WARNING: LIFX Firmware Update
autolog
Post by autolog »
:!: Just to advise users of the LIFX plugin that a user has reported a problem with his lamps going no ack after applying the latest firmware update from LIFX.
I will investigate and try and determine what the issue is. It will likely be a few days before I can do this. :|
If anyone has done the firmware update and you are or aren't experiencing a problem then please reply to this thread. Thanks. :)
autolog
Re: WARNING: LIFX Firmware Update
Post by autolog »
That was a quick couple of days :wink: - new release version 4.1.4 now available on Github which hopefully fixes the issue. :)
I have tested it with:
  • LIFX Original 1000 (Firmware 2.1)
  • LIFX Color 1000 (Firmware 1.22)
  • LIFX + A19 (Firmware 2.9)
  • LIFX + A19 (Firmware 2.13)
  • LIFX Z (Firmware 1.22)
Return to “LIFX Controller”
