Couple of issues with pibeacon...
forestfield
Post by forestfield »
Hi Karl,
I've just upgrade my pibeacon to 7.105.293 from a much older version, and I had a couple of issues.
a. I don't use any homeseer security (fear not - I have some reverse proxy's for internet access to homeseer). So in the 'master' config I have 'DIGEST, BASIC or no authentication' set to 'use do not use security...', and the 'userid and password both blank'. The plugin wouldn't set running until I entered a dummy username and password. Looks like the code in plugin.py around line 8787ish - perhaps this should 'break' if no security is set?
        while True:
            if self.userIdOfServer !="" and self.passwordOfServer !="" : break
            self.indiLOG.log(20, u"userid or password not configured in config")
            self.sleep(20)
b. Had some problems with exim! Eventually tracked this down to line 1425ish. of master.py
os.system("sudo chown -R  pi:pi "+G.logDir)
I think this is a hangover from when the logFile was in /run/..., and the line should be something like
os.system("sudo chown -R  pi:pi "+G.logDir+"piBeacon.log")
Otherwise, thanks for a v. useful plugin; I know have 6 beacons running and can locate my keyring to a room! (More seriously I use it as presence detection to set Home/Away automatically!
-- Paul --
Re: Couple of issues with pibeacon...
1. that IF is a crude way of check if anything is configured, can change that.
... as i have not ventured in to "no security" is
add:
and if authentication !="none"  # other options: digest or basic
should doit?
2. s.system("sudo chown -R pi:pi "+G.logDir) should be removed, was ok when log file was in pibeacon run directory. Will remove that one.
and thanks for the useful feedback
forestfield
My pleasure to have helped.
-- Paul --
will be fixed tomorrow.
posted new version with those fixes ... .295
forestfield
Hi Karl,
I upgraded to 7.109.303, and I still have problems...
1. The plugin still gets stuck in the authentication loop. In your master.py you have
if self.userIdOfServer !="" and self.passwordOfServer !=""  and self.pluginPrefs.get(u"authentication", u"digest") != "none": break
I changed it to
if (self.userIdOfServer !="" and self.passwordOfServer !="")  or self.pluginPrefs.get(u"authentication", u"digest") == "none": break
and this seems to work for me.
2. Once I got the server started I was getting all sorts of timeouts and failures from my pibeacons. I *think* this is because the latest version of the pibeacon code has
import serial
in master.py (and some others), but there's no serial module in the plugin's pi directory to upload so mater.py doesn't't start properly
I've just reverted to 7.105.293 and I think I'm back back to normal operation - i.e 4/7 beacons running correctly, still have 3/7 to reload/restart
Regards
-- Paul --
I am out until Tuesday next week. Then I will be spending time on get things straightened out.
Serial should be part of std python
Could you do
ssh pi@....
python
Import serial
exit()
You should not get an error message.
it looks as if your ssd does not have serial installed.
I checked my RPIs they all have serial installed.
you could do :
ssh pi@..
sudo apt-get install python-serial
that should do it.
I will add to master.py in the next release:
  import serial
except:
  os.system("sudo apt-get install python-serial")
to make sure your ssd has serial installed.
forestfield
Hi Karl,
The serial package isn't installed on any of my (7) pibeacons, or (6) raspberry pis! (The latter are used for other things). They're all running buster, and have all been upgraded from jessie/wheezy or whatever came before these. Maybe serial wasn't in older pythons, and doesn't get installed as the o/s is upgraded.
i.e.
ssh pibeacon3
Warning: No xauth data; using fake authentication data for X11 forwarding.
Linux pibeacon3 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
No mail.
Last login: Tue Aug 20 16:37:14 2019 from 10.100.101.12
paulw@pibeacon3:~$ python
Python 2.7.16 (default, Apr  6 2019, 01:42:57)
[GCC 8.2.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import serial
  File "<stdin>", line 1, in <module>
ImportError: No module named serial
Did you use one of my preconfigured ssd or did you start from a fresh raw image directly from the rpi site?
forestfield
Would almost certainly have been a raspberry pi image - since I had the pi-zeros before pibeacon.
Ok. I installed serial on my ssd images published for download.
You have to do
sudo apt-get install serial-python
Then everything should work.
Return to “piBeacon”
