RPIs constantly cycling, no iBeacons detected
kmarkley
Post by kmarkley »
Hi Karl.
Since upgrading to latest plugin release (and skipping an unknown number of intermediate releases), all my RPIs are constantly cycling. As in:
up
expired
IPconnection and BLE down
up
expired
Additionally, no iBeacons are ever detected, even if I set to accept all new iBeacons. I haven't seen anything suspicious in the plugin logfile.
When I ssh to the RPI, I can see that almost all the files have been recently updated:
$ ls -l ~/pibeacon
total 2124
-rwxrwxrwx 1 pi pi   1938 Jun 17 19:50 actions.py
-rwxrwxrwx 1 pi pi  19925 Jun 17 19:50 amg88xx.py
-rwxrwxrwx 1 pi pi  64587 Jun 17 19:50 apds9960.py
-rwxrwxrwx 1 pi pi  18156 Jun 17 19:50 as3935.py
-rwxrwxrwx 1 pi pi  22403 Jun 17 19:50 as726x.py
-rw-rw-rw- 1 pi pi   3615 Jun 17 18:59 beacon_ExistingHistory
-rwxrwxrwx 1 pi pi  41464 Jun 17 19:50 beaconloop.py
-rw-rw-rw- 1 pi pi   2036 Jun 17 20:26 beacon_parameters
-rwxrwxrwx 1 pi pi  11391 Jun 17 19:50 BLEconnect.py
-rwxrwxrwx 1 pi pi  19329 Jun 17 19:50 BLEsensor.py
-rwxrwxrwx 1 pi pi  35107 Jun 17 19:50 bme680.py
-rwxrwxrwx 1 pi pi  31084 Jun 17 19:50 bno055.py
-rwxrwxrwx 1 pi pi   4321 Jun 17 19:50 callbeacon.py
-rwxrwxrwx 1 pi pi  19863 Jun 17 19:50 ccs811.py
-rwxrwxrwx 1 pi pi    804 Feb 25 19:03 checkLogfile.py
-rwxrwxrwx 1 pi pi   1096 Jun 17 19:50 convert.py
-rwxrwxrwx 1 pi pi   1453 Jun 17 19:50 copyToTemp.py
-rwxrwxrwx 1 pi pi   8184 Jun 17 19:50 DHT.py
-rwxrwxrwx 1 pi pi   8149 Jun 17 19:50 displayDistance.py
drwxrwxrwx 2 pi pi   4096 Jun  7  2017 displayfiles
-rwxrwxrwx 1 pi pi  75914 Jun 17 19:50 display.py
-rwxrwxrwx 1 pi pi    210 Jun 17 20:29 doGPIOatStartup.py
<<--SNIP-->>
But there are definitely errors in the RPI log:
$ tail -F /var/log/piBeacon.log
20190617-20:29:12 INPUTgpio       L:-1= starting setup sensors
20190617-20:29:12 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190617-20:29:12 Wire18B20       L:-1= error in Line 513 has error=global name 'wifiIP' is not defined
20190617-20:29:12 master          L:-1= error in Line 513 has error=global name 'wifiIP' is not defined
20190617-20:29:22 master          L:-1= error in Line 513 has error=global name 'wifiIP' is not defined
20190617-20:29:22 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wifiIP >><<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190617-20:29:23 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190617-20:29:23 master          L:-1=  DNS server reachable at:172.23.2.1
20190617-20:29:23 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
FWIW, I'm seeing the same behavior in 4 different ZeroW's connected by wifi (one of which also has 1-wire sensors). Everything worked as expected for a year or more before yesterday.
I'd appreciate any help to figure this out.
Thanks.
Re: RPIs constantly cycling, no iBeacons detected
fixed in release .286
kmarkley
Post by kmarkley »
Thanks Karl. Unfortunately I'm still having issues.
20190618-07:11:14 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190618-07:11:26 master          L:-1= writing new callbeacon.py file
20190618-07:11:29 master          L:-1= started:INPUTgpio.py
20190618-07:11:29 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190618-07:11:30 INPUTgpio       L:-1= starting INPUTgpio program
20190618-07:11:30 INPUTgpio       L:-1= starting setup sensors
20190618-07:11:30 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190618-07:11:30 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:11:30 Wire18B20       L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:11:40 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:11:40 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1130 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:842 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:146774 (143.3 KiB)  TX bytes:164991 (161.1 KiB)']<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190618-07:11:41 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:11:41 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:11:41 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190618-07:11:41 master          L:-1= U.getIPNumberMaster bad IP number ...  ipHostname >>['172.23.2.60']<<  old from file ipAddressRead>>172.23.2.60<< not in sync with ifconfig output: wlan0IP>>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1130 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:842 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:146774 (143.3 KiB)  TX bytes:164991 (161.1 KiB)']<<;	eth0IP>><<
20190618-07:11:46 master          L:-1=  master no ip number working, trying again, retcode=2
20190618-07:11:46 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:11:56 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:11:56 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1143 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:853 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:148104 (144.6 KiB)  TX bytes:168529 (164.5 KiB)']<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190618-07:11:56 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:11:56 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:11:56 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190618-07:11:56 master          L:-1= U.getIPNumberMaster bad IP number ...  ipHostname >>['172.23.2.60']<<  old from file ipAddressRead>>172.23.2.60<< not in sync with ifconfig output: wlan0IP>>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1143 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:853 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:148104 (144.6 KiB)  TX bytes:168529 (164.5 KiB)']<<;	eth0IP>><<
20190618-07:12:01 master          L:-1=  master no ip number working, trying again, retcode=2
20190618-07:12:01 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:12 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:12 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1157 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:865 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:149160 (145.6 KiB)  TX bytes:172181 (168.1 KiB)']<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190618-07:12:12 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:12:12 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:12:12 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190618-07:12:12 master          L:-1= U.getIPNumberMaster bad IP number ...  ipHostname >>['172.23.2.60']<<  old from file ipAddressRead>>172.23.2.60<< not in sync with ifconfig output: wlan0IP>>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1157 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:865 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:149160 (145.6 KiB)  TX bytes:172181 (168.1 KiB)']<<;	eth0IP>><<
