This is an excerpt from the Device Extension Wiki site for the new Thermostat Wrapper device, if you would like to get all of the details be sure to check out the Wiki for more details.
This is released fully into the Plugin Store but this device (not the release) is still experimental. While it is being regularly enhanced, more features are forthcoming, I encourage you to try it as-is and let me know what else you might like to see.
Device Extensions is getting some upgrades from just being conversions and extensions, wrappers are now being added and the first of the bunch is the Thermostat Wrapper. A wrapper is just as the name implies, it wraps around another device to either modify the default behavior of the device or to add functionality that wasn't there before. It can also be used as a "virtual" device that can have each function assigned to a different device or action group.
The wrapper concept is that you can optionally select any thermostat in Indigo to wrap (you don't have to actually wrap anything) and any function or value that you do not explicitly override will simply pass through to the selected thermostat. For instance, if the only function you decide to override is the current temperature and humidity then those values will be retrieved from whatever devices and states you specify for them while the rest of the thermostats data and functions will pass through.
This was primarily designed as a way to get temperature sensor data to pass through to HomeKit since Homebridge-Indigo/Homebridge Buddy does not yet support independent temperature sensors. While it shows in HomeKit as a thermostat, the desired result was achieved since the thermostat reads the temperature from the sensor.
New Device: Thermostat Wrapper
- Colorado4Wheeler
Post by Colorado4Wheeler »
- Colorado4Wheeler
Re: New Device: Thermostat Wrapper
If anyone is interested in testing this device it is available as a "preview" release on the Git repository. I may not drop the actual next big upgrade for a little while yet because I'm doing a LOT with Device Extensions but this is a stable release and now allows you to mostly fully wrap a thermostat and have control over:
- Optionally pass through any functions or data that are not explicitly remapped elsewhere to another thermostat (so keep 99% of your thermostat but maybe map your "Fan On" to an action group that does some other things and then turns the fan on too)
- Use any device in Indigo and pull any state into the current temperature, humidity, cooling set point or heating set point (you temperature could be the outside temperature from WUnderground if you want or any other data source you can dream of)
- Use any action group to control all functions, such as setting the heat/cool set points, controlling the fan and setting the HVAC mode
- wrapper-thermostat-options.png (42.69 KiB) Viewed 2251 times
Jump to
- Indigo Help
- ↳ Announcements
- ↳ Basic Usage Questions
- ↳ Devices
- ↳ Schedules
- ↳ Conditions
- ↳ Action Groups and Actions
- ↳ Variables
- ↳ Control Pages
- ↳ Feature Requests
- ↳ Z-Wave
- ↳ INSTEON
- ↳ Indigo Virtual Devices
