DomoPad Plugin Update Check Error
ryanbuckner
Post by ryanbuckner »
Version 2.2.2 of the plugin throws the following error on check for update:
Feb 27, 2019 at 8:21:04 AM
   Domotics Pad Mobile Client DebugVersion check initiated
   Domotics Pad Mobile Client ErrorError checking for new plugin version.
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/DomoPad Mobile Client.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 734, in checkVersionNow
    reply.raise_for_status()
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/models.py", line 848, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
HTTPError: 404 Client Error: Not Found for url: https://api.indigodomo.com/api/v2/pluginstore/plugin-version-info.json?pluginId=com.duncanware.domoPadMobileClient
ryanbuckner
Re: DomoPad Plugin Update Check Error
I turned off debugging and here's the error:
Feb 27, 2019 at 8:33:44 AM
   Domotics Pad Mobile Client      Debugging disabled
   Domotics Pad Mobile Client Warning Error checking for new plugin version.
RogueProeliator
Post by RogueProeliator »
That's expected, update checks will be removed slight in support of a new method.
