Lock Manager Time Update Bug
CliveS
Post by CliveS »
Just noticed that the RTC is failing since the 1.0.37 update (quick to spot these things I am not!!!)
All logs up to then show
2017-05-31 00:00:00.070 Application Created new log file (Indigo Server version 7.0.3)
2017-05-31 00:00:00.070 Schedule Front Door Lock Time Set
2017-05-31 00:00:01.728 Z-Wave Lock Manager Setting lock time to 31/5/2017 0:0:1 (UK format DD/MM/YYYY HH:MM:SS)
2017-05-31 00:00:02.085 Z-Wave sent "Front Door Keypad Lock" raw command [xx xx xx xx xx xx 00 00 01]
I updated the plugin
2017-05-31 07:58:57.543 Application Stopping plugin Z-Wave Lock Manager (pid 458)
2017-05-31 07:58:58.671 Application Stopped plugin Z-Wave Lock Manager
2017-05-31 07:58:58.671 Application Upgrading plugin Z-Wave Lock Manager to newer version 1.0.37 (previous version moved to trash)
2017-05-31 07:58:58.729 Application Loading plugin "Z-Wave Lock Manager 1.0.37"
2017-05-31 07:58:58.731 Application Starting plugin "Z-Wave Lock Manager 1.0.37" (pid 2952)
2017-05-31 07:58:59.163 Application Started plugin "Z-Wave Lock Manager 1.0.37"
2017-05-31 08:00:00.525 Z-Wave received "055 - Front Door Keypad Lock" status update battery level 90%
2017-05-31 08:08:16.569 Schedule Front Door Lock Time Set
2017-05-31 08:08:16.572 Z-Wave Lock Manager Setting lock time to 31/5/2017 8:8:16 (UK format DD/MM/YYYY HH:MM:SS)
2017-05-31 08:08:16.627 Z-Wave Lock Manager Error Error in plugin execution ExecuteAction:
File "plugin.py", line 189, in setRTC
InvalidParameter: could not find module/node for action
2017-05-31 08:10:06.607 Action Group Front Door Lock Wrong Code Set Limit & Timeout
2017-05-31 08:10:06.609 Z-Wave Lock Manager Setting incorrect code limit to 3 attempts with 60 second timeout:
2017-05-31 08:10:06.629 Z-Wave Lock Manager Error Error in plugin execution ExecuteAction:
File "plugin.py", line 224, in setWrongLimit
Further updates cured the setWrongLimit problem and I thought no more about it but it seems the setRTC is still not happy.
CliveS
CliveS
howartp
Re: Lock Manager Time Update Bug
Post by howartp »
Can you post current logs showing the error as those line numbers don't match up with the v1.0.42 codebase so I can't debug it.
Peter
CliveS
Post by CliveS »
Peter,
11 Jul 2017, 23:01:36
Z-Wave received "En Suite Floor Heating Thermostat" heat setpoint is 15.0 °C
Disabling plugin "Z-Wave Lock Manager 1.0.42"
Stopping plugin "Z-Wave Lock Manager 1.0.42" (pid 19236)
Stopped plugin "Z-Wave Lock Manager 1.0.42"
Enabling plugin "Z-Wave Lock Manager 1.0.42"
Starting plugin "Z-Wave Lock Manager 1.0.42" (pid 64757)
Started plugin "Z-Wave Lock Manager 1.0.42"
11 Jul 2017, 23:02:14
Z-Wave Lock Manager Setting lock time to 11/7/2017 23:2:14 (UK format DD/MM/YYYY HH:MM:SS)
File "plugin.py", line 200, in setRTC
CliveS
CliveS
howartp
Post by howartp »
Fixed in 1.0.43 released this morning.
Peter
CliveS
Post by CliveS »
howartp wrote:Fixed in 1.0.43 released this morning.
Thank you Peter, as you say, Fixed.
CliveS
CliveS
durosity
Post by durosity »
(ignore - posted in wrong part of forum)
roquej
Post by roquej »
howartp wrote:Can you post current logs showing the error as those line numbers don't match up with the v1.0.42 codebase so I can't debug it.
Peter
Peter - the error logs i last posted were after upgrading to .43. Sorry, but not sure what you mean.
JP
