Airfoil 4.9.2 breaking plugin?
This forum is where we've moved the discussions of the original Airfoil plugin that shipped with Indigo 5/6 (and is now open source). You may continue to ask questions in this subforum, just make sure that it's not about the new Airfoil Pro plugin that shipped with Indigo 7 (ask those questions below).
simdude
Post by simdude »
Did an update and I'm getting this error:
Airfoil Error Update failed. Check to see if Airfoil is functioning correctly.
Airfoil Debug Update failed with exception:
File "plugin.py", line 460, in update
theCurrentSourceId = self.airfoil.get(theCurrentSource.id)
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/appscript/reference.py", line 498, in __call__
raise CommandError(self, (args, kargs), e, self.AS_appdata)
CommandError: Command failed:
OSERROR: -1728
MESSAGE: Can't get reference.
OFFENDING OBJECT: app(u'/Applications/Airfoil.app').application_sources.ID(64)
COMMAND: app(u'/Applications/Airfoil.app').get(app(u'/Applications/Airfoil.app').application_sources.ID(64).id)
Airfoil Debug runConcurrentThread: update()
jay (support)
Re: Airfoil 4.9.2 breaking plugin?
Post by jay (support) »
What version of Indigo and the Airfoil plugin are you using?
Also, make sure you have a source selected in Airfoil.
simdude
Post by simdude »
I think we are ok. I restarted the computer and was still getting an error. Then, I used Airfoil to send audio from Safari to some speakers, went back to Indigo and reloaded the plugin and it worked. Your suggestion of selecting the source may have been the problem. Thanks!
jay (support)
This bug was fixed in 6.0.21 (and later) along with other things so you might want to consider installing the latest version.
Return to “Old Airfoil Discussions”
