I created a new ZWave Lock/Code Manager plugin Door Lock device.
I was trying to send some commands to set user PINs and I was seeing these messages in logs (XX's substituted for PIN values).
Z-Wave Lock/Code Manager Setting PIN for user 5 to: XXXXXX
Z-Wave sent "GAR-W Door Deadbolt" raw command [63 01 05 01 XX XX XX XX XX XX]
Z-Wave received "GAR-W Door Deadbolt" status update user code add failed (duplicate)
Z-Wave Lock/Code Manager Unknown lock status received: 34 [Node: 111] Also the "unknown status code" message is a bit disconcerting... Anyone seen that before?
I've used Indigo and ZWave Lock Manager on other Kwikset locks (not model 916) previously and had generally good results.
