Hi Adam,
I just installed DomoPad v:1.4.3 on Android cell phone.
I put in my Reflector info, but it won't connect. It says "There was a problem connecting to Server".
If I go to a standard web browser, put in Reflector address/Login/PW, it connects fine.
If I put my IP/port address in DomoPad, it connects to Indigo Server fine.
Can't use IP/port address in DomoPad because ISP constantly changes it.
I have DomoPad set to only connect remotely, and put nothing in Home connect, as I don't use Wifi in my house.
Oh, and FYI, my Reflector worked fine with my iphone and Indigo Touch app?
But, I'm switching over to this Android phone, and would love to use your DomoPad app with Reflector account.
Hope there is a solution, I will buy the Premium of the app if it will work with Reflector.
-Thanks
DomoPad won't work with Reflector? - Help!
- RogueProeliator
Re: DomoPad won't work with Reflector? - Help!
Most users of the application that I have talked to use the Reflector service (including me), so that is definitely working on the application (I use it myself too). Just to confirm, is this how you have it setup:
Away IP/Host Name => Reflector address
Away Port => Use Default
Away Use HTTPS => Checked
Current Location => Away
Auto-Switch Location => NOT checked
Does that look like your settings? If so, try setting up a Unique Identifier (maybe to your forum name) in the Error/Crash Reporting section of settings. Then go to Devices list; once you see the error message that it isn't connecting, click the the menu and choose Help. Then Send Debug. That will provide me with an email for debugging that hopefully will show some error details.
Adam
Adam
Hi Adam,
I thought I had it set right, but I had put in the port number.
When I set that to default, it worked.
Now I can confirm that it is working GREAT! with Reflector.
Thank you SO much for your android addition to Indigo.
Now I'll buy the upgrade to Ultimate.
-Tom
-Tom
- RogueProeliator
Glad you got it working - and thanks!
