Steps to setup Airfoil
This forum is where we've moved the discussions of the original Airfoil plugin that shipped with Indigo 5/6 (and is now open source). You may continue to ask questions in this subforum, just make sure that it's not about the new Airfoil Pro plugin that shipped with Indigo 7 (ask those questions below).
auto_man
Post by auto_man »
I've read the Airfoil Wiki, but it doesn't list the setup procedure to get Airfoil working with Indigo. Does anyone have a step by step procedure for getting loaded and Airfoil working with Indigo? Steps like where does the app need to reside, does it need to be launched, parameters that need to be set, how to set up speakers, et...,,,,
Any help would be appreciated.
colinpartridge
Re: Steps to setup Airfoil
Post by colinpartridge »
Not a step by step guide, but Airfoil needs to be installed on the same machine as your Indigo server. Ensure that there is only one instance of Airfoil on your machine. The Airfoil plugin should automatically detect Airfoil and give you a list of variables related to your airplay devices listed by Airfoil. There really easy much more to set-up apart from setting up your actions groups.
Colin
jay (support)
Post by jay (support) »
Setting up Airfoil itself is a task for the Airfoil documentation (in Airfoil, select the Help->Airfoil Manual menu item). Once it's set up (on the same Mac as your Indigo server as Colin points out), then I believe the Airfoil Plugin docs are pretty complete. Is there something in particular that's not working for you or you have questions about?
Return to “Old Airfoil Discussions”
