send beep command Action not working
siclark
Post by siclark »
Hi Karl,
I am looking to take more advantage of pibeacon for item location and want to use the beep command. I have a nonda iHere, ZUS, beacon that is working and if I use the plugin menu I can get it to beep for the various durations, using an individual rPi or the closest.
However when I try to do this via an action nothing happens. Is this supposed to replicate the same command?
Simon.
Re: send beep command Action not working
Will check. Yes it should do it
siclark
Post by siclark »
Thanks Karl
v .492 should fix that
siclark
Post by siclark »
Thanks. That works now
siclark
Post by siclark »
Got 4x Nut3s coming tomorrow to set up and use for key location, with actions I can ask Alexa or Siri to beep our keys.
Return to “piBeacon”
