Need Data Please: Garage Door
Colorado4Wheeler
Post by Colorado4Wheeler »
If you are using something other than an Insteon Multi I/O for your garage door would you mind posting the output of this script here so I can see how other devices work? While this is for HomeKit integration you don't need to be a HomeKit or plugin user, I just need data.
indigo.server.log(unicode(indigo.devices[DEVICE_ID]))
jay (support)
Re: Need Data Please: Garage Door
Post by jay (support) »
Here's my myQ garage door:
address : #############
batteryLevel : None
buttonGroupCount : 0
configured : True
description : Opener Device auto-created by MyQ plugin from gateway information
deviceTypeId : myqOpener
displayStateId : onOffState
displayStateImageSel : Locked
displayStateValRaw : True
displayStateValUi : locked
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : #############
     com.flyingdiver.indigoplugin.myq : (dict)
          IsLockSubType : true (bool)
          address : ############# (integer)
          devVersCount : 1 (integer)
          sensor : ############# (string)
lastChanged : 2018-02-09 16:22:24
lastSuccessfulComm : 2018-02-09 16:22:24
ledStates : []
model : MyQ Door Opener
onState : True
ownerProps : com.flyingdiver.indigoplugin.myq : (dict)
pluginId : com.flyingdiver.indigoplugin.myq
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     doorStatus : Closed (string)
     doorStatus.Closed : true (bool)
     doorStatus.Closing : false (bool)
     doorStatus.Disconnected : false (bool)
     doorStatus.Open : false (bool)
     doorStatus.Opening : false (bool)
     doorStatus.Stopped : false (bool)
     doorStatus.Unknown : false (bool)
     onOffState : on (on/off bool)
     onOffState.ui : locked (string)
subModel :
supportsAllOff : False
supportsStatusRequest : True
version : None
Colorado4Wheeler
Thanks Jay!
Coolcaper
Post by Coolcaper »
This is for the Aeotec Garage Door Controller ZW062-A:
batteryLevel : None
configured : True
description :
deviceTypeId : zwRelayType
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
errorState :
folderId : 925076314
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          address : 116 (integer)
          indigoObjVersion : 6 (integer)
          modelNameAndFirmware : Garage Door Controller (ZW062), firmware 1.11 (string)
          propsPushTickler : 9 (string)
          tempAlwaysFalse : false (bool)
          userConfigVal034 : false (bool)
          userConfigVal035 : 13 (integer)
          userPollAfterActivity : true (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : true (bool)
          userWakeInterval : 60 (integer)
          version : 1.12 (string)
          zwAppVersMajor : 1 (integer)
          zwAppVersMinor : 12 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
               g2 : (list)
          zwAssociationsMapStr : 1:[1] 2:[] (string)
          zwClassCmdBase : 102 (integer)
          zwClassCmdMap : (dict)
               c102 : 1 (integer)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c115 : 1 (integer)
               c122 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c152 : 1 (integer)
               c32 : 1 (integer)
               c37 : 1 (integer)
               c89 : 1 (integer)
               c94 : 1 (integer)
          zwClassCmdMapStr : 20v1 25v1 66v1 70v1 71v1 72v1 73v1 5Ev1 98v1 59v1 7Av1 86v1 85v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 64 (integer)
               Item : 7 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Secure Barrier Add-On (string)
          zwConfigVals : (dict)
               p252 : 0 (integer)
               p35 : 13 (integer)
               p37 : 16843008 (integer)
               p38 : 16843008 (integer)
               p39 : 16843008 (integer)
               p40 : 16843008 (integer)
               p80 : 2 (integer)
          zwConfigValsStr : 35:13 37:16843008 38:16843008 39:16843008 40:16843008 80:2 252:0 (string)
          zwDevSubIndex : 0 (integer)
          zwEncryptClassCmdMap : (dict)
          zwEncryptClassCmdMapStr : - none - (string)
          zwEncryptionStatusStr : Supported but not Enabled (string)
          zwEndpointClassMap : (dict)
          zwEndpointClassMapStr : - none - (string)
          zwEndpointDevTypeMap : (dict)
          zwEndpointDevTypeMapStr : - none - (string)
          zwFeatureListStr : routing, beaming, security (string)
          zwLibType : 3 (integer)
          zwManufactureId : 134 (integer)
          zwManufactureName : Aeon Labs (string)
          zwModelDefnVers : 3 (integer)
          zwModelId : 33751102 (integer)
          zwModelName : Garage Door Controller (ZW062) (string)
          zwNodeNeighbors : (list)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 5 (integer)
               Item : 6 (integer)
               Item : 8 (integer)
               Item : 16 (integer)
               Item : 23 (integer)
               Item : 27 (integer)
               Item : 28 (integer)
               Item : 31 (integer)
               Item : 32 (integer)
               Item : 37 (integer)
               Item : 38 (integer)
               Item : 40 (integer)
               Item : 45 (integer)
               Item : 53 (integer)
               Item : 54 (integer)
               Item : 98 (integer)
               Item : 102 (integer)
               Item : 104 (integer)
               Item : 105 (integer)
               Item : 106 (integer)
               Item : 107 (integer)
               Item : 109 (integer)
          zwNodeNeighborsStr : 3, 4, 5, 6, 8, 16, 23, 27, 28, 31, 32, 37, 38, 40, 45, 53, 54, 98, 102, 104, 105, 106, 107, 109 (string)
          zwProtoVersMajor : 3 (integer)
          zwProtoVersMinor : 99 (integer)
          zwShowDumpDevToLog : true (bool)
          zwShowMainUI : true (bool)
          zwShowManualModifyConfigParmUI : false (bool)
          zwShowPollingUI : false (bool)
          zwShowSubmitModelInfoUI : false (bool)
          zwShowWakeIntervalUI : false (bool)
          zwWakeInterval : 0 (integer)
lastChanged : 2018-02-09 15:24:18
lastSuccessfulComm : 2018-02-09 15:24:18
ledStates : []
model : Garage Door Controller (ZW062)
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
          g1 : (list)
               Item : 1 (integer)
          g2 : (list)
          c102 : 1 (integer)
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c115 : 1 (integer)
          c122 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c152 : 1 (integer)
          c32 : 1 (integer)
          c37 : 1 (integer)
          c89 : 1 (integer)
          c94 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 64 (integer)
          Item : 7 (integer)
          p252 : 0 (integer)
          p35 : 13 (integer)
          p80 : 2 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 5 (integer)
          Item : 6 (integer)
          Item : 8 (integer)
          Item : 16 (integer)
          Item : 23 (integer)
          Item : 27 (integer)
          Item : 28 (integer)
          Item : 31 (integer)
          Item : 32 (integer)
          Item : 37 (integer)
          Item : 38 (integer)
          Item : 40 (integer)
          Item : 45 (integer)
          Item : 53 (integer)
          Item : 54 (integer)
          Item : 98 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
subModel : Door Controller
supportsStatusRequest : False
version : 1.12
Colorado4Wheeler
Thank you!
