Brighten/Dim not functioning anymore
7rdr7
Post by 7rdr7 »
When I initially set up the LIFX plugin, I had my light switches programed that if they were held up or down, they would brighten or dim the LIFX bulbs. I tried it recently and it no longer functions. The following are the associated logs files:
Oct 28, 2020 at 12:43:39 PM
Trigger Occupancy - Main Floor Motion Detectors
Action Group Set Main Floor Occupancy ON
Virtual Devices sent "Main Floor Occupancy" on
Z-Wave received "Pool Probe" sensor update to 19.2 °C
Z-Wave received "Deck Door Light (Leave ON)" up button pressed
Trigger Deck Door Light ST ON Standard_White
LIFX sent "Deck Door Bulb" preset of set White Level to "50" and White Temperature to "3500" with duration of 2 seconds
LIFX sent "Deck Door Bulb" on with duration of 1.0 seconds
Trigger Deck Door Light ON status light
Trigger Backyard Lights Bulb ON - Reset Color
Z-Wave device "Deck Door Light (Leave ON)" parameter 8 changed to 33489050
Z-Wave received "Deck Door Light (Leave ON)" up button held down
Trigger Deck Door Light Brighten
LIFX sent "Deck Door Bulb" Brightening by 2 every 0.3 second(s)
LIFX Error StandardError detected in 'process_brighten_by_timer'. Line 504 has error: 'key powerLevel not found in dict'
Z-Wave received "Deck Door Light (Leave ON)" up button released
Trigger Deck Door Light Brighten Released
LIFX sent "Deck Door Bulb" stop brighten / dim
Z-Wave received "Deck Door Light (Leave ON)" energy total to 4.663 kWh
Z-Wave received "Deck Door Light (Leave ON)" power load to 2.9 W
Z-Wave received "Deck Door Light (Leave ON)" down button held down
Trigger Deck Door Light Dim
LIFX sent "Deck Door Bulb" Dimming by 2 every 0.3 second(s)
LIFX Error StandardError detected in 'process_dim_by_timer'. Line 696 has error: 'key powerLevel not found in dict'
Z-Wave received "Deck Door Light (Leave ON)" down button released
Trigger Deck Door Light Dim Released
Z-Wave received "Deck Door Light (Leave ON)" down button pressed
Z-Wave received "Deck Door Light (Leave ON)" status update is off
Trigger Deck Door Light - Reset
Trigger Deck Door Light ST OFF
LIFX sent "Deck Door Bulb" off with duration of 1.0 seconds
Trigger Deck Door Light OFF status light
Trigger Backyard Lights Bulb OFF - Reset Color
Z-Wave device "Deck Door Light (Leave ON)" parameter 8 changed to 33490857
Z-Wave received "Deck Door Light (Leave ON)" power load to 0.6 W
Detailed Logs:
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 E7 08 70 04 08 04 01 FF 00 9A 25 F0 C5
Z-Wave Debug RCVD setConfigVal: 06 (ACK)
Z-Wave Debug RCVD setConfigVal: 01 04 01 13 01 E8 (expecting callback)
Z-Wave Debug RCVD setConfigVal: 01 07 00 13 F0 00 00 06 1D (node ACK)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 E7 05 5B 03 98 82 02 52
Z-Wave Debug . . sceneActivateCmd2: node 231, type: 2, scene: 2
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 E7 05 5B 03 99 81 02 50
Z-Wave Debug . . sceneActivateCmd2: node 231, type: 1, scene: 2
Z-Wave Debug SENT requestRelayStatus: 01 09 00 13 E7 02 25 02 25 F1 F3
Z-Wave Debug RCVD requestRelayStatus: 06 (ACK)
Z-Wave Debug RCVD requestRelayStatus: 01 04 01 13 01 E8 (expecting callback)
Z-Wave Debug RCVD requestRelayStatus: 01 07 00 13 F1 00 00 11 0B (node ACK)
Z-Wave Debug waiting up to 3.0 seconds for module reply after sending request
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 E7 03 25 03 FF CF
Z-Wave Debug . . requestRelayStatus: node 231, endpoint None, value 255
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 00 25 F2 E6
Z-Wave Debug RCVD requestMeterLevel: 06 (ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 04 01 13 01 E8 (expecting callback)
