piBeacon: 19- display in which room a beacon is
here is how to display a green dot for (each) beacon in a room where the beacon currently is:
setup a page with:
Screen Shot 2017-01-17 at 22.39.04.png (68.28 KiB) Viewed 7537 times
and
Screen Shot 2017-01-17 at 22.39.40.png (50.83 KiB) Viewed 7537 times
etc for each beacon (here b-radius-1,2) and room (room-0...9 if you have 10 RPI ) you like to cover
create the following images:
RPI0+-1.png	RPI1+.png	RPI2+0.png	RPI3+1.png	RPI4+2.png	RPI5+4.png	RPI6+4.png	RPI7+5.png	RPI8+6.png	RPI9+7.png
RPI0+.png	RPI1+0.png	RPI2+1.png	RPI3+2.png	RPI4+3.png	RPI5+5.png	RPI6+5.png	RPI7+6.png	RPI8+7.png	RPI9+8.png
RPI0+0.png	RPI1+1.png	RPI2+2.png	RPI3+3.png	RPI4+4.png	RPI5+6.png	RPI6+6.png	RPI7+7.png	RPI8+8.png	RPI9+9.png
RPI0+1.png	RPI1+2.png	RPI2+3.png	RPI3+4.png	RPI4+5.png	RPI5+7.png	RPI6+7.png	RPI7+8.png	RPI8+9.png
RPI0+2.png	RPI1+3.png	RPI2+4.png	RPI3+5.png	RPI4+6.png	RPI5+8.png	RPI6+8.png	RPI7+9.png	RPI9+-1.png
RPI0+3.png	RPI1+4.png	RPI2+5.png	RPI3+6.png	RPI4+7.png	RPI5+9.png	RPI6+9.png	RPI8+-1.png	RPI9+.png
RPI0+4.png	RPI1+5.png	RPI2+6.png	RPI3+7.png	RPI4+8.png	RPI6+-1.png	RPI7+-1.png	RPI8+.png	RPI9+0.png
RPI0+5.png	RPI1+6.png	RPI2+7.png	RPI3+8.png	RPI4+9.png	RPI6+.png	RPI7+.png	RPI8+0.png	RPI9+1.png
RPI0+6.png	RPI1+7.png	RPI2+8.png	RPI3+9.png	RPI5+-1.png	RPI6+0.png	RPI7+0.png	RPI8+1.png	RPI9+3.png
RPI0+7.png	RPI1+8.png	RPI2+9.png	RPI4+-1.png	RPI5+0.png	RPI6+1.png	RPI7+1.png	RPI8+3.png	RPI9+4.png
RPI0+8.png	RPI1+9.png	RPI3+-1.png	RPI4+.png	RPI5+1.png	RPI6+2.png	RPI7+3.png	RPI8+4.png	RPI9+5.png
RPI0+9.png	RPI2+.png	RPI3+0.png	RPI4+1.png	RPI5+3.png	RPI6+3.png	RPI7+4.png	RPI8+5.png	RPI9+6.png
where most are empty circles and only RPI0+0.png RPI1+1.png... RPI9+9.png are a green dot.
and the control page will then look like:
Screen Shot 2017-01-17 at 22.42.05.png (31.68 KiB) Viewed 7537 times
beacon rad-2 is in room 0 and beacon rad-1 is in room 3
naturally this can be made look nicer with a real floor plan, but I hope you get the principle
you could use a name instead of the green dot eg make "rad-1" "rad2" an image and replace RPI1-1.png for the 2 files with the image of the beacon and leave the empty images as is this would add one image file for each beacon per room (= 10 images for each beacon for 10 rooms - 10 times the same image but with a different name: abc9-0.pgn ... abc9-9.png if the name of the beacon/image is abc)
and with some modified parameters ( caption on image)
Screen Shot 2017-01-17 at 23.14.28.png (27.63 KiB) Viewed 7529 times
johnpolasek
Re: piBeacon: 19- display in which room a beacon is
Post by johnpolasek »
Do you really need ALL the blank states? I'll have to go home to make sure, but I was given to understand that for the "custom state" cases (ie +.png, +state_a.png, ..., +state_z.png), anything that didn't match any of the specified states got the default +.png image. If that's the case, you only need a "blank" NearPiN+.png and a "present" image NearPiN+N.png for each Pi... or is my understanding wrong?
I tried that and it did not work. Looking at the indigo code: it tries to find an image that is close to the current value .. and only if it does not find one it uses the default one.
Return to “piBeacon”
