local/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', '-s', u'192.168.5.134', 'push_updates']
21 16:43:54 === listenToDevices ip:192.168.5.134, (re)started listener
21 16:43:55 === listenToDevices ip:192.168.5.134, newlines:{"result": "success", "datetime": "2021-04-21T16:43:55.346936-05:00", "power_state": "on"}
{"result": "success", "datetime": "2021-04-21T16:43:55.347795-05:00", "hash": "com.apple.avkit.7536.d9cf6e71", "media_type": "video", "device_state": "playing", "title": "Take Your Pills", "artist": null, "album": null, "genre": null, "total_time": 5263, "position": 149, "shuffle": "off", "repeat": "off", "app": "Netflix", "app_id": "com.netflix.Netflix"}
21 16:44:00 === listenToDevices ip:192.168.5.13, newlines:{"result": "failure", "datetime": "2021-04-21T16:43:59.812978-05:00", "error": "device_not_found"}
21 16:44:00 === listenToDevices ip:192.168.5.13, connection lost:{"result": "failure", "datetime": "2021-04-21T16:43:59.812978-05:00", "error": "device_not_found"}
21 16:44:02 execCommandToAppleTVCALLBACK command:[u'/usr/local/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvremote.py', '-i', u'', u'play_pause']
21 16:44:04 in loop #2
21 16:44:05 === listenToDevices ip:192.168.5.13, (re)starting listener w cmd:[u'/usr/local/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', '-s', u'192.168.5.13', 'push_updates']
21 16:44:05 === listenToDevices ip:192.168.5.13, (re)started listener
21 16:44:05 === listenToDevices ip:192.168.5.13, newlines:{"result": "failure", "datetime": "2021-04-21T16:44:05.453897-05:00", "exception": "no service to connect to", "stacktrace": "Traceback (most recent call last):\n File \"/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py\", line 310, in appstart\n print(args.output(await _handle_command(args, abort_sem, loop)), flush=True)\n File \"/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py\", line 195, in _handle_command\n atv = await connect(config, loop, protocol=Protocol.MRP)\n File \"/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/__init__.py\", line 63, in connect\n service = config.main_service(protocol=protocol)\n File \"/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/conf.py\", line 112, in main_service\n raise exceptions.NoServiceError(\"no service to connect to\")\npyatv.exceptions.NoServiceError: no service to connect to\n"}
21 16:44:14 in loop #3
How many Apple TV devices do you have?
you can exclude ip numbers from being scanned (eg the .13) in plugin / menu
I really only have 2 real Apple TV devices... one at 192.168.5 134 and one a 192.168.5. 13. Will work to exclude the others.
Can you power cycle the .13 Apple TV. ?
I power cycled the .13 device, had it playing, but the device still shows as device not found. I do find it curious that it found the 2nd AppleTV and created a "Device" with the right IP address, but now "device_not_found".
Could you delete dev .13. Then switch on debug and then scan for new devices.
And post plugin.log
And post plugin.log
Alllllmost there...
Also is the network slower to the .13? May be there is a time out?
could you also:
1. open terminal
2. paste: (you don't need the path to python when you open a terminal session. python3 should be in PATH)
then change channel on tv switch on / off ... you should see some output like:
1. open terminal
2. paste:
python3 '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py' -s 192.168.5.13 push_updatesthen change channel on tv switch on / off ... you should see some output like:
{"result": "success", "datetime": "2021-04-22T22:25:38.045732-05:00", "power_state": "off"}
{"result": "success", "datetime": "2021-04-22T22:25:38.046832-05:00", "hash": "F2550E9C-9937-46A7-8EF2-C9A06411AA7B", "media_type": "unknown", "device_state": "paused", "title": "CBS 11 News at 10PM", "artist": "CBS 11", "album": null, "genre": null, "total_time": 50400, "position": 47153, "shuffle": "off", "repeat": "off", "app": null, "app_id": "com.google.ios.youtubeunplugged"}
/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py:97: DeprecationWarning: The explicit passing of coroutine objects to asyncio.wait() is deprecated since Python 3.8, and scheduled for removal in Python 3.11.
await asyncio.wait(
{"result": "success", "datetime": "2021-04-22T22:26:05.956418-05:00", "power_state": "on"}
{"result": "success", "datetime": "2021-04-22T22:26:11.035532-05:00", "hash": "E930F477-C54B-49DD-96E9-D08BC8CBB834", "media_type": "unknown", "device_state": "paused", "title": "CBS 11 News at 10PM", "artist": "CBS 11", "album": null, "genre": null, "total_time": 50400, "position": 47153, "shuffle": "off", "repeat": "off", "app": null, "app_id": "com.google.ios.youtubeunplugged"}
{"result": "success", "datetime": "2021-04-22T22:26:11.051205-05:00", "hash": "E930F477-C54B-49DD-96E9-D08BC8CBB834", "media_type": "unknown", "device_state": "playing", "title": "CBS 11 News at 10PM", "artist": "CBS 11", "album": null, "genre": null, "total_time": 50400, "position": 47153, "shuffle": "off", "repeat": "off", "app": null, "app_id": "com.google.ios.youtubeunplugged"}
