"expect: spawn id exp9 not open" Error
shrxman
Post by shrxman »
Hey Karl,
So, I bought a new Mac and decided to reinstall Indigo so as not to inherit all of my previous blunders along with my successes. Starting with PiBeacon on the new machine, I used your latest image as well. I've just added my first pi (used #2 by design as part of my internal housekeeping as pis 0 and 1 will be migrated off of my old system later). Had issues using ssh keys, so reverted to password authentication for now, and that seems to be working ok. I get beacons reported in from that pi, based on your logs, but I keep getting this recurring error. When I watch the auth.log at the time the error occurs, I don't see any attempted connections from the indigo server, so i'm not sure what's up there. Everything seems to be working ok, but I haven't set up my beacons for testing just yet, so I wanted to eliminate this as a real error before I continued. The error keeps repeating, gets up to attempt 9, and then resets. I know piBeacon can connect via ssh as I see other successful connections in the auth.log on that pi, which is the only one configured for this system.
10:30:51                          -updating pi server config for # 2 executing
/usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp' pi  assword 10.0.1.126 2 '/Library/Application Support/Perceptive Automation/Indigo 7.2/Preferences/Plugins/com.karlwachs.piBeacon/' '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/pi' 15
10:30:51                          -setup pi response (1)
('spawn sftp -o ConnectTimeout= pi@2\r\n\r\ncommand-line line 0: missing time value.\r\r\nConnection closed\r\r\n', 'expect: spawn id exp9 not open\n    while executing\n"expect "sftp" {  send  "put \'parameters.$ipParms\'  /home/pi/pibeacon/parameters\\r" }"\n    (file "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 35)\r\n')
10:30:51                          -return code from fix ('spawn sftp -o ConnectTimeout= pi@2\r\n\r\ncommand-line line 0: missing time value.\r\r\nConnection closed\r\r\n', 'expect: spawn id exp9 not open\n    while executing\n"expect "sftp" {  send  "put \'parameters.$ipParms\'  /home/pi/pibeacon/parameters\\r" }"\n    (file "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 35)\r\n') trying again to configure PI
10:30:53                          -setup pi response (2) message
Connection closed
10:30:53                          -setup pi response (2) error
    while executing
"expect "sftp" {  send  "put 'parameters.$ipParms'  /home/pi/pibeacon/parameters\r" }"
10:30:54                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 4, 'exeTime': 1547663458.989195, 'pi': 2, 'type': 'ftp'}
10:30:55                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 4, 'exeTime': 1547663458.989195, 'pi': 2, 'type': 'ftp'}
10:30:57                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 4, 'exeTime': 1547663458.989195, 'pi': 2, 'type': 'ftp'}
10:30:58                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 4, 'exeTime': 1547663458.989195, 'pi': 2, 'type': 'ftp'}
10:30:59                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 4, 'exeTime': 1547663458.989195, 'pi': 2, 'type': 'ftp'}
10:30:59                          -enter  sendFilesToPiFTP #2  fileToSend:updateParamsFTP.exp
10:30:59                          -updating pi server config for # 2
10:30:59                          - sbin/ping  -c 1 -W 40 -o 10.0.1.126 return-code: 0
10:30:59                          -updating pi server config for # 2 executing
10:30:59                          -setup pi response (1)
10:30:59                          -return code from fix ('spawn sftp -o ConnectTimeout= pi@2\r\n\r\ncommand-line line 0: missing time value.\r\r\nConnection closed\r\r\n', 'expect: spawn id exp9 not open\n    while executing\n"expect "sftp" {  send  "put \'parameters.$ipParms\'  /home/pi/pibeacon/parameters\\r" }"\n    (file "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 35)\r\n') trying again to configure PI
10:31:00                          -fixConfig called from checkMinute; with:['all']
10:31:01                          -setup pi response (2) message
Connection closed
10:31:01                          -setup pi response (2) error
    while executing
10:31:02                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 5, 'exeTime': 1547663466.835473, 'pi': 2, 'type': 'ftp'}
10:31:03                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 5, 'exeTime': 1547663466.835473, 'pi': 2, 'type': 'ftp'}
10:31:04                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 5, 'exeTime': 1547663466.835473, 'pi': 2, 'type': 'ftp'}
10:31:05                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 5, 'exeTime': 1547663466.835473, 'pi': 2, 'type': 'ftp'}
10:31:06                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 5, 'exeTime': 1547663466.835473, 'pi': 2, 'type': 'ftp'}
10:31:06                          -enter  sendFilesToPiFTP #2  fileToSend:updateParamsFTP.exp
10:31:06                          -updating pi server config for # 2
10:31:07                          - sbin/ping  -c 1 -W 40 -o 10.0.1.126 return-code: 0
10:31:07                          -updating pi server config for # 2 executing
