0.4.0 no problems, 1 note
berkinet
Post by berkinet »
Just installed 0.4.0 and it works fine. Thanks!
One small note. After upgrading I started getting the following errors:
  • DoorBird Debug Doorbird.primary_device_state_update() called
    DoorBird Error DoorBird Status: Unable to read keep alive time
I just had to open the former "Status" device, enter Edit Device Settings, then Save and Close.
berkinet
Re: 0.4.0 no problems, 1 note
Post by berkinet »
I wrote:Just installed 0.4.0 and it works fine....
I wrote too soon. When creating a trigger, the states list is broken. Here is what it shows:
Screen Shot 2018-08-05 at 15.27.58.png (38.65 KiB) Viewed 3665 times
If I select Motion On/Off State or Doorbell On/Off State I do not get the options Has Any Change", Becomes On, or Becomes Off.
If I select the On or Off below each of the states noted above, then I get the Any, True or False choices.
Having a single state, with Any, On or Off is more common. But, having specific states with True, etc is Ok. I guess not offers flexibility as -is, though it should be one way or the other. But, in either case, the separate states, should be labeled for clarity. I.e. Doorbell On, Doorbell Off, etc.
kwijibo007
Post by kwijibo007 »
Thanks for testing.
berkinet wrote:One small note. After upgrading I started getting the following errors:
I'll try to replicate and sort this out
Wow, that's a bug. There should only be On/Off State actions. Not sure how this has happened. I'll investigate
Pete
kwijibo007
berkinet wrote:When creating a trigger, the states list is broken
Just uploaded 0.4.1 which fixes the state list.
This one's got me stumped. I'm pretty sure the error is because the new "State Binding" field was not set until you saved the Device Settings. I don't understand why because it's assigned a default value. It's only an issue the first time you update but it's really not ideal. I'm using the stateListOrDisplayStateIdChanged() method within deviceStartComm but that's for states, not properties. Any thoughts?
Pete
berkinet
Post by berkinet »
kwijibo007 wrote:...Just uploaded 0.4.1 which fixes the state list.
Actually, the update fixed the states list issue as well. Seems to be working fine. But, I will keep testing.
neilk
Post by neilk »
Upgraded and all good for me. I did get the keep alive error but the edit/save cleared it straight away.
kwijibo007
neilk wrote:Upgraded and all good for me. I did get the keep alive error but the edit/save cleared it straight away.
Thanks for testing. I would love to fix it but I can’t replicate it as it’s a one-off update error. New installs should be fine.
agame
Post by agame »
Also got a flood of keep alive errors on upgrade but after re-saving the master devices appears to be working fine.
Return to “Doorbird”