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 F2 00 00 0E 17 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E7 0E 32 02 21 64 00 00 12 37 03 D6 00 00 12 37 A6
Z-Wave Debug . . requestMeterLevel: node 231, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 4.663 kWh (float: 4.663000)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 10 25 F3 F7
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 F3 00 00 0C 14 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E7 0A 32 02 21 34 00 00 00 1B 00 00 38
Z-Wave Debug . . requestMeterLevel: node 231, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 2.7 W (float: 2.700000)
Z-Wave received "Deck Door Light (Leave ON)" power load to 2.7 W
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 E7 05 5B 03 9A 82 01 53
Z-Wave Debug . . sceneActivateCmd2: node 231, type: 2, scene: 1
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 E7 05 5B 03 9B 81 01 51
Z-Wave Debug . . sceneActivateCmd2: node 231, type: 1, scene: 1
Z-Wave Debug SENT requestRelayStatus: 01 09 00 13 E7 02 25 02 25 F4 F6
Z-Wave Debug RCVD requestRelayStatus: 01 07 00 13 F4 00 00 09 16 (node ACK)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 00 25 F5 E1
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 F5 00 00 0B 15 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E7 0E 32 02 21 64 00 00 12 37 00 09 00 00 12 37 7A
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 10 25 F6 F2
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 F6 00 00 0A 17 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E7 0A 32 02 21 34 00 00 00 1D 00 00 3E
Z-Wave Debug . . requestMeterLevel: 2.9 W (float: 2.900000)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 E7 05 5B 03 9C 80 01 57
Z-Wave Debug . . sceneActivateCmd2: node 231, type: 0, scene: 1
Z-Wave Debug queueing energy request of "231 - Deck Door Light (Leave ON)" (activity detected)
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 E7 08 70 04 08 04 01 FF 07 A9 25 F7 F6
Z-Wave Debug RCVD setConfigVal: 01 07 00 13 F7 00 00 07 1B (node ACK)
Z-Wave Debug polling status of node "231 - Deck Door Light (Leave ON)" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 00 25 F8 EC
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 F8 00 00 07 14 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E7 0E 32 02 21 64 00 00 12 37 00 08 00 00 12 37 7B
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 10 25 F9 FD
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 F9 00 00 0A 18 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E7 0A 32 02 21 34 00 00 00 06 00 00 25
Z-Wave Debug . . requestMeterLevel: 0.6 W (float: 0.600000)
Schedule Deck Door Light - Reset (delayed action)
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 E7 03 25 01 FF 25 FA 06
Z-Wave Debug RCVD setRelayValue: 06 (ACK)
Z-Wave Debug RCVD setRelayValue: 01 04 01 13 01 E8 (expecting callback)
Z-Wave Debug RCVD setRelayValue: 01 07 00 13 FA 00 00 07 16 (node ACK)
Z-Wave sent "Deck Door Light (Leave ON)" on
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 00 25 FB EF
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 FB 00 00 07 17 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E7 0E 32 02 21 64 00 00 12 37 00 0E 00 00 12 37 7D
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E7 03 32 01 10 25 FC F8
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 FC 00 00 0B 1C (node ACK)
autolog
Re: Brighten/Dim not functioning anymore
Post by autolog »
Thanks for the report - it's a bug. :|
I can see what the issue is but will need ~48 hours to sort it (maybe less). :)
autolog
Post by autolog »
It was easier to fix than I had originally anticipated. :D
New pre-release is up on Github: Fix Dim / Brighten by Timer Bug
Tested and working for me, hope it does for you. :)
Return to “LIFX Controller”