20190618-07:12:17 master          L:-1=  master no ip number working, trying again, retcode=2
20190618-07:12:17 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:27 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:27 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1172 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:876 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:150899 (147.3 KiB)  TX bytes:175719 (171.6 KiB)']<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190618-07:12:27 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:12:27 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:12:28 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190618-07:12:28 master          L:-1= U.getIPNumberMaster bad IP number ...  ipHostname >>['172.23.2.60']<<  old from file ipAddressRead>>172.23.2.60<< not in sync with ifconfig output: wlan0IP>>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1172 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:876 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:150899 (147.3 KiB)  TX bytes:175719 (171.6 KiB)']<<;	eth0IP>><<
20190618-07:12:33 master          L:-1=  master no ip number working, trying again, retcode=2
20190618-07:12:33 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:43 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:43 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1189 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:887 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:152517 (148.9 KiB)  TX bytes:179257 (175.0 KiB)']<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190618-07:12:43 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:12:43 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:12:43 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190618-07:12:43 master          L:-1= U.getIPNumberMaster bad IP number ...  ipHostname >>['172.23.2.60']<<  old from file ipAddressRead>>172.23.2.60<< not in sync with ifconfig output: wlan0IP>>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1189 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:887 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:152517 (148.9 KiB)  TX bytes:179257 (175.0 KiB)']<<;	eth0IP>><<
20190618-07:12:48 master          L:-1=  master no ip number working, trying again, retcode=2
20190618-07:12:48 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:58 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:12:58 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1207 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:900 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:154351 (150.7 KiB)  TX bytes:183771 (179.4 KiB)']<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190618-07:12:59 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:12:59 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:12:59 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190618-07:12:59 master          L:-1= U.getIPNumberMaster bad IP number ...  ipHostname >>['172.23.2.60']<<  old from file ipAddressRead>>172.23.2.60<< not in sync with ifconfig output: wlan0IP>>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1207 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:900 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:154351 (150.7 KiB)  TX bytes:183771 (179.4 KiB)']<<;	eth0IP>><<
20190618-07:13:04 master          L:-1=  master no ip number working, trying again, retcode=2
20190618-07:13:04 master          L:-1=  master no ip number working, giving up
20190618-07:13:05 master          L:-1= starting web server : port 80 for status
20190618-07:13:07 installLibs     L:-1=  installLibs starting
20190618-07:13:07 installLibs     L:-1=  installLibs no opsys upgrade requested
20190618-07:13:07 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190618-07:13:07 installLibs     L:-1= ==== libraries install finished
20190618-07:13:09 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190618-07:13:09 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190618-07:13:09 beaconloop      L:-1= (re)starting bluetooth
20190618-07:13:10 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:13:10 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:13:10 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190618-07:13:10 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190618-07:13:10 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:13:10 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190618-07:13:10 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190618-07:13:10 beaconloop      L:-1= BLE start returned:
hci0:	Type: BR/EDR  Bus: UART
	BD Address: B8:27:EB:1B:B3:BF  ACL MTU: 1021:8  SCO MTU: 64:1
	UP RUNNING
	RX bytes:2005126 acl:0 sco:0 events:54868 errors:0
	TX bytes:9829 acl:0 sco:0 commands:479 errors:0
20190618-07:13:10 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190618-07:13:10 beaconloop      L:-1= ble thread started
20190618-07:13:10 beaconloop      L:-1= starting loop
20190618-07:13:10 beaconloop      L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:13:20 master          L:-1= error in Line 514 has error=global name 'wlIP' is not defined
20190618-07:13:21 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190618-07:13:21 master          L:-1=  DNS server reachable at:172.23.2.1
20190618-07:13:21 master          L:-1= U.getIPNumberMaster bad IP number ...  ipHostname >>['172.23.2.60']<<  old from file ipAddressRead>>172.23.2.60<< not in sync with ifconfig output: wlan0IP>>['wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:4c:40  \n          ', '172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0\n          inet6 addr: fe80::7cce:a90e:641:76af/64 Scope:Link\n          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1\n          RX packets:1251 errors:0 dropped:0 overruns:0 frame:0\n          TX packets:938 errors:0 dropped:0 overruns:0 carrier:0\n          collisions:0 txqueuelen:1000 \n          RX bytes:158097 (154.3 KiB)  TX bytes:192614 (188.0 KiB)']<<;	eth0IP>><<
20190618-07:13:21 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
kmarkley
Post by kmarkley »
Hi Karl. Just following up.
My RPIs are still constantly cycling as in the log above. Any idea what might be wrong?
Thanks.
sorry for that. I hope that one is finally fixed:
check v .288
kmarkley
Post by kmarkley »
Thanks Karl.
That seems to have fixed the actual error messages. However, I am still not detecting any beacons and the rpi seems to be 'restarting' every minute or so thinking the IP has changed (it hasn't).
