Variable Devices Plugin
howartp
Post by howartp »
Introducing the Variable Devices plugin
This plugin is in response to a request to expose Indigo Variables as Device States.
Simply create a Variable Devices device, select which variable(s) you’d like to monitor, choose which one to display as the device’s state, and you’re done.
Download link
VariableDevice.IndigoPlugin
Those who have seen me around the forums will know I usually participate in the forums at least daily if not several times; however please be aware this is usually from my iPhone when I'm away from my desk. I will endeavour to support this plugin as quickly as possible, but (as with everyone) I have busy periods of the year when I'm simply not at my desk long enough to do all I'd like to, including fixing or updating plugin code, even if you see me actively responding to other threads.
Enjoy!
Peter
howartp
Re: Variable Devices Plugin
Post by howartp »
v1.0.3 uploaded.
Fixed the temperature displays and also reduced code by ~50 lines.
howartp
Post by howartp »
I'm a bit behind posting updates here.
v1.0.5 is the latest py2 version - currently on my private github but get in touch if you need this.
v3.0.7 is the py3 version with the same functionality as v1.0.5 - this will be on the pluginstore shortly: https://www.indigodomo.com/pluginstore/269/
Locked
Return to “Variable Devices”
