Use of FlyingDiver's plugins to switch tasmota sonoff device
wasimpson
Post by wasimpson »
I have been using GreenSky MQTT Bridge to control Tasmota Sonoff devices.
Unfortunately this has stopped working and i want to switch over to your plugins.
I have been looking at the forums but am at a loss.
Is there an idiots guide as to what and i i can do this?
Re: Use of FlyingDiver's plugins to switch tasmota sonoff de
The longer answer depends on what you actually want to be able to do. If you just want to publish messages to the device to control it, there are Actions for the Broker device to do that. If you want to create an Indigo device that represents the Tasmota device, that takes more work.
wasimpson
Post by wasimpson »
Thanks i had not seen the startup page.
Having played i still do not see how to link the tasmota sonoff switches as a shim
Just follow the steps in viewtopic.php?f=316&t=22783
That specific example is for a Wemos device, but Tasmota is about the same. Just detail differences in the topics and payloads.
If you still have problems, post the exact steps you've taken and describe what's not working as described in the other thread. It's hard to help you figure it out when we don't know where you're stuck.
wasimpson
Post by wasimpson »
Thanks for your help.
After a bit of trial and error i have all the Sonoff devices working OK
Return to “MQTT”