$ tail -F /var/log/piBeacon.log | grep restarting
20190620-10:19:04 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-10:19:56 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
I need to know your config if wifi / ethernet setup
what is in config
Screen Shot 2019-06-20 at 12.47.51.png (12.47 KiB) Viewed 4597 times
and in RPI device edit
Screen Shot 2019-06-20 at 12.48.22.png (12.09 KiB) Viewed 4597 times
they are indentical, but the device edit will overwrite the config, but only when you edit the device at least once (done this way so that there is a default when a new device gets added)
kmarkley
Post by kmarkley »
I have set "ethernet cable(eth0) active" to "off" and "WiFi(wlan0) active" to "ON, use wlan0 IP#" in both places. These seemed like the correct settings given that the RPI Zeros don't even have an ethernet connection.
After upgrading plugin, these were all set to blank. I changed them when I was first trying to fix the problem.
will check this afternoon.
And could you post:
ifconfig
hostname -i
kmarkley
Post by kmarkley »
$ ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:24173 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24173 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5234076 (4.9 MiB)  TX bytes:5234076 (4.9 MiB)
          inet addr:172.23.2.60  Bcast:172.23.2.255  Mask:255.255.255.0
          RX packets:110601 errors:0 dropped:34 overruns:0 frame:0
          TX packets:75931 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:19950106 (19.0 MiB)  TX bytes:9263795 (8.8 MiB)
$ hostname -i
127.0.1.1
$ hostname --all-ip-addresses
172.23.2.60
(was "hostname -I" not -i )
anyway could you post :
tail -500 /var/log/piBeacon.log
and
cd pibeacon
cat parameters
(remove userid and passwords.. only nee to see the lines w wifiEth
  "wifiEth": {
    "eth0": {
      "on": "dontChange",
      "useIP": "use"
    "wlan0": {
      "on": "dontChange",
      "useIP": "useIf"
kmarkley
Post by kmarkley »
Here you go:
$ cat pibeacon/parameters
  <<<snip>>>
  "wifiEth": {
    "eth0": {
      "on": "off",
      "useIP": "doNotUse"
    "wlan0": {
      "on": "on",
      "useIP": "use"
$ tail -500 /var/log/piBeacon.log
20190620-14:32:58 beaconloop      L:-1= ble thread started
20190620-14:32:58 beaconloop      L:-1= starting loop
20190620-14:33:00 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:33:01 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:33:01 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:33:12 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:33:12 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:33:12 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:33:12 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:33:12 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:33:25 master          L:-1= writing new callbeacon.py file
20190620-14:33:28 master          L:-1= started:INPUTgpio.py
20190620-14:33:28 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:33:29 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:33:29 INPUTgpio       L:-1= starting setup sensors
20190620-14:33:33 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:33:43 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:33:43 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:33:43 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:33:43 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:33:43 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:33:45 master          L:-1= starting web server : port 80 for status
20190620-14:33:45 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:33:45 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:33:46 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:33:47 receiveCommands L:-1= started, listening to port: 9999
20190620-14:33:49 installLibs     L:-1=  installLibs starting
20190620-14:33:49 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:33:49 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:33:49 installLibs     L:-1= ==== libraries install finished
20190620-14:33:51 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:33:51 beaconloop      L:-1= (re)starting bluetooth
20190620-14:33:52 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:33:52 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:33:52 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:33:52 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:33:52 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:272755303 acl:0 sco:0 events:7438824 errors:0
	TX bytes:1446029 acl:0 sco:0 commands:76159 errors:0
20190620-14:33:52 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:33:52 beaconloop      L:-1= ble thread started
20190620-14:33:52 beaconloop      L:-1= starting loop
20190620-14:33:55 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:33:55 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:33:55 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:34:06 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:34:06 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:34:06 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:34:06 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:34:06 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:34:19 master          L:-1= writing new callbeacon.py file
20190620-14:34:22 master          L:-1= started:INPUTgpio.py
20190620-14:34:22 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:34:23 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:34:23 INPUTgpio       L:-1= starting setup sensors
20190620-14:34:27 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:34:37 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:34:37 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:34:37 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:34:37 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:34:37 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:34:39 master          L:-1= starting web server : port 80 for status
20190620-14:34:39 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:34:39 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:34:41 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:34:41 receiveCommands L:-1= started, listening to port: 9999
20190620-14:34:43 installLibs     L:-1=  installLibs starting
20190620-14:34:43 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:34:43 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:34:43 installLibs     L:-1= ==== libraries install finished
20190620-14:34:45 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:34:45 beaconloop      L:-1= (re)starting bluetooth
20190620-14:34:46 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:34:46 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:34:46 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:34:46 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:34:46 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:272844505 acl:0 sco:0 events:7441324 errors:0
	TX bytes:1446864 acl:0 sco:0 commands:76203 errors:0
20190620-14:34:46 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:34:46 beaconloop      L:-1= ble thread started
20190620-14:34:46 beaconloop      L:-1= starting loop
20190620-14:34:49 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:34:49 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:34:49 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:35:00 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:35:00 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:35:00 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:35:00 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:35:01 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:35:14 master          L:-1= writing new callbeacon.py file
20190620-14:35:16 master          L:-1= started:INPUTgpio.py
20190620-14:35:16 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:35:18 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:35:18 INPUTgpio       L:-1= starting setup sensors
20190620-14:35:21 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:35:31 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:35:31 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:35:31 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:35:31 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:35:31 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:35:33 master          L:-1= starting web server : port 80 for status
20190620-14:35:33 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:35:33 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:35:35 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:35:35 receiveCommands L:-1= started, listening to port: 9999
20190620-14:35:37 installLibs     L:-1=  installLibs starting
20190620-14:35:37 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:35:37 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:35:37 installLibs     L:-1= ==== libraries install finished
20190620-14:35:39 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:35:39 beaconloop      L:-1= (re)starting bluetooth
20190620-14:35:40 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:35:40 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:35:40 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:35:40 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:35:40 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:272935788 acl:0 sco:0 events:7443878 errors:0
	TX bytes:1447699 acl:0 sco:0 commands:76247 errors:0
20190620-14:35:40 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:35:40 beaconloop      L:-1= ble thread started
20190620-14:35:40 beaconloop      L:-1= starting loop
