error after update
johnpolasek
error after update
Post by johnpolasek »
I just pulled the newest version (7.28.258) down from the plugin store and suddenly I am getting
Dec 16, 2018, 10:29:52 AM
   piBeacon                        variableUpdated in Line '9540' has error='Unterminated string starting at: line 1 column 30 (char 29)'
   piBeacon                        {"temp": "45.6", "rpi_type": "Pi 3 Model B Rev 1.2
about once a minute... Doesn't seem to be hurting anything but thought you should know.
Re: error after update
I have a fix.. its is a ";" in the string, and that stops somewhere. the ; is now a , that works
when you switch to socket comm it works fine. Only effected the variables update path.
if you want to try it :
https://www.dropbox.com/s/eydnqjyobysau ... n.zip?dl=1
not a formal release !
Return to “piBeacon”
