Nest Home Error Message
maslett
Post by maslett »
Chameleon,
I recently upgraded to the latest rev of the Nest Home, Nest Home 2 and Nest Home 3 plugins. I am getting error message in the Indigo Log as shown below. Any ideas?
Thanks in advance, Mark
Feb 1, 2016, 6:48:36 AM
Error device "Basement VT Nest Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Basement VT Nest Thermostat" state key humidityInputsAll not defined (ignoring update request)
Error device "Bunk Room VT Nest Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Bunk Room VT Nest Thermostat" state key humidityInputsAll not defined (ignoring update request)
Error device "Great Room VT Nest Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Great Room VT Nest Thermostat" state key humidityInputsAll not defined (ignoring update request)
Error device "Guest Bedroom VT Nest Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Guest Bedroom VT Nest Thermostat" state key humidityInputsAll not defined (ignoring update request)
Error device "Locker Room VT Nest Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Locker Room VT Nest Thermostat" state key humidityInputsAll not defined (ignoring update request)
Error device "Master VT Nest Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Master VT Nest Thermostat" state key humidityInputsAll not defined (ignoring update request)
Error device "Office MA Nest Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Office MA Nest Thermostat" state key humidityInputsAll not defined (ignoring update request)
NEST Home sent "Office MA Nest Thermostat" decrease heat setpoint to 74.0
NEST Home sent "Office MA Nest Thermostat" decrease heat setpoint to 73.0
NEST Home sent "Office MA Nest Thermostat" decrease heat setpoint to 72.0
Feb 1, 2016, 6:49:38 AM
NEST Home Master Bedroom Thermostat last_connection updated to 2016-02-01T11:48:44.874Z
Trigger isNestMA_Upstairs_Temp copy
NEST Home Master Bedroom Thermostat ambient_temperature_f updated to 72
NEST Home Master Bedroom Thermostat humidity updated to 30
NEST Home Office Thermostat last_connection updated to 2016-02-01T11:48:49.059Z
maslett
Re: Nest Home Error Message
Post by maslett »
Mike,
I completely uninstalled and reinstalled the plugin and reauthenticated with Nest. The plugin seems to be communicating with Nest but does not appear to be controlling the Nest thermostats.
When I increase the temperature the log shows the request but then it appears that Nest overrides the increase request. See the log below.
Feb 1, 2016, 9:50:31 AM
NEST Home Family Room Thermostat last_connection updated to 2016-02-01T14:50:03.094Z
NEST Home Family Room Thermostat has_leaf updated to True
NEST Home Family Room Thermostat target_temperature_f updated to 72
NEST Home sent "Family Room Thermostat" increase heat setpoint to 73.0
NEST Home sent "Family Room Thermostat" increase heat setpoint to 74.0
NEST Home sent "Family Room Thermostat" increase heat setpoint to 75.0
NEST Home sent "Family Room Thermostat" increase heat setpoint to 76.0
NEST Home sent "Family Room Thermostat" increase heat setpoint to 77.0
Feb 1, 2016, 9:52:14 AM
NEST Home sent "Dining Room Thermostat" increase heat setpoint to 72.0
NEST Home sent "Dining Room Thermostat" increase heat setpoint to 73.0
NEST Home sent "Dining Room Thermostat" increase heat setpoint to 74.0
Feb 1, 2016, 9:52:48 AM
NEST Home Dining Room Thermostat target_temperature_f updated to 71
NEST Home Family Room Thermostat last_connection updated to 2016-02-01T14:52:42.319Z
NEST Home Family Room Thermostat ambient_temperature_f updated to 75
maslett
Post by maslett »
Mike,
please disregard previous posts. I think the issue was the number of requests to the API. All seems to be functioning correctly.
Thanks, Mark
Chameleon
Post by Chameleon »
maslett wrote:Mike,
Thanks, Mark
You're right and that's a lesson for all of us. If the cycle time is reduced too much Google will deliver a slap on the wrists and stop you accessing the API for a while (up to an hour or so).
Regards
Mike
Return to “NEST Home”