20190620-14:35:43 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:35:43 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:35:43 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:35:54 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:35:54 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:35:54 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:35:55 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:35:55 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:36:08 master          L:-1= writing new callbeacon.py file
20190620-14:36:10 master          L:-1= started:INPUTgpio.py
20190620-14:36:11 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:36:12 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:36:12 INPUTgpio       L:-1= starting setup sensors
20190620-14:36:15 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:36:25 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:36:25 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:36:25 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:36:25 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:36:26 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:36:27 master          L:-1= starting web server : port 80 for status
20190620-14:36:27 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:36:27 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:36:29 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:36:29 receiveCommands L:-1= started, listening to port: 9999
20190620-14:36:31 installLibs     L:-1=  installLibs starting
20190620-14:36:31 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:36:31 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:36:31 installLibs     L:-1= ==== libraries install finished
20190620-14:36:33 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:36:33 beaconloop      L:-1= (re)starting bluetooth
20190620-14:36:34 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:36:34 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:36:34 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:36:34 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:36:34 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273021220 acl:0 sco:0 events:7446281 errors:0
	TX bytes:1448534 acl:0 sco:0 commands:76291 errors:0
20190620-14:36:34 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:36:34 beaconloop      L:-1= ble thread started
20190620-14:36:34 beaconloop      L:-1= starting loop
20190620-14:36:37 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:36:37 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:36:37 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:36:48 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:36:48 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:36:48 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:36:49 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:36:49 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:37:02 master          L:-1= writing new callbeacon.py file
20190620-14:37:04 master          L:-1= started:INPUTgpio.py
20190620-14:37:05 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:37:06 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:37:06 INPUTgpio       L:-1= starting setup sensors
20190620-14:37:09 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:37:19 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:37:19 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:37:19 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:37:19 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:37:20 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:37:21 master          L:-1= starting web server : port 80 for status
20190620-14:37:22 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:37:22 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:37:23 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:37:23 receiveCommands L:-1= started, listening to port: 9999
20190620-14:37:25 installLibs     L:-1=  installLibs starting
20190620-14:37:25 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:37:25 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:37:25 installLibs     L:-1= ==== libraries install finished
20190620-14:37:27 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:37:27 beaconloop      L:-1= (re)starting bluetooth
20190620-14:37:28 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:37:28 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:37:28 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:37:28 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:37:28 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273113715 acl:0 sco:0 events:7448872 errors:0
	TX bytes:1449369 acl:0 sco:0 commands:76335 errors:0
20190620-14:37:28 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:37:28 beaconloop      L:-1= ble thread started
20190620-14:37:28 beaconloop      L:-1= starting loop
20190620-14:37:31 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:37:32 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:37:32 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:37:42 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:37:42 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:37:42 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:37:43 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:37:43 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:37:56 master          L:-1= writing new callbeacon.py file
20190620-14:37:58 master          L:-1= started:INPUTgpio.py
20190620-14:37:58 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:38:00 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:38:00 INPUTgpio       L:-1= starting setup sensors
20190620-14:38:03 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:38:13 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:38:13 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:38:13 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:38:13 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:38:13 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:38:15 master          L:-1= starting web server : port 80 for status
20190620-14:38:15 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:38:15 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:38:17 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:38:17 receiveCommands L:-1= started, listening to port: 9999
20190620-14:38:19 installLibs     L:-1=  installLibs starting
20190620-14:38:19 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:38:19 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:38:19 installLibs     L:-1= ==== libraries install finished
20190620-14:38:21 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:38:21 beaconloop      L:-1= (re)starting bluetooth
20190620-14:38:22 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:38:22 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:38:22 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:38:22 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:38:22 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273190514 acl:0 sco:0 events:7451041 errors:0
	TX bytes:1450204 acl:0 sco:0 commands:76379 errors:0
20190620-14:38:22 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:38:22 beaconloop      L:-1= ble thread started
20190620-14:38:22 beaconloop      L:-1= starting loop
20190620-14:38:25 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:38:25 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:38:25 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:38:36 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:38:36 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:38:36 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:38:36 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:38:36 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:38:49 master          L:-1= writing new callbeacon.py file
20190620-14:38:52 master          L:-1= started:INPUTgpio.py
20190620-14:38:52 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:38:53 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:38:53 INPUTgpio       L:-1= starting setup sensors
20190620-14:38:57 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:39:07 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:39:07 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:39:07 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:39:07 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:39:07 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:39:09 master          L:-1= starting web server : port 80 for status
20190620-14:39:09 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:39:09 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:39:11 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:39:11 receiveCommands L:-1= started, listening to port: 9999
20190620-14:39:13 installLibs     L:-1=  installLibs starting
20190620-14:39:13 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:39:13 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:39:13 installLibs     L:-1= ==== libraries install finished
20190620-14:39:15 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:39:15 beaconloop      L:-1= (re)starting bluetooth
20190620-14:39:16 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:39:16 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:39:16 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:39:16 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:39:16 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273265355 acl:0 sco:0 events:7453154 errors:0
	TX bytes:1451039 acl:0 sco:0 commands:76423 errors:0
20190620-14:39:16 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:39:16 beaconloop      L:-1= ble thread started
20190620-14:39:16 beaconloop      L:-1= starting loop
