Please use the GitHub Issues System for bug reports or feature requests.
I'm trying to update the Wiki documentation to cover all common questions. If there's something missing, please post it here or create an issue. Or submit your own changes to the Wiki.
Bug Reports and Feature Requests
- FlyingDiver
Re: Bug Reports and Feature Requests
Is there anything special to do in getting Parrot codes working as a device to turn on and off. I can get the "Send Text" command working for the device "ON A1 PARROT" works.
When I try and add the device as a Parrot i get this error:
RFPlayer Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
File "plugin.py", line 215, in deviceStartComm
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/RFPlayer.indigoPlugin/Contents/Server Plugin/protocols/x10.py", line 16, in __init__
KeyError: key deviceType not found in dict
- FlyingDiver
That's definitely a coding error. Can you create a GitHub issue for this? I won't be able to get into it until I get home after Christmas.
Yes will do, thanks! I've managed to get it to workaround using an Action to send a text command.
