I have an Aercus Weathersleuth weather station that I was using with Wunderground but it has stopped connecting with the server and I have given up trying to get it to work. I have read all the other threads about PWS changes and API keys etc.
So I decided to see if I could read the data directly off the device itself and I can.
Sample output (processed) looks like this:
++ Outdoor Temperature = 14.8 deg C
++ Outdoor Humidity = 60%
++ Dew Point = 7.1 deg C
++ Wind Chill = 14.8 deg C
++ Wind Direction = NNE
++ Wind Speed = 1.34 mph
++ Wind Gust = 2.46 mph
++ Hourly Rain = 0.0 mm
++ Daily Rain = 0.0 mm
++ Weekly Rain = 0.0 mm
++ Monthly Rain = 0.0 mm
++ Annual Rain = 532.4 mm
++ Solar Radiation = 497.74
++ UV = 2
++ Indoor Temperature = 21.5 deg C
++ Indoor Humidity = 49%
++ Barometric Pressure = 1009 mbar
++ Low Battery = 0
++ Date = 2019-04-01 [UTC]
++ Time = 15:19:24
++ Software Type = WH2600GEN_V2.2.7
++ Action = updateraw
++ Realtime = 1
++ RT Freq = 5Weather Snoop doesn't appear to directly support the Aercus Weathersleuth but it does provide something called a Script Agent. This apparently supports Python scripts so I thought it should be easy enough to retrieve the data and provide it via a Script Agent.
Unfortunately the documentation is a bit sparse on how exactly you use python in a Script Agent and AFAICS there aren't any examples of python scripts (that I have been able to find).
Just wondering if anyone had tried to do one of these using python and if so how?
