Using Shelly devices with the MQTT plugin
Espressomatic
Post by Espressomatic »
Is anyone working on a Shelly-specific plugin? MQTT has a lot of possibilities and supports a lot of messaging from a lot of very different products, but Shelly publishes details to directly integrate their products with anyone's platform. Cloud API, REST API, direct device-to-device API.
IMO, I won't ever waste my time flashing Tasmota on a SONOFF when Shelly has done things properly from the start. 4 switches arriving shortly along with some buttons to turn a pair of them into lamp-cord switches. H&T, Switch 2.5 and then their smoke detector later in the spring.
Introducing the Shims plugin
Espressomatic wrote:Is anyone working on a Shelly-specific plugin?
Why would you need one? Shelly does MQTT.
Re: Introducing the Shims plugin
Pre-release available - https://github.com/FlyingDiver/Indigo-S ... /tag/0.1.3
Minor changes to support Shelly native MQTT.
Changed commands sent to lower case. This is to accommodate Shelly devices that require lower case commands. See https://github.com/FlyingDiver/Indigo-Shims/issues/8 for specifics.
Tested with a Sonoff/Tasmota device and it seems to work fine.
Please test action commands from Indigo to relay type devices. Specifically on/off/toggle. That's the only thing that changed.
MarcoGT
Post by MarcoGT »
Will this plugin support all Shelly devices? I bought a Shelly switch to use with Alexa, but it would be fine to integrate it with Indigo
MarcoGT wrote:Will this plugin support all Shelly devices? I bought a Shelly switch to use with Alexa, but it would be fine to integrate it with Indigo
I really don't know anything about Shelly devices, other than they (at least some) do MQTT natively. If that's true, then I would expect you can use it with my MQTT plugins. If there are issues doing so, and I can fix them without breaking something else, I'll do so.
MarcoGT
Post by MarcoGT »
Ok fine.
I did a quick research and it seems that the dimmer (I bought the dimmer, not the switch) and it seems that it support MQTT
CliveS
Post by CliveS »
I have just received a Shelly 1PM and having spent all day trying to get my head around MQTT and failing so I just setup two Actions to turn on and turn off the Shelly, works fine. Also have a Shelly dimmer and so I will need to try and sort out MQTT but it just confuses me.
CliveS
MarcoGT
Post by MarcoGT »
How do you turn it on and off? Using MQTT?
Re: Using Shelly devices with the MQTT plugin
I moved the discussion of Shelly devices to a new thread.
Here's the docs for using MQTT with Shelly devices: https://shelly-api-docs.shelly.cloud/#reboot
siclark
Post by siclark »
Really interested in the Shelly 1 and the button to give hardwired control to lamps but also remote control them.
siclark
Post by siclark »
Except it's only for their switch and not their dimmer. Two buttons on it would be perfect.
CliveS
Post by CliveS »
MarcoGT wrote:How do you turn it on and off? Using MQTT?
I am using 2 actions that run either On or Off python scripts
# Shelly Turn Off
import urllib2
import socket
ShellyIP = "192.168.100.236"
TurnOn	 = "/relay/0?turn=on"
TurnOff  = "/relay/0?turn=off"
#url_cmd = "http://" + ShellyIP + TurnOn
url_cmd = "http://" + ShellyIP + TurnOff
indigo.server.log(u"Sending to Shelly at " + ShellyIP)
	response = urllib2.urlopen(url_cmd)
	response.read()
	response.close()
except socket.timeout:
	indigo.server.log(u"Timed out when talking to Shelly at " + ShellyIP)
except urllib2.URLError, e:
	if hasattr(e, 'reason'):
		indigo.server.log(u"Error: We failed to find Shelly at " + ShellyIP)
		indigo.server.log("Reason: " + str(e.reason))
	elif hasattr(e, 'code'):
		indigo.server.log(u"Error: The Shelly couldn\'t fulfill the request.")
		indigo.server.log("Error code: " + str(e.code))
	indigo.server.log(u"Sent to Shelly at " + ShellyIP)
FlyingDiver wrote:Here's the docs for using MQTT with Shelly devices: https://shelly-api-docs.shelly.cloud/#reboot
Yes, I have been staring at it all day but can't get my head around Mosquitto, MQTT plugin, Shims plugin and Shelly.
If anyone gets a Shelly and installs with these plugins please can you put a "how to" here (in idiot steps) and I will be eternally grateful
CliveS
siclark
Post by siclark »
I have always found The Hook Up to be very clear in his explanations.
https://www.youtube.com/watch?v=NjKK5ab0-Kk
As an alternative to shims, and as described in above video, you could also use nodered, which can do nodered to follow along with the above and use the indigo action nodered pluging / palette to control the devices
CliveS
Post by CliveS »
siclark wrote:I have always found The Hook Up to be very clear in his explanations.
Yes watched that also this afternoon but it is based around Home Assistant which seems to have a very large base of Shelly support, as for Node-Red I uninstalled that a few days ago as I now have the Alexa back working with the Echo Gen 1 so did not need it, not sure I would manage to get my head around it, would rather a step by step how to for FlyingDiver's MQTT and Shims plugins, once I get one switch setup I should be fine for others.
CliveS
Return to “MQTT”