20190620-14:39:19 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:39:19 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:39:19 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:39:30 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:39:30 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:39:30 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:39:30 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:39:30 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:39:43 master          L:-1= writing new callbeacon.py file
20190620-14:39:46 master          L:-1= started:INPUTgpio.py
20190620-14:39:46 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:39:47 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:39:47 INPUTgpio       L:-1= starting setup sensors
20190620-14:39:51 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:40:01 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:40:01 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:40:01 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:40:01 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:40:01 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:40:03 master          L:-1= starting web server : port 80 for status
20190620-14:40:03 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:40:03 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:40:05 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:40:05 receiveCommands L:-1= started, listening to port: 9999
20190620-14:40:07 installLibs     L:-1=  installLibs starting
20190620-14:40:07 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:40:07 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:40:07 installLibs     L:-1= ==== libraries install finished
20190620-14:40:09 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:40:09 beaconloop      L:-1= (re)starting bluetooth
20190620-14:40:10 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:40:10 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:40:10 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:40:10 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:40:10 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273354416 acl:0 sco:0 events:7455666 errors:0
	TX bytes:1451874 acl:0 sco:0 commands:76467 errors:0
20190620-14:40:10 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:40:10 beaconloop      L:-1= ble thread started
20190620-14:40:10 beaconloop      L:-1= starting loop
20190620-14:40:13 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:40:13 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:40:13 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:40:24 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:40:24 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:40:24 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:40:25 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:40:25 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:40:38 master          L:-1= writing new callbeacon.py file
20190620-14:40:40 master          L:-1= started:INPUTgpio.py
20190620-14:40:40 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:40:42 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:40:42 INPUTgpio       L:-1= starting setup sensors
20190620-14:40:45 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:40:55 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:40:55 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:40:55 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:40:55 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:40:56 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:40:57 master          L:-1= starting web server : port 80 for status
20190620-14:40:57 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:40:57 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:40:59 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:40:59 receiveCommands L:-1= started, listening to port: 9999
20190620-14:41:01 installLibs     L:-1=  installLibs starting
20190620-14:41:01 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:41:01 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:41:01 installLibs     L:-1= ==== libraries install finished
20190620-14:41:03 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:41:03 beaconloop      L:-1= (re)starting bluetooth
20190620-14:41:04 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:41:04 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:41:04 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:41:04 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:41:04 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273441372 acl:0 sco:0 events:7458094 errors:0
	TX bytes:1452709 acl:0 sco:0 commands:76511 errors:0
20190620-14:41:04 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:41:04 beaconloop      L:-1= ble thread started
20190620-14:41:04 beaconloop      L:-1= starting loop
20190620-14:41:07 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:41:07 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:41:07 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:41:18 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:41:18 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:41:18 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:41:18 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:41:19 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:41:32 master          L:-1= writing new callbeacon.py file
20190620-14:41:34 master          L:-1= started:INPUTgpio.py
20190620-14:41:34 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:41:35 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:41:36 INPUTgpio       L:-1= starting setup sensors
20190620-14:41:39 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:41:49 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:41:49 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:41:49 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:41:49 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:41:49 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:41:51 master          L:-1= starting web server : port 80 for status
20190620-14:41:51 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:41:51 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:41:53 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:41:53 receiveCommands L:-1= started, listening to port: 9999
20190620-14:41:55 installLibs     L:-1=  installLibs starting
20190620-14:41:55 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:41:55 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:41:55 installLibs     L:-1= ==== libraries install finished
20190620-14:41:57 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:41:57 beaconloop      L:-1= (re)starting bluetooth
20190620-14:41:58 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:41:58 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:41:58 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:41:58 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:41:58 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273524978 acl:0 sco:0 events:7460438 errors:0
	TX bytes:1453544 acl:0 sco:0 commands:76555 errors:0
20190620-14:41:58 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:41:58 beaconloop      L:-1= ble thread started
20190620-14:41:58 beaconloop      L:-1= starting loop
20190620-14:42:01 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:42:01 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:42:01 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:42:12 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:42:12 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:42:12 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:42:13 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:42:13 master          L:-1= --- restarting ---   changed ip number, ie wifi was switched off with eth0 present
20190620-14:42:26 master          L:-1= writing new callbeacon.py file
20190620-14:42:28 master          L:-1= started:INPUTgpio.py
20190620-14:42:28 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-14:42:30 INPUTgpio       L:-1= starting INPUTgpio program
20190620-14:42:30 INPUTgpio       L:-1= starting setup sensors
20190620-14:42:33 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-14:42:43 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-14:42:43 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:42:43 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-14:42:43 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:42:43 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-14:42:45 master          L:-1= starting web server : port 80 for status
20190620-14:42:45 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-14:42:45 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-14:42:47 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-14:42:47 receiveCommands L:-1= started, listening to port: 9999
20190620-14:42:49 installLibs     L:-1=  installLibs starting
20190620-14:42:49 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-14:42:49 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-14:42:49 installLibs     L:-1= ==== libraries install finished
20190620-14:42:51 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-14:42:51 beaconloop      L:-1= (re)starting bluetooth
20190620-14:42:52 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-14:42:52 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-14:42:52 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-14:42:52 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-14:42:52 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:273613483 acl:0 sco:0 events:7462922 errors:0
	TX bytes:1454379 acl:0 sco:0 commands:76599 errors:0
