I tried to search for this but there are too many words in the search. Here's what I'm getting:
Error plugin "EPS Homebridge.indigoPlugin" is missing file: /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/EPS Homebridge.indigoPlugin/Contents/Info.plist
Everything seems to be working correctly but this pops up every time the server is restarted. Any ideas?
HomeKit error
- FlyingDiver
Re: HomeKit error
Have you checked to see if that file is actually present?
Re: HomeKit error
I have, it does not exist. It's interesting because I'm not using HomeBridge, I'm using HokeKitBridge.
- FlyingDiver
Re: HomeKit error
Is the plugin wrapper there?
Is the old plugin in either "Plugins" or "Plugins (Disabled)"? If so, delete it.
Re: HomeKit error
There was one in both Plugin folders so I deleted the one in the active Plugin folder. I'll restart and see if that fixes it.
Re: HomeKit error
That did it! Thank you! Not sure why it was still in the Plugin folder, it's been a while since I made the switch to your newest Plugin.
