Feature request: Multiple Server Support
gatomon
Post by gatomon »
I have more than 1 indigo server that I would like to check. It seems that the only way to do this is to edit the settings. Couldn't there be a way to create profiles for each server? For example, I have multiple rasberry pi sprinkler controllers running SIP (http://dan-in-ca.github.io/SIP/). I use the Android (and iPhone) app "OpenSprinkler" (https://play.google.com/store/apps/deta ... sprinklers). This app lets me set up profiles for each controller and then switch between them is a clean way.
BTW, I've been using Indigo since the beginning, but just discovered this nice application...
-Chris
RogueProeliator
Re: Feature request: Multiple Server Support
Post by RogueProeliator »
I'll add it to the request list -- there are very few users utilizing multiple servers, however it is a consideration for the future as there has been some interest in utilizing Domotics Pad in a rental or second home scenario.
In the current version, the best suggestion I have for you is to utilize the Home and Away settings and you could have two different servers -- then turn off the auto-switch and manually make the switch (there is a quick toggle in the navigation drawer). That isn't ideal, but perhaps could be passable depending upon your network and remove access setup.
Adam