20190620-14:42:52 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-14:42:52 beaconloop      L:-1= ble thread started
20190620-14:42:52 beaconloop      L:-1= starting loop
20190620-14:42:55 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-14:42:55 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-14:42:56 master          L:-1=  DNS server reachable at:172.23.2.1
could you install this version, only added some logging:
https://www.dropbox.com/s/a7s6bc3rd6lc7 ... n.zip?dl=1
kmarkley
Post by kmarkley »
Here's the log with the new version:
20190620-15:11:37 master          L:-1= writing new callbeacon.py file
20190620-15:11:40 master          L:-1= started:INPUTgpio.py
20190620-15:11:40 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:11:41 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:11:41 INPUTgpio       L:-1= starting setup sensors
20190620-15:11:44 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:11:54 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:11:54 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:11:55 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:11:55 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:11:55 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:11:55 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:11:55 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:11:57 master          L:-1= starting web server : port 80 for status
20190620-15:11:57 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:11:57 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:11:58 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:11:58 receiveCommands L:-1= started, listening to port: 9999
20190620-15:12:01 installLibs     L:-1=  installLibs starting
20190620-15:12:01 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:12:01 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:12:01 installLibs     L:-1= ==== libraries install finished
20190620-15:12:03 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:12:03 beaconloop      L:-1= (re)starting bluetooth
20190620-15:12:04 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:12:04 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:12:04 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:12:04 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:12:04 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276261528 acl:0 sco:0 events:7537246 errors:0
	TX bytes:1481099 acl:0 sco:0 commands:78007 errors:0
20190620-15:12:04 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:12:04 beaconloop      L:-1= ble thread started
20190620-15:12:04 beaconloop      L:-1= starting loop
20190620-15:12:07 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:12:07 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:12:07 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:12:18 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:12:18 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:12:18 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:12:18 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:12:18 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:12:18 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:12:18 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:12:18 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:12:32 master          L:-1= writing new callbeacon.py file
20190620-15:12:34 master          L:-1= started:INPUTgpio.py
20190620-15:12:34 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:12:35 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:12:35 INPUTgpio       L:-1= starting setup sensors
20190620-15:12:39 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:12:49 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:12:49 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:12:49 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:12:49 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:12:49 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:12:49 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:12:49 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:12:51 master          L:-1= starting web server : port 80 for status
20190620-15:12:51 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:12:51 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:12:53 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:12:53 receiveCommands L:-1= started, listening to port: 9999
20190620-15:12:55 installLibs     L:-1=  installLibs starting
20190620-15:12:55 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:12:55 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:12:55 installLibs     L:-1= ==== libraries install finished
20190620-15:12:57 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:12:57 beaconloop      L:-1= (re)starting bluetooth
20190620-15:12:58 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:12:58 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:12:58 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:12:58 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:12:58 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276340257 acl:0 sco:0 events:7539466 errors:0
	TX bytes:1481934 acl:0 sco:0 commands:78051 errors:0
20190620-15:12:58 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:12:58 beaconloop      L:-1= ble thread started
20190620-15:12:58 beaconloop      L:-1= starting loop
20190620-15:13:01 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:13:02 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:13:02 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:13:12 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:13:12 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:13:12 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:13:13 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:13:13 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:13:13 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:13:13 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:13:13 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:13:26 master          L:-1= writing new callbeacon.py file
20190620-15:13:29 master          L:-1= started:INPUTgpio.py
20190620-15:13:29 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:13:30 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:13:30 INPUTgpio       L:-1= starting setup sensors
20190620-15:13:34 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:13:44 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:13:44 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:13:44 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:13:44 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:13:44 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:13:44 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:13:44 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:13:46 master          L:-1= starting web server : port 80 for status
20190620-15:13:46 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:13:46 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:13:48 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:13:48 receiveCommands L:-1= started, listening to port: 9999
20190620-15:13:50 installLibs     L:-1=  installLibs starting
20190620-15:13:50 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:13:50 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:13:50 installLibs     L:-1= ==== libraries install finished
20190620-15:13:52 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:13:52 beaconloop      L:-1= (re)starting bluetooth
20190620-15:13:53 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:13:53 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:13:53 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:13:53 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:13:53 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276442549 acl:0 sco:0 events:7542363 errors:0
	TX bytes:1482769 acl:0 sco:0 commands:78095 errors:0
20190620-15:13:53 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:13:53 beaconloop      L:-1= ble thread started
20190620-15:13:53 beaconloop      L:-1= starting loop
20190620-15:13:56 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:13:56 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:13:56 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:14:07 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:14:07 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:14:07 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:14:07 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:14:07 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:14:07 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:14:08 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:14:08 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:14:21 master          L:-1= writing new callbeacon.py file
20190620-15:14:23 master          L:-1= started:INPUTgpio.py
20190620-15:14:23 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:14:25 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:14:25 INPUTgpio       L:-1= starting setup sensors
20190620-15:14:28 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:14:38 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:14:38 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:14:38 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:14:38 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:14:38 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:14:39 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:14:39 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:14:40 master          L:-1= starting web server : port 80 for status
