Below is a failing log file (with debug enabled).
Is there any way to fix it at source and if not, is there any way to fix it without having to reboot the iMac?
martphone Radar Debug STATE: SNMP Init
Smartphone Radar Debug STATE: SNMP Run
Smartphone Radar Debug Polling Airport: *192.168.1.1*, Pwd: *public*
Smartphone Radar Debug SNMP Command: snmpwalk -m AIRPORT-BASESTATION-3-MIB -Os -v 2c -c public 192.168.1.1 1.3.6.1.4.1.63.501.3.2
Smartphone Radar Debug Polling Airport: *192.168.1.2*, Pwd: *public*
Smartphone Radar Debug SNMP Command: snmpwalk -m AIRPORT-BASESTATION-3-MIB -Os -v 2c -c public 192.168.1.2 1.3.6.1.4.1.63.501.3.2
Smartphone Radar Debug Polling Airport: *192.168.1.3*, Pwd: *public*
Smartphone Radar Debug SNMP Command: snmpwalk -m AIRPORT-BASESTATION-3-MIB -Os -v 2c -c public 192.168.1.3 1.3.6.1.4.1.63.501.3.2
Smartphone Radar Debug Polling Airport: *192.168.1.4*, Pwd: *public*
Smartphone Radar Debug SNMP Command: snmpwalk -m AIRPORT-BASESTATION-3-MIB -Os -v 2c -c public 192.168.1.4 1.3.6.1.4.1.63.501.3.2
Smartphone Radar Debug STATE: SNMP Poll
Smartphone Radar Debug Searching SNMP data for *44.51.97.10.31.213*
Smartphone Radar Debug Searching SNMP data for *2c:33:61:0a:1f:d5*
Smartphone Radar Debug Searching SNMP data for *2c 33 61 0a 1f d5*
Smartphone Radar Debug Searching SNMP data for *240.180.121.3.21.69*
Smartphone Radar Debug Searching SNMP data for *f0:b4:79:03:15:45*
Smartphone Radar Debug Searching SNMP data for *f0 b4 79 03 15 45*
Smartphone Radar Debug Searching SNMP data for *0.37.75.4.184.13*
Smartphone Radar Debug Searching SNMP data for *00:25:4b:04:b8:0d*
Smartphone Radar Debug Searching SNMP data for *00 25 4b 04 b8 0d*
Smartphone Radar Debug Searching SNMP data for *64.60.252.5.182.225*
Smartphone Radar Debug Searching SNMP data for *40:3c:fc:05:b6:e1*
Smartphone Radar Debug Searching SNMP data for *40 3c fc 05 b6 e1*
Smartphone Radar Debug Searching SNMP data for *228.206.143.109.62.69*
Smartphone Radar Debug Searching SNMP data for *e4:ce:8f:6d:3e:45*
Smartphone Radar Debug Searching SNMP data for *e4 ce 8f 6d 3e 45*
Smartphone Radar Debug Searching SNMP data for *64.60.252.5.178.73*
Smartphone Radar Debug Searching SNMP data for *40:3c:fc:05:b2:49*
Smartphone Radar Debug Searching SNMP data for *40 3c fc 05 b2 49*
Smartphone Radar Debug Searching SNMP data for *228.206.143.109.240.183*
Smartphone Radar Debug Searching SNMP data for *e4:ce:8f:6d:f0:b7*
Smartphone Radar Debug Searching SNMP data for *e4 ce 8f 6d f0 b7*
Smartphone Radar Debug Searching SNMP data for *184.83.172.98.18.157*
Smartphone Radar Debug Searching SNMP data for *b8:53:ac:62:12:9d*
Smartphone Radar Debug Searching SNMP data for *b8 53 ac 62 12 9d*
Smartphone Radar Debug Searching SNMP data for *184.83.172.67.105.64*
Smartphone Radar Debug Searching SNMP data for *b8:53:ac:43:69:40*
Smartphone Radar Debug Searching SNMP data for *b8 53 ac 43 69 40*
Smartphone Radar Debug Searching SNMP data for *16.154.221.190.77.215*
Smartphone Radar Debug Searching SNMP data for *10:9a:dd:be:4d:d7*
Smartphone Radar Debug Searching SNMP data for *10 9a dd be 4d d7*
Smartphone Radar Debug Searching SNMP data for *12.62.159.120.175.243*
Smartphone Radar Debug Searching SNMP data for *0c:3e:9f:78:af:f3*
Smartphone Radar Debug Searching SNMP data for *0c 3e 9f 78 af f3*
Smartphone Radar Debug Searching SNMP data for *184.83.172.39.226.155*
Smartphone Radar Debug Searching SNMP data for *b8:53:ac:27:e2:9b*
Smartphone Radar Debug Searching SNMP data for *b8 53 ac 27 e2 9b*
Smartphone Radar Debug Searching SNMP data for *228.206.143.109.221.179*
Smartphone Radar Debug Searching SNMP data for *e4:ce:8f:6d:dd:b3*
Smartphone Radar Debug Searching SNMP data for *e4 ce 8f 6d dd b3*
Smartphone Radar Debug Searching SNMP data for *228.206.143.109.55.89*
Smartphone Radar Debug Searching SNMP data for *e4:ce:8f:6d:37:59*
Smartphone Radar Debug Searching SNMP data for *e4 ce 8f 6d 37 59*
Smartphone Radar SNMP Output for 192.168.1.3:
wirelessnumber.0 = integer: 0
SQL Logger update complete
Smartphone Radar Error Some SNMP processes timed out. The address is wrong or the router is unreachable.
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Alan's iPhone'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Mat's Room'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Balcony'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Living Room'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Family Room'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Master Bedroom'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Dining Room'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Ross's iPhone'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Mat's iPhone'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Ross's Laptop'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Becky's iPhone'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Yvonne's iPhone'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Back Yard'
Smartphone Radar Debug Incrementing lastSeen timer of 'Radar Airplay Ross's Room'
Smartphone Radar Debug validating Prefs called
Smartphone Radar Debug STATE: Init
Smartphone Radar Debug getConfiguration start
