Presence monitoring using Karl's Plugins: Best Practices
mundmc
Post by mundmc »
It's obvious I am a total fanboy of your plugins, Karl, as I use the trifecta of Unifi, fingscan, and PiBeacon. They all are great.
I suppose my question (having recently moved from an NYC apartment to a house I can really get behind) is the following:
Given I have success with each of your plugins, what are the most efficient settings for
a) rapid identification of somebody returning home
b) rapid identification for somebody who has truly left
c) with minimal false positives
In my experience, PiBeacon has the best sensitivity and specificity, but, sadly, the XY beacons I use last, on average, 3 months. The WAF (wife acceptance factor) takes a hit when I ask to replace batteries in her keychain-tracking-device.
Thoughts?
Re: Presence monitoring using Karl's Plugins: Best Practices
in order to reduce false negatives:
1. have > 2 RPI opposite of the house/ apartment .. the more the better -- I have 10.
in case you sit on the beacon the signal might not come through your body.. As wifes are always slim, that should not be a problem. :)
2. do not set the timeout too fast
I have not seen wrong positives.
if you want to do quick downs, try " fast down mode" in the beacons devices edit, set to 20 secs. If no signal for 20 secs the beacon will go to down
as for battery live the tiles seem to be a bit better, but the new ones seem to more sophisticated to save battery power.. that might create a false negative.
the radius are ugly, but you can set the signal strength and repeat rate. for good detection ~1 second repeat is more than enough. don't need 0.2 secs.
but some others can probably chime in with more info..
and thanks for the nice feed back
new release coming:
- communication through sockets instead of
RPI -> http -> indigo web server -> log file --> sql logger for variable changes --> 'expensive' "variable has changed method" into pibeacon belly
new:
RPI --> tcp/ip socket --> tcp/ip listener --> pibeacon belly .
with message error control (I found a bad ethernet cable on one of my RPIs, 10% of messages required a retransmit). that is not visible in the HTTP channel
- added function cut off low signal if not UP. If up use signal. This should prevent remote beacons coming going UP/down frequency if they are at e.g. -90 dBm.
- some error checking and a lot of tuning
and the bad side: I changed all folder device and variable names where it had a "-" to a "_". learned that indigo does not support those fully (e.g. you can not edit their names )
that will require some maintanece if you have e.g. events setup on variables.
old device names etc will not be touched though.
the stats info will look like:
00:10:53 pi TCPIP socket     -Stats for RPI-->INDIGO data transfers. Tracking started 2017-10-09 23:11:23. Report TX errors if time between errors is <:100secs
00:10:53 pi TCPIP socket     -IP              name         type       first               last                    #MSGs       #bytes bytes/MSG bytes/min  MSGs/min
00:10:53                     -192.168.1.20    pi_IN_0      ok         2017-10-09 23:11:48 2017-10-10 00:10:36       653       254836       390    4282.6   10.9739
00:10:53                     -192.168.1.20    pi_IN_Alive  ok         2017-10-09 23:17:57 2017-10-10 00:05:42         9         1061       117   17.8305    0.1512
00:10:53                     -192.168.1.21    pi_IN_1      ok         2017-10-09 23:11:44 2017-10-10 00:10:41       353       191158       541    3212.5    5.9323
00:10:53                     -192.168.1.21    pi_IN_Alive  ok         2017-10-09 23:12:55 2017-10-10 00:04:49         6          678       113   11.3940    0.1008
00:10:53                     -192.168.1.22    pi_IN_2      ok         2017-10-09 23:11:48 2017-10-10 00:10:40       294        93519       318    1571.6    4.9408
00:10:53                     -192.168.1.22    pi_IN_Alive  ok         2017-10-09 23:20:20 2017-10-10 00:09:48         5          595       119    9.9992    0.0840
00:10:53                     -192.168.1.23    pi_IN_3      ok         2017-10-09 23:11:46 2017-10-10 00:10:50       324       233607       721    3925.9    5.4449
00:10:53                     -192.168.1.23    pi_IN_Alive  ok         2017-10-09 23:22:30 2017-10-10 00:06:43         5          560       112    9.4110    0.0840