20190620-15:14:41 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:14:41 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:14:42 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:14:42 receiveCommands L:-1= started, listening to port: 9999
20190620-15:14:44 installLibs     L:-1=  installLibs starting
20190620-15:14:44 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:14:44 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:14:44 installLibs     L:-1= ==== libraries install finished
20190620-15:14:46 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:14:47 beaconloop      L:-1= (re)starting bluetooth
20190620-15:14:47 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:14:47 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:14:47 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:14:47 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:14:48 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276526296 acl:0 sco:0 events:7544767 errors:0
	TX bytes:1483604 acl:0 sco:0 commands:78139 errors:0
20190620-15:14:48 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:14:48 beaconloop      L:-1= ble thread started
20190620-15:14:48 beaconloop      L:-1= starting loop
20190620-15:14:50 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:14:51 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:14:51 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:15:01 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:15:01 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:15:02 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:15:02 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:15:02 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:15:02 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:15:02 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:15:02 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:15:15 master          L:-1= writing new callbeacon.py file
20190620-15:15:18 master          L:-1= started:INPUTgpio.py
20190620-15:15:18 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:15:19 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:15:19 INPUTgpio       L:-1= starting setup sensors
20190620-15:15:23 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:15:33 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:15:33 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:15:33 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:15:33 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:15:33 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:15:33 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:15:33 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:15:35 master          L:-1= starting web server : port 80 for status
20190620-15:15:35 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:15:35 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:15:37 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:15:37 receiveCommands L:-1= started, listening to port: 9999
20190620-15:15:39 installLibs     L:-1=  installLibs starting
20190620-15:15:39 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:15:39 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:15:39 installLibs     L:-1= ==== libraries install finished
20190620-15:15:41 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:15:41 beaconloop      L:-1= (re)starting bluetooth
20190620-15:15:42 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:15:42 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:15:42 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:15:42 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:15:42 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276605881 acl:0 sco:0 events:7547008 errors:0
	TX bytes:1484439 acl:0 sco:0 commands:78183 errors:0
20190620-15:15:42 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:15:42 beaconloop      L:-1= ble thread started
20190620-15:15:42 beaconloop      L:-1= starting loop
20190620-15:15:45 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:15:45 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:15:45 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:15:56 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:15:56 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:15:56 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:15:56 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:15:56 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:15:56 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:15:57 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:15:57 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:16:10 master          L:-1= writing new callbeacon.py file
20190620-15:16:12 master          L:-1= started:INPUTgpio.py
20190620-15:16:12 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:16:14 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:16:14 INPUTgpio       L:-1= starting setup sensors
20190620-15:16:17 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:16:27 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:16:27 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:16:27 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:16:27 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:16:27 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:16:27 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:16:28 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:16:29 master          L:-1= starting web server : port 80 for status
20190620-15:16:30 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:16:30 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:16:31 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:16:31 receiveCommands L:-1= started, listening to port: 9999
20190620-15:16:33 installLibs     L:-1=  installLibs starting
20190620-15:16:33 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:16:33 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:16:33 installLibs     L:-1= ==== libraries install finished
20190620-15:16:35 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:16:35 beaconloop      L:-1= (re)starting bluetooth
20190620-15:16:36 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:16:36 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:16:36 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:16:36 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:16:36 beaconloop      L:-1= BLE start returned:
hci0:	Type: BR/EDR  Bus: UART
	BD Address: B8:27:EB:1B:B3:BF  ACL MTU: 1021:8  SCO MTU: 64:1
	UP RUNNING
	RX bytes:276685468 acl:0 sco:0 events:7549229 errors:0
	TX bytes:1485274 acl:0 sco:0 commands:78227 errors:0
20190620-15:16:37 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:16:37 beaconloop      L:-1= ble thread started
20190620-15:16:37 beaconloop      L:-1= starting loop
20190620-15:16:39 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:16:40 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:16:40 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:17:09 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:17:09 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:17:09 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:17:09 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:17:09 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:17:09 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:17:09 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:17:09 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:17:22 master          L:-1= writing new callbeacon.py file
20190620-15:17:25 master          L:-1= started:INPUTgpio.py
20190620-15:17:25 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:17:26 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:17:26 INPUTgpio       L:-1= starting setup sensors
20190620-15:17:30 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:17:40 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:17:40 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:17:40 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:17:40 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:17:40 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:17:40 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:17:40 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:17:42 master          L:-1= starting web server : port 80 for status
20190620-15:17:42 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:17:42 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:17:44 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:17:44 receiveCommands L:-1= started, listening to port: 9999
20190620-15:17:46 installLibs     L:-1=  installLibs starting
20190620-15:17:46 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:17:46 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:17:46 installLibs     L:-1= ==== libraries install finished
20190620-15:17:48 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:17:48 beaconloop      L:-1= (re)starting bluetooth
20190620-15:17:49 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:17:49 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:17:49 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:17:49 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:17:49 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276790030 acl:0 sco:0 events:7552154 errors:0
	TX bytes:1486109 acl:0 sco:0 commands:78271 errors:0
20190620-15:17:49 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:17:49 beaconloop      L:-1= ble thread started
20190620-15:17:49 beaconloop      L:-1= starting loop
