Notification sound
WouterK
Notification sound
Post by WouterK »
Is it possible to change the sound of the notification other then in Domopad itself?
I would like to select a different sound depending of the message I want to sent.
Regards,
Wouter
polycron
Re: Notification sound
Post by polycron »
Maybe a Low, Medium, High priority that each can have their own sound? Similar to how Pushover works.
Jeff
RogueProeliator
Post by RogueProeliator »
No, there is no way to change the sound at the Indigo Server.
That might be doable; currently the high priority does a different vibrate pattern, but the notification sounds themselves are the same. I'll see about adding this at some point which should accommodate the limited ability to send different sounds by message (since you aren't forced to use priorities in any particular way). Good suggestion, Jeff.
Adam
