This version includes the following changes:
- Brighten / Dim Support
Now supports Brightening / Dimming using the standard Indigo controls & triggers - Set RGBW Levels
Processing work-around added to enable Indigo action ‘Set RGBW Levels’ to work.
To differentiate between Color and White the plugin does the following: If any of Red, Green or Blue values are greater than zero then the plugin assumes you are setting a Color otherwise it will use the White Level and Temperature values. - LifxLan
Now uses the latest lifxlan libabry from Meghan Clark - see https://github.com/mclarkk/lifxlan
This latest version supports the new firmware recently released by LIFX. - Bug Fixes
Various
Download link: LIFX Controller V4
If you are currently running V4.0.4 or later, you should be able to use the plugin menu (LIFX ) to update the plugin.
Any issues please add to the existing discussion thread or start a new topic.
