In addition to SSH control, the plugin can also report your public IP address and the date it was last updated.
I wrote this plugin to help me support Indigo (and the Mac it's running on) for family and friends. I wasn't comfortable in leaving SSH open to the internet constantly and wanted a way someone could grant me access as required. This way the person I'm supporting flicks a switch in Indigo Touch to enable remote access and turns it off when I'm done. They can also easily provide me their public IP address too. Aside from console access, SSH lets you do some cool things like screen sharing (via an SSH tunnel) and file transfers.
Please note: In order to allow the plugin to enable/disable SSH (Remote Login), a change to your Mac's sudoers file is required. This change grants the user running indigo the permission to query the state of SSH, turn SSH on and turn SSH off without entering an administrator password. No other rights/changes are granted in this process.
Important: Opening SSH to the internet and making the changes to your sudoers file outlined below reduces the security of your Mac. In my humble, non-professional opinion, the risks are fairly low but you should only make these changes if you fully understand what they are doing. That being said, you should have a very, very (very) strong password on the account with SSH access.
Full credit for the steps below (and a big thank you) go to forum user roussell. Without his awesome help this plugin would not have been possible. See this topic for full details. NB: I wasn't able to make the overrides file work as suggested so I resorted to editing the sudoers file directly. There are some good tips here on security by obscurity and the plugin allows you to change the path of the systemsetup executable if you so desire.
Steps:
Open terminal and type:
sudo visudoScroll down and find something similar to these lines:
# User privilege specification
root ALL=(ALL) ALL
%admin ALL=(ALL) ALLPress "a" to put VI into edit mode and place a new line directly under "%admin ALL=(ALL) ALL". On the new line(s) enter the following (where "my_username" is the username of the user running your Indigo):
my_username ALL=(ALL) NOPASSWD: /usr/sbin/systemsetup -getremotelogin
my_username ALL=(ALL) NOPASSWD: /usr/sbin/systemsetup -setremotelogin on
my_username ALL=(ALL) NOPASSWD: /usr/sbin/systemsetup -f -setremotelogin off
root ALL=(ALL) ALL
my_username ALL=(ALL) NOPASSWD: /usr/sbin/systemsetup -f -setremotelogin offOnce you've sorted the steps above, install the plugin and you're good to go. The plugin options are self explanatory (I hope).
Plugin can be downloaded here.
