"Test" menu items in plugin
geeknz
Post by geeknz »
I have a Zipato RFID keypad and seems we're nearly there with setup. I've got the virtual device set up (actually I have two as the keypad identifies in 7.4.1. as both "Notification Sound" and "Home/Away Mode") but the only PIN-related items in my Plugin menu are as follows:
Test Set PIN
Test Clear PIN
Test Get PIN
and also
Test status response
Using these menus does nothing, whether or not the plugin is on Debug mode.
Did I miss something essential in the original setup? I can see the device as when I do Home/Away then hold RFID to keypad, it shows up as "User Code 0 is blank" and when I activate Tamper, it shows up in the log too.
howartp
Re: "Test" menu items in plugin
Post by howartp »
Hi
Ignore those test menu items; I must have forgotten to hide them.
There are Actions to set/get PINs, so Indigo > Actions > New > Zwave Lock Manager > Set PIN.
Pwter
geeknz
Post by geeknz »
Thanks for the pointer in the right direction - all good here now.
howartp
Post by howartp »
Excellent.
I've just fixed my local copy so next time I push an update, the menu items will go away.
