Installation troubles, beyond my level of expertise to fix.
Didn’t have pip2.6 installed, so followed manual instructions
“sudo easy_install-2.6 pip2.6”
Which failed; trace follows:
2014-Mac-Mini:~ admin$ pip2.6
-bash: pip2.6: command not found
2014-Mac-Mini:~ admin$ sudo easy_install-2.6 pip2.6
Password:
Searching for pip2.6
Reading http://pypi.python.org/simple/pip2.6/
Couldn't find index page for 'pip2.6' (maybe misspelled?)
Scanning index of all packages (this may take a while)
No local packages or download links found for pip2.6
error: Could not find suitable distribution for Requirement.parse('pip2.6’)
So had a look around indigo forums and found an amended installation command:
This seemed to work. Trace follows:
Searching for pip
Reading http://pypi.python.org/simple/pip/
Best match: pip 8.1.2
Downloading https://pypi.python.org/packages/e7/a8/7556133689add8d1a54c0b14aeff0acb03c64707ce100ecd53934da1aa13/pip-8.1.2.tar.gz#md5=87083c0b9867963b29f7aba3613e8f4a
Processing pip-8.1.2.tar.gz
Running pip-8.1.2/setup.py -q bdist_egg --dist-dir /tmp/easy_install-5ojD7q/pip-8.1.2/egg-dist-tmp-2Wbobv
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.mailmap'
warning: no previously-included files found matching '.travis.yml'
warning: no previously-included files found matching '.landscape.yml'
warning: no previously-included files found matching 'pip/_vendor/Makefile'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'appveyor.yml'
no previously-included directories found matching '.github'
no previously-included directories found matching '.travis'
no previously-included directories found matching 'docs/_build'
no previously-included directories found matching 'contrib'
no previously-included directories found matching 'tasks'
no previously-included directories found matching 'tests'
Adding pip 8.1.2 to easy-install.pth file
Installing pip script to /usr/local/bin
Installing pip2.6 script to /usr/local/bin
Installing pip2 script to /usr/local/bin
Installed /Library/Python/2.6/site-packages/pip-8.1.2-py2.6.egg
Processing dependencies for pip
Finished processing dependencies for pip
So, back to the manual, and tried to install PILLOW, but that failed too. Long trace follows…
2014-Mac-Mini:~ admin$ sudo pip2.6 install PILLOW
DEPRECATION: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of pip will drop support for Python 2.6
The directory '/Users/admin/Library/Caches/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/Users/admin/Library/Caches/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting PILLOW
/Library/Python/2.6/site-packages/pip-8.1.2-py2.6.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#snimissingwarning.
SNIMissingWarning
/Library/Python/2.6/site-packages/pip-8.1.2-py2.6.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
Downloading Pillow-3.3.1.zip (10.8MB)
100% |████████████████████████████████| 10.8MB 99kB/s
Installing collected packages: PILLOW
Running setup.py install for PILLOW ... error
Complete output from command /System/Library/Frameworks/Python.framework/Versions/2.6/Resources/Python.app/Contents/MacOS/Python -u -c "import setuptools, tokenize;__file__='/private/tmp/pip-build-xrTY_Q/PILLOW/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-XHHMg1-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.macosx-10.10-intel-2.6
creating build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/__init__.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/_binary.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/_tkinter_finder.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/_util.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/BdfFontFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/BmpImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/BufrStubImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ContainerIO.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/CurImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/DcxImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/DdsImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/EpsImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ExifTags.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/features.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/FitsStubImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/FliImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/FontFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/FpxImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/FtexImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/GbrImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/GdImageFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/GifImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/GimpGradientFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/GimpPaletteFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/GribStubImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/Hdf5StubImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/IcnsImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/IcoImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/Image.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageChops.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageCms.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageColor.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageDraw.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageDraw2.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageEnhance.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageFilter.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageFont.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageGrab.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageMath.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageMode.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageMorph.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageOps.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImagePalette.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImagePath.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageQt.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageSequence.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageShow.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageStat.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageTk.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageTransform.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImageWin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/ImtImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/IptcImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/Jpeg2KImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/JpegImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/JpegPresets.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/McIdasImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/MicImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/MpegImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/MpoImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/MspImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/OleFileIO.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PaletteFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PalmImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PcdImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PcfFontFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PcxImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PdfImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PixarImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PngImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PpmImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PsdImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PSDraw.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/PyAccess.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/SgiImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/SpiderImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/SunImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/TarIO.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/TgaImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/TiffImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/TiffTags.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/WalImageFile.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/WebPImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/WmfImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/XbmImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/XpmImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
copying PIL/XVThumbImagePlugin.py -> build/lib.macosx-10.10-intel-2.6/PIL
running egg_info
writing Pillow.egg-info/PKG-INFO
writing top-level names to Pillow.egg-info/top_level.txt
writing dependency_links to Pillow.egg-info/dependency_links.txt
warning: manifest_maker: standard file '-c' not found
reading manifest file 'Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.sh'
no previously-included directories found matching 'docs/_static'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.landscape.yaml'
warning: no previously-included files found matching 'build_children.sh'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
writing manifest file 'Pillow.egg-info/SOURCES.txt'
copying PIL/OleFileIO-README.md -> build/lib.macosx-10.10-intel-2.6/PIL
running build_ext
File "/private/tmp/pip-build-xrTY_Q/PILLOW/setup.py", line 753, in <module>
zip_safe=not debug_build(), )
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/core.py", line 152, in setup
dist.run_commands()
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/dist.py", line 975, in run_commands
self.run_command(cmd)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/dist.py", line 995, in run_command
cmd_obj.run()
File "/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/setuptools/command/install.py", line 56, in run
return _install.run(self)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/command/install.py", line 587, in run
self.run_command('build')
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/cmd.py", line 333, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/command/build.py", line 134, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/command/build_ext.py", line 340, in run
self.build_extensions()
File "/private/tmp/pip-build-xrTY_Q/PILLOW/setup.py", line 521, in build_extensions
' using --disable-%s, aborting' % (f, f))
ValueError: zlib is required unless explicitly disabled using --disable-zlib, aborting
Command "/System/Library/Frameworks/Python.framework/Versions/2.6/Resources/Python.app/Contents/MacOS/Python -u -c "import setuptools, tokenize;__file__='/private/tmp/pip-build-xrTY_Q/PILLOW/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-XHHMg1-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /private/tmp/pip-build-xrTY_Q/PILLOW/
Looks like a permissions problem. Let’s go check ‘admin’s permissions for /Users/admin/Library/Caches/pip/http...
Turns out there is no such directory. /Users/admin/Library/Caches exists with the correct permissions, but no pip subdirectory
Now I’m lost