10:31:07                          -setup pi response (1)
10:31:07                          -return code from fix ('spawn sftp -o ConnectTimeout= pi@2\r\n\r\ncommand-line line 0: missing time value.\r\r\nConnection closed\r\r\n', 'expect: spawn id exp9 not open\n    while executing\n"expect "sftp" {  send  "put \'parameters.$ipParms\'  /home/pi/pibeacon/parameters\\r" }"\n    (file "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 35)\r\n') trying again to configure PI
10:31:09                          -setup pi response (2) message
Connection closed
10:31:09                          -setup pi response (2) error
    while executing
10:31:09                          -last updates were not successful wait, then try again
10:31:10                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:11                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:12                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:13                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:14                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:15                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:16                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:17                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:18                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:19                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 6, 'exeTime': 1547663479.706137, 'pi': 2, 'type': 'ftp'}
10:31:19                          -enter  sendFilesToPiFTP #2  fileToSend:updateParamsFTP.exp
10:31:19                          -updating pi server config for # 2
10:31:19                          - sbin/ping  -c 1 -W 40 -o 10.0.1.126 return-code: 0
10:31:19                          -updating pi server config for # 2 executing
10:31:20                          -setup pi response (1)
10:31:20                          -return code from fix ('spawn sftp -o ConnectTimeout= pi@2\r\n\r\ncommand-line line 0: missing time value.\r\r\nConnection closed\r\r\n', 'expect: spawn id exp9 not open\n    while executing\n"expect "sftp" {  send  "put \'parameters.$ipParms\'  /home/pi/pibeacon/parameters\\r" }"\n    (file "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 35)\r\n') trying again to configure PI
10:31:21                          -creating new beacon,  received from pi # 2/B8:27:EB:53:3E:D1:   beacon-7F:AB:55:3B:10:00  UUID: 011a0aff4c001005-1820-16638
10:31:21                          -fixConfig called from updateBeaconStates new beacon; with:['beacon']
10:31:22                          -setup pi response (2) message
Connection closed
10:31:22                          -setup pi response (2) error
    while executing
10:31:22                          -last updates were not successful wait, then try again
10:31:23                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:24                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:25                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:26                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:27                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:28                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:29                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:30                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:31                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:32                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 7, 'exeTime': 1547663492.487701, 'pi': 2, 'type': 'ftp'}
10:31:32                          -enter  sendFilesToPiFTP #2  fileToSend:updateParamsFTP.exp
10:31:32                          -updating pi server config for # 2
10:31:32                          - sbin/ping  -c 1 -W 40 -o 10.0.1.126 return-code: 0
10:31:32                          -updating pi server config for # 2 executing
10:31:32                          -setup pi response (1)
10:31:32                          -return code from fix ('spawn sftp -o ConnectTimeout= pi@2\r\n\r\ncommand-line line 0: missing time value.\r\r\nConnection closed\r\r\n', 'expect: spawn id exp9 not open\n    while executing\n"expect "sftp" {  send  "put \'parameters.$ipParms\'  /home/pi/pibeacon/parameters\\r" }"\n    (file "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 35)\r\n') trying again to configure PI
10:31:35                          -setup pi response (2) message
Connection closed
10:31:35                          -setup pi response (2) error
    while executing
10:31:35                          -last updates were not successful wait, then try again
10:31:36                          -rpiUpdateThread executing  {'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'tries': 8, 'exeTi
Any thoughts?
Re: "expect: spawn id exp9 not open" Error
looks like your password is not set in
setup basic ..
/usr/bin/expect ....TP.exp' pi <here should be the password> assword 10.0.1.126 2 '/Li ....
"assword" is the string that EXPECT is looking for (the p can be p or P that why it is not here . and yes it says assword
Screen Shot 2019-01-16 at 15.38.57.png (5.54 KiB) Viewed 2205 times
Return to “piBeacon”
