lastCmd property not populating
agame
Post by agame »
I've been using your plugin with great success at two different window sets, using two generations of Fakro window openers.
i'm currently cleaning up control pages for the early generation openers, that only support the open/close/stop commands (and don't report status meaningfully).
So my intention was to use lastCmd property as a proxy - but the property does not appear to be populating (is blank).
Is this expected behaviour, or should the plugin be remembering the last command in this situation? (Nothing appears to update, regardless of whether I operate the window from an action against the plugin device, or directly on the native device.
Using version 1.03 .
howartp
Re: lastCmd property not populating
Post by howartp »
Apologies, I've just seen your post.
I'm on with plugins this weekend so i'll have a look.
Peter
Return to “Zwave Window Controller”