- ↳ X10 - Legacy
- ↳ Supported Hardware
- ↳ Interfaces
- ↳ IR and A/V Devices
- ↳ Switches
- ↳ Thermostats
- ↳ Miscellaneous Devices
- ↳ Built-in Plugins
- ↳ Airfoil Pro
- ↳ Old Airfoil Discussions
- ↳ Alexa
- ↳ EasyDAQ Relay Card
- ↳ Email+
- ↳ Global Property Manager
- ↳ iTunes (Discontinued)
- ↳ NOAA Weather
- ↳ SQL Logger
- ↳ Timers and Pesters
- ↳ WeatherSnoop
- ↳ Growl (Discontinued)
- ↳ Indigo Server Software
- ↳ Indigo Mac Client App
- ↳ Indigo Touch for iOS
- ↳ Indigo Touch for the Web
- ↳ Extending Indigo
- ↳ AI Coding Agents
- ↳ Python Scripting
- ↳ Client APIs
- ↳ Hacking
- ↳ AppleScript Scripting
- ↳ Archived Posts
- ↳ Plugin Lists
- ↳ AaronLionsheep’s Plugins
- ↳ ShellyMQTT
- ↳ ShellyNGMQTT
- ↳ AB's Plugins
- ↳ AD2USB Alarm Interface
- ↳ Anyone's Plugins
- ↳ Autolog's Plugins
- ↳ AWTRIX
- ↳ Dynamic View Controller
- ↳ Foscam HD Controller
- ↳ Hubitat
- ↳ LIFX Controller
- ↳ nanoleaf Controller
- ↳ Roon Controller
- ↳ SMAPPEE Controller
- ↳ Squeezebox Controller
- ↳ Starling Bridge
- ↳ Touch Portal
- ↳ TRV Controller
- ↳ Z-Wave Interpreter
- ↳ Zigbee2mqtt
- ↳ Berkinet's Plugins
- ↳ Bill's Plugins
- ↳ Bouncing Ball LTD
- ↳ Dave's Plugins
- ↳ Announcements Plugin
- ↳ Bike Share Plugin
- ↳ Dave's Scripts
- ↳ GhostXML Plugin
- ↳ Indigo Log Viewer
- ↳ Matplotlib Plugin
- ↳ Multitool Plugin
- ↳ OWServer Plugin
- ↳ Z-Wave Node Matrix Plugin
- ↳ Deprecated Plugins
- ↳ Thingspeak Plugin
- ↳ WUnderstation Plugin
- ↳ WUnderground Plugin
- ↳ Fantastic Weather Plugin
- ↳ Duncan’s Plugins
- ↳ FlyingDiver's Plugins
- ↳ Ecobee
- ↳ Harmony Hub
- ↳ Home Assistant Agent
- ↳ LIFX Bridge
- ↳ Lutron
- ↳ miniUniFi
- ↳ MQTT
- ↳ Spy Connect
- ↳ Trane Nexia
- ↳ Twilio
- ↳ Other Plugins
- ↳ Discontinued Plugins
- ↳ RFPlayer
- ↳ MyQ
- ↳ Better Email
- ↳ GlennNZ's Plugins
- ↳ Actron QUE AC Plugin
- ↳ AppleTV Plugin
- ↳ BlueIris
- ↳ DeepState AI Plugin
- ↳ Deluxe Graphing
- ↳ Device Timer
- ↳ Dreame Vacuum Plugin
- ↳ Emby Plugin
- ↳ Enphase Envoy Solar
- ↳ ESPHome4Indigo
- ↳ FindFriendsMini Plugin
- ↳ Gecko Spa Plugin
- ↳ Holiday Plugin
- ↳ HomeKitLink Siri
- ↳ iMessage
- ↳ iRoomba iRobot Plugin
- ↳ Kiosk Home iOS App
- ↳ LedSimple Effects Plugin
- ↳ Mammotion Robot
- ↳ Paradox Alarm Plugin
- ↳ Sipura SPA VOIP Plugin
- ↳ Solar Smart
- ↳ Sunrise Plugin
- ↳ Tesla Battery
- ↳ Windows PC Remote Plugin
- ↳ Greg Glockner's Plugins
- ↳ Greg's Plugins
- ↳ Honeywell TC2 Security
- ↳ howartp's Plugins
- ↳ Clock Display
- ↳ EnergyLink
- ↳ Font Awesome
- ↳ Honeywell Evohome
- ↳ MyEnergi Hub
- ↳ Neo Smart Blinds
- ↳ Pulse Counter
- ↳ Sense Home Energy
- ↳ Sensibo
- ↳ Somfy Manager
- ↳ Tesla EV Control
- ↳ Variable Devices
- ↳ Verisure Alarm
- ↳ Volvo On Call
- ↳ Wakeup Scheduler
- ↳ ZWave Lock Manager
- ↳ ZWave Sensor Logger
- ↳ ZWave Scene Controller
- ↳ ZWave Watcher
- ↳ Zwave Window Controller
- ↳ Jason's Plugins
- ↳ GitHub Plugin Updater
- ↳ Network Devices
- ↳ Power Source
- ↳ Prometheus Client
- ↳ Prowl Notify
- ↳ RToggle
- ↳ Webcam
- ↳ XMPP Client
- ↳ Bouncie OBD Plugin
- ↳ On-Screen Keyboard Plugin
- ↳ AppleTV Plugin
- ↳ ARDUINO Plugin
- ↳ Devices and Variables
- ↳ FINGSCAN
- ↳ Homematic Plugin