DaveL17
Post by DaveL17 »
In case mine is different than Jay's in some way. (MyQ 7.1.9)
   Script                          address : #############
batteryLevel : None
configured : True
enabled : True
errorState :
lastChanged : 2018-02-10 06:26:30
lastSuccessfulComm : 2018-02-10 06:26:30
ledStates : []
name : Garage Door Opener (CG081019AFA9)
onState : True
protocol : Plugin
subModel :
version : None
My Plugins and Scripts
Colorado4Wheeler
I appreciate all the data, it'll make HomeKit Bridge much easier.
If you are wondering why I want all of this, it's because HKB will, to the greatest of my programming ability, auto detect each device and make it work without anything else. This is so it'll be a plug-and-play as is possible. The hope is that a new user just installs the plugin and everything just works and is mapped to it's proper HomeKit type.
I'll be requesting this from a handful of devices as the development continues.
Thanks again all!
If you need the MyQ plugin to expose different state variables to match better with other devices, just let me know. Right now the base device class is Lock, because there's nothing better. I do plan to change that as soon as Indigo has a proper Door type.
Colorado4Wheeler
Thanks Joe, I don't think I'll need that. I'll write in the conversions to the plugin and if that changes then I can always update or they can fix it manually.
Colorado4Wheeler
Since I seem to be the oddball with the MultiIODevice as a garage door, :shock: :roll:.
Since my only exposure is to Multi IO which basically says "toggle BinaryOutput1 to open and toggle BinaryOutput1 to close and you'll know if it works because BinaryInput1 will be true or false", how do these other doors work? Turn on = open, Turn off = close? I assume so but I'm not sure.
For MyQ, it's unlock to open and lock to close. Which you got right in 0.6.0, because I can open and close the door using the Home app on my phone. There's a long delay before the door registers any state changes, which seems to be confusing the bridge.
Feb 15, 2018 at 5:38:00 PM 2/15
   HomeKit Bridge Error            Attempting to control 'Small Garage Door (CG0838484821)' from HomeKit and have not gotten a response from the Indigo device for at least 10 seconds, aborting command
   Z-Wave                          received "Small Garage Door Tilt Sensor" status update is on
   Trigger                         MyQ Door Sync Issue
   Z-Wave                          received "Small Garage Door Tilt Sensor" status update is off
   Z-Wave                          received "Rack Power Switch" energy total to 430.52 kWh
Feb 15, 2018 at 5:38:35 PM 2/15
Feb 15, 2018 at 5:39:03 PM 2/15
I opened and closed the door, and the MyQ plugin status is correct, but HomeKit thinks it's still open.
maslett
Re: Need Data Please: August Door Lock
Post by maslett »
Here you go. This is the data for an August Door Lock
configured : True
description :
deviceTypeId : augLock
enabled : True
errorState :
folderId : 1185955894
com.vtmikel.augusthome : (dict)
SupportsBatteryLevel : true (bool)
configured : true (bool)
houseID : a7bddfd1-71cf-4078-9697-12bf5c1083a7 (string)
houseName : Street (string)
lockID : CC6F1CC21D7D4D42A5A4D0F94776DAC1 (string)
lastChanged : 2018-02-18 09:05:47
lastSuccessfulComm : 2018-02-18 09:05:47
ledStates : []
model : August Smart Lock
name : Mudroom Door Lock
onState : True
ownerProps : com.vtmikel.augusthome : (dict)
pluginId : com.vtmikel.augusthome
protocol : Plugin
batteryLevel : 98 (integer)
batteryLevel.ui : 98% (string)
lastSentIndigoUpdateTime : 2018-02-17 21:30:09 (string)
lastStateChangeTime : 2018-02-17 21:30:09 (string)
locked_minutes : 695 (integer)
unlocked_minutes : 0 (integer)
subModel :
Return to “HomeKit Bridge”