20190620-15:17:52 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:17:53 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:17:53 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:18:03 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:18:03 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:18:03 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:18:03 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:18:03 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:18:04 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:18:04 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:18:04 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:18:17 master          L:-1= writing new callbeacon.py file
20190620-15:18:19 master          L:-1= started:INPUTgpio.py
20190620-15:18:20 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:18:21 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:18:21 INPUTgpio       L:-1= starting setup sensors
20190620-15:18:24 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:18:34 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:18:34 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:18:34 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:18:34 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:18:34 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:18:35 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:18:35 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:18:36 master          L:-1= starting web server : port 80 for status
20190620-15:18:37 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:18:37 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:18:38 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:18:38 receiveCommands L:-1= started, listening to port: 9999
20190620-15:18:40 installLibs     L:-1=  installLibs starting
20190620-15:18:40 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:18:40 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:18:40 installLibs     L:-1= ==== libraries install finished
20190620-15:18:42 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:18:43 beaconloop      L:-1= (re)starting bluetooth
20190620-15:18:43 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:18:43 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:18:43 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:18:43 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:18:44 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276870940 acl:0 sco:0 events:7554414 errors:0
	TX bytes:1486944 acl:0 sco:0 commands:78315 errors:0
20190620-15:18:44 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:18:44 beaconloop      L:-1= ble thread started
20190620-15:18:44 beaconloop      L:-1= starting loop
20190620-15:18:46 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:18:47 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:18:47 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:18:57 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:18:58 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:18:58 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:18:58 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:18:58 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:18:58 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:18:58 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:18:58 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:19:11 master          L:-1= writing new callbeacon.py file
20190620-15:19:14 master          L:-1= started:INPUTgpio.py
20190620-15:19:14 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:19:15 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:19:15 INPUTgpio       L:-1= starting setup sensors
20190620-15:19:19 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:19:29 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:19:29 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:19:29 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:19:29 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:19:29 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:19:29 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:19:29 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:19:31 master          L:-1= starting web server : port 80 for status
20190620-15:19:31 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:19:31 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:19:33 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:19:33 receiveCommands L:-1= started, listening to port: 9999
20190620-15:19:35 installLibs     L:-1=  installLibs starting
20190620-15:19:35 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:19:35 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:19:35 installLibs     L:-1= ==== libraries install finished
20190620-15:19:37 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:19:37 beaconloop      L:-1= (re)starting bluetooth
20190620-15:19:38 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:19:38 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:19:38 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:19:38 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:19:38 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:276949826 acl:0 sco:0 events:7556631 errors:0
	TX bytes:1487779 acl:0 sco:0 commands:78359 errors:0
20190620-15:19:38 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:19:38 beaconloop      L:-1= ble thread started
20190620-15:19:38 beaconloop      L:-1= starting loop
20190620-15:19:41 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:19:41 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:19:41 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:19:52 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:19:52 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:19:52 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:19:52 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:19:52 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:19:52 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:19:53 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:19:53 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
20190620-15:20:06 master          L:-1= writing new callbeacon.py file
20190620-15:20:08 master          L:-1= started:INPUTgpio.py
20190620-15:20:09 master          L:-1= START.. indigoServer IP:>>172.23.2.10<<
20190620-15:20:10 INPUTgpio       L:-1= starting INPUTgpio program
20190620-15:20:10 INPUTgpio       L:-1= starting setup sensors
20190620-15:20:13 master          L:-1= Master adhocWifi is:-1 ;  G.wifiType is:normal
20190620-15:20:23 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:20:23 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:20:23 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:20:23 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:20:23 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:20:24 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:20:24 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:20:25 master          L:-1= starting web server : port 80 for status
20190620-15:20:26 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:20:26 master          L:-1= can ping indigo server at ip:>>172.23.2.10<<
20190620-15:20:27 receiveCommands L:-1= proceding with normal on no ad-hoc network
20190620-15:20:27 receiveCommands L:-1= started, listening to port: 9999
20190620-15:20:30 installLibs     L:-1=  installLibs starting
20190620-15:20:30 installLibs     L:-1=  installLibs no opsys upgrade requested
20190620-15:20:30 installLibs     L:-1= ==== libraries seem to be setup, no need for action
20190620-15:20:30 installLibs     L:-1= ==== libraries install finished
20190620-15:20:31 beaconloop      L: 1= trying to kill ps -ef | grep 'beaconloop.py' | grep -v grep
20190620-15:20:32 beaconloop      L:-1= (re)starting bluetooth
20190620-15:20:32 beaconloop      L:-1= Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:1B:B3:BF; devId:0
20190620-15:20:32 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190620-15:20:32 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190620-15:20:32 beaconloop      L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190620-15:20:33 beaconloop      L:-1= BLE start returned:
	UP RUNNING
	RX bytes:277030053 acl:0 sco:0 events:7558892 errors:0
	TX bytes:1488614 acl:0 sco:0 commands:78403 errors:0
20190620-15:20:33 beaconloop      L:-1= my BLE mac# is : B8:27:EB:1B:B3:BF
20190620-15:20:33 beaconloop      L:-1= ble thread started
20190620-15:20:33 beaconloop      L:-1= starting loop
20190620-15:20:35 master          L:-1= testPing input>>172.23.2.10<< indigoIP>>172.23.2.10<<
20190620-15:20:36 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:20:36 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:20:46 master          L:-1= setWlanEthONoff  ip changed: eth0[on]: dontChange, eth0IP:/, eth0Enabled:F, wlan0IP:172.23.2.60 .. starting eth0
20190620-15:20:46 master          L:-1= setWlanEthONoff  return: eth0IP:, wlan0IP:172.23.2.60, eth0Enabled:False, wifiEnabled:True
20190620-15:20:46 master          L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wlan0IP >>172.23.2.60<<; eth0IP: >><<;   hostnameIP >>['172.23.2.60']<<;   ipAddressRead >>172.23.2.60<<;   requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190620-15:20:47 master          L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190620-15:20:47 master          L:-1=  DNS server reachable at:172.23.2.1
20190620-15:20:47 master          L:-1= testPing input>><< indigoIP>>172.23.2.10<<
20190620-15:20:47 master          L:-1= testPing input>>172.23.2.60<< indigoIP>>172.23.2.10<<
20190620-15:20:47 master          L:-1= --- restarting ---   changed ip number, eg wifi was switched off with eth0 present (1)
I have to run and won't be able work on this for a few hours. Thanks for your help.
Return to “piBeacon”