- ↳ homeAway - presence
- ↳ Hue Lights
- ↳ Archives
- ↳ Indigo Utilities
- ↳ INDIGOplotD
- ↳ Mother Plugin
- ↳ Network Scanner
- ↳ piBeacon
- ↳ Shelly Plugin
- ↳ startupAction Plugin
- ↳ uniFi-WiFi-AP
- ↳ VoiceReceiver
- ↳ kmarkley's plugins
- ↳ Korey’s Plugins
- ↳ Anthem-Rs232
- ↳ Apple Music Control
- ↳ Music Manager
- ↳ Spotify Control
- ↳ Viewsonic Projector Rs232
- ↳ VLC Control
- ↳ Kwijibo007’s Plugins
- ↳ Doorbird
- ↳ Monoprice 6 Zone Amp
- ↳ SSH Switch
- ↳ Samsung TV
- ↳ Mpoulson’s Plugins
- ↳ Ring Doorbell
- ↳ Mr.Slim Heat Pump
- ↳ NuHeat Heated Floors
- ↳ PurpleAir
- ↳ Nathan Williams' Plugins
- ↳ Nick's Plugins
- ↳ Autelis Jandy
- ↳ Autelis Somfy
- ↳ Hikvision Camera Alerts
- ↳ Honeywell Thermostat
- ↳ TED 5000
- ↳ Neil's Plugins
- ↳ Daikin Wifi Controller
- ↳ Solcast Solar Forecast
- ↳ Velux Active
- ↳ WLED LED Controller
- ↳ papamac’s plugins
- ↳ Virtual Garage Door
- ↳ Pi GPIO
- ↳ Perry the Cynic
- ↳ racarter's plugins
- ↳ Blink
- ↳ Heatmiser Neo
- ↳ Hive
- ↳ Netatmo Multi
- ↳ Sunsynk
- ↳ Tapo
- ↳ Texecom
- ↳ Tuya
- ↳ Watchdog
- ↳ raneil's corner
- ↳ rbdubz3's Plugins
- ↳ Smart Setpoints
- ↳ Sylvania Lightify
- ↳ Light Scenes
- ↳ RFXCOM
- ↳ TiVo Network Remote
- ↳ Roku Network Remote
- ↳ Niles Audio Zone Receiver
- ↳ Sharp TV Network Remote
- ↳ DomoPad Android Client
- ↳ Onkyo Receiver
- ↳ Plex Media Server Manager
- ↳ Google Assistant
- ↳ Ryan Buckner's Plugins
- ↳ Tomorrow.io Plugin
- ↳ SearchCz's Plugins
- ↳ Roomify
- ↳ Securify
- ↳ Simon’s Plug-ins
- ↳ Claude Skill
- ↳ Domio
- ↳ Home Intelligence
- ↳ MCP Lite
- ↳ Netro Irrigation
- ↳ Sofabaton
- ↳ UK Trains
- ↳ Broadlink Devices
- ↳ APC Metered Rack PDU
- ↳ Captain’s Recapitulation
- ↳ VTMikeL's plugins
- ↳ Auto Fan
- ↳ Auto Lights
- ↳ Security Spy Helper
- ↳ August Home
- ↳ Google Vision
- ↳ Just Add Power
- ↳ MCP Server
- ↳ WeatherSnoop
- ↳ WebDeck Software
- ↳ BAFControl
- ↳ WonderSlug's Plugins
- ↳ Bert's Plugins
- ↳ Indify
- ↳ Chameleon Plugins
- ↳ NEST Home
- ↳ iTravel
- ↳ LED Device Manager
- ↳ iFindStuff
- ↳ Bip's Plugins
- ↳ Homebridge Buddy
- ↳ Device Extensions Plugin
- ↳ HomeKit Bridge
- ↳ LCD Creator
- ↳ Room-O-Matic
- ↳ Scene Toggle
- ↳ Firstnibble
- ↳ indilinq
- ↳ Jacob Lindehoff's Plugins
- ↳ Kristian's Plugins
- ↳ Mission Machines' Plugins
- ↳ Nathan Sheldon Software
- ↳ Proxidyne
- ↳ Sean's Plugins
- ↳ Spencer's Plugins
- ↳ thechad.io
- ↳ Travis' Plugins
- ↳ Smartphone Radar
- ↳ DSC Alarm Plugin
- ↳ Yergey's Forum
- ↳ ZachBenz's Plugins
- ↳ RingForIndigo
- User Contributions
- ↳ User Plugins
- ↳ Open Source Plugins
- ↳ Adapters
- ↳ Alexa-Hue Bridge
- ↳ DIRECTV DVR Control
- ↳ Dynamic Control
- ↳ HassBridge
- ↳ Photo Frame
- ↳ Pushover
- ↳ Archives
- ↳ Rachio
- ↳ Security Camera
- ↳ Sonos
- ↳ Vera Bridge
- ↳ Yamaha RX
- ↳ 8 Channel Network Relay
- ↳ Python Scripts
- ↳ Apple Shortcuts
- ↳ Other Scripts
- ↳ Miscellaneous
- ↳ AppleScripts
- ↳ Archived Posts
- ↳ Switching to Indigo
- ↳ Vendor Announcements
- ↳ Help Wanted & Bounties
- ↳ How Do I...
- ↳ User Modifications
- ↳ Classifieds
- ↳ General Home Automation
- ↳ General Chat
- ↳ Finding Installers
- ↳ Installer Discussions
