Glowmarkt CAD/IHD Plugin Released
neilk
Post by neilk »
Hi all,
I have now published this to the Plugin Store, and it seems very stable but it has only been tested by me. This version supports updates via the API which you can get with a "free" account from Glowmarkt, or for real time energy usage direct from your smart meter the MQTT version that requires you to purchase the Glowmarkt IHD/CAD that connects to your UK smart meter. You get real time electricity usage, and near real time cost and usage for electricity and gas. It utilises FlyingDivers excellent MQTT plugin that does the heavy lifting for MQTT.
https://github.com/neilkplugins/Glow-IH ... lugin/wiki for the documentation.
Any questions, problems or requests let me know. It also works incredibly well with the Grafana plugin, and I am also embedding the Grafana dials in my control page for energy usage.
Here is the ugly control page
Screenshot 2020-06-28 at 21.29.23.png (92.73 KiB) Viewed 5554 times
and my Grafana Dashboard (not all of it)
Screenshot 2020-06-28 at 21.36.31.png (305.86 KiB) Viewed 5554 times
Just adding some new functionality to the Octopus Energy plugin as well so that it calculates the best time to run a load for 30m, 1hr, 2hr, 3hr or 4hr to get the lowest rates and a new version will be published that also gets at your usage data.
Neil
neilk
Re: Glowmarkt CAD/IHD Plugin Released
Post by neilk »
https://github.com/neilkplugins/Glow-IH ... Plugin.zip
This version adds no new functionality but adds meaningful state labelling for the device states for each 30min Cost or Consumption status. The initial version each state was labelled "Electricity State" which with 48 of them was not helpful when trying to create control pages. In this version they appear as "Consumption from 00:00" etc, which is a compromise as the same states are used for Cost and Consumption data depending on the device configuration. Given this only impacts Trigger or Control Page state labels it is reasonable but open to other suggestions.
racarter
Post by racarter »
Hi Neil
Just to let you know I got my EDF smart meters fitted last week and signed up for a Glowmarkt account. My display arrived today and I've now got the plugin up and running. Thanks for all your efforts!
Alan
neilk
Post by neilk »
Alan,
Thanks for letting me know, I suspect you are user number 1 so please feel free to chip in with requests or I am sure you will find some quirks.
Regards,
Neil
neilk
Post by neilk »
Alan (or any other users),
I had an issue yesterday and I wonder if you have experienced it. The MQTT messages were not being consumed and I ended up with 40k+ messages, that flushed through when it restarted. I have only seen this once and wondered if you have seen anything similar.
Neil
racarter
Post by racarter »
Hi Neil
No, I've never seen that issue. The only one I have is occasional 1-2 minute bursts of
GlowmarktCAD Error Failed to complete updates for Glow device Glow Energy
but I assume that's just their servers not responding quickly enough (or at all) for a short while.
neilk
Post by neilk »
Alan,
Thanks, I recently had them push the agile screen (you have to request it) to my IHD and suspect that may have triggered the issue, I will also see if I can better trap that error as I see it occasionally as well and I think it may be a malformed MQTT payload, or at least one I don’t parse properly.
Neil
racarter
Post by racarter »
Hi Neil
Had a few of these today:
23 Oct 2020 at 09:41:48
GlowmarktCAD Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 236, in runConcurrentThread
File "plugin.py", line 313, in update
File "plugin.py", line 62, in refresh_daily_consumption_device
UnboundLocalError: local variable 'response' referenced before assignment
GlowmarktCAD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
neilk
Post by neilk »
Hi Alan,
I will take a look over the weekend, I had the same and suspect I am not catching an unexpected API response (or lack of one) correctly. I had some other weirdness late last night when my ZWave network went unresponsive and other plugins went crazy and I thought it may have been that so this is useful to know.
Neil
neilk
Post by neilk »
It looks as expected as the API had a couple of wobbles this morning and I don’t trap it correctly but will work a fix. I will need to keep a close eye on this on Saturday as the clocks go back as well as this will be uncharted territory for me and the energy API’s are known to be challenging, not to mention my novice skills :D
racarter
Post by racarter »
:D Good luck!
neilk
Post by neilk »
I have just pushed 0.0.13 to the plugin store that addresses the issue to trap and more elegantly recover from API refresh issue. This issue may surface in other API accesses, and I will review the remaining code, but this addresses the most frequent potential issue and once the clocks change tonight in case anything else is needed to be updated.
Neil
racarter
Post by racarter »
Thanks Neil - I’ll install it this afternoon.
Return to “Glow IHD/CAD Energy Monitor”