00:10:53                     -192.168.1.24    pi_IN_4      ok         2017-10-09 23:11:53 2017-10-10 00:10:34       140       153803      1098    2584.7    2.3528
00:10:53                     -192.168.1.24    pi_IN_Alive  ok         2017-10-09 23:15:23 2017-10-10 00:07:43         6          690       115   11.5957    0.1008
00:10:53                     -192.168.1.25    pi_IN_5      ok         2017-10-09 23:11:44 2017-10-10 00:10:51       198       248927      1257    4183.3    3.3275
00:10:53                     -192.168.1.25    pi_IN_Alive  ok         2017-10-09 23:17:37 2017-10-10 00:10:39         6          678       113   11.3940    0.1008
00:10:53                     -192.168.1.26    pi_IN_6      ok         2017-10-09 23:11:57 2017-10-10 00:10:38       261       163024       624    2739.7    4.3862
00:10:53                     -192.168.1.26    pi_IN_Alive  ok         2017-10-09 23:12:49 2017-10-10 00:04:39         6          714       119   11.9990    0.1008
00:10:53                     -192.168.1.27    pi_IN_7      ok         2017-10-09 23:11:55 2017-10-10 00:10:33        35         5880       168   98.8156    0.5882
00:10:53                     -192.168.1.27    pi_IN_Alive  ok         2017-10-09 23:11:46 2017-10-10 00:10:19        33         3630       110   61.0035    0.5546
00:10:53                     -192.168.1.28    pi_IN_8      ok         2017-10-09 23:12:11 2017-10-10 00:10:47       150        39736       264  667.7783    2.5208
00:10:53                     -192.168.1.28    pi_IN_Alive  ok         2017-10-09 23:14:58 2017-10-10 00:08:59         6          678       113   11.3940    0.1008
00:10:53                     -192.168.1.29    pi_IN_9      ok         2017-10-09 23:11:51 2017-10-10 00:10:36       146       206897      1417    3477.0    2.4536
00:10:53                     -192.168.1.29    pi_IN_9      errLength  2017-10-09 19:08:57 2017-10-09 19:51:14         9        13032      1448  297.6812    0.2056
00:10:53                     -192.168.1.29    pi_IN_Alive  ok         2017-10-09 23:12:49 2017-10-10 00:04:48         6          696       116   11.6965    0.1008
00:10:53                     -192.168.1.31    pi_IN_11     ok         2017-10-09 23:11:45 2017-10-10 00:10:46       166        54780       330  920.5983    2.7897
00:10:53                     -192.168.1.31    pi_IN_Alive  ok         2017-10-09 23:12:57 2017-10-10 00:04:39         6          666       111   11.1924    0.1008
00:10:53                     -192.168.1.33    pi_IN_13     ok         2017-10-09 23:11:43 2017-10-10 00:10:52        82        23759       289  399.2789    1.3780
00:10:53                     -192.168.1.33    pi_IN_Alive  ok         2017-10-09 23:20:37 2017-10-10 00:03:05         8         1124       140   18.8892    0.1344
00:10:53                     -192.168.1.34    pi_IN_14     ok         2017-10-09 23:12:46 2017-10-10 00:09:59        42         8190       195  137.6360    0.7058
00:10:53                     -192.168.1.34    pi_IN_Alive  ok         2017-10-09 23:11:45 2017-10-10 00:01:25         7          826       118   13.8812    0.1176
00:10:53                     -192.168.1.36    pi_IN_16     ok         2017-10-09 23:11:50 2017-10-10 00:10:40       159        36729       231  617.2445    2.6721
00:10:53                     -192.168.1.36    pi_IN_Alive  ok         2017-10-09 23:15:57 2017-10-10 00:09:00         6          666       111   11.1924    0.1008
00:10:53                     -192.168.1.38    pi_IN_18     ok         2017-10-09 23:11:59 2017-10-10 00:09:49        38         6802       179  114.3101    0.6386
00:10:53                     -192.168.1.38    pi_IN_Alive  ok         2017-10-09 23:11:57 2017-10-10 00:10:13        30         3661       122   61.5245    0.5042
00:10:53                     -total        3186      1738570       545   29217.3   53.5419
00:10:53 pi TCPIP socket     - ===  Stats for RPI --> INDIGO data transfers ==  END total minutes measured: 59
besides looking at transmission error see errLength line,
you can also see which RPi is very busy and check why.
mundmc
Post by mundmc »
Great news on the rPi front. I should have been more specific with my question-> if I am NOT using piBeacons, and just using iPhones, what combo of Unifi plugin and Fingscan do you recommend?
